Question about Arris SURFboard Gateway SBG6580 DOCSIS 3.0 Wireless Cable Modem
Just installed SBG6580 and pressed the wireless pairing button by mistake. No devices use this mehtod to connect wirelessly and the light won't stop blinking. How do I stop this light from blinking..or will it always blink (unless it's paired with a device)?
toac990
  • 838 Answers
SOURCE: I just installed a Motorola
Try changing the authentication type to WEP/WPA/WPA etc. Might be your XP laptop doesn't support current authentication type. Thanks for joining us. Have a nice day.
Posted on Feb 24, 2011
  • 40 Answers
SOURCE: Link light blinking
On these cable modems the link light is supposed to blink when you are connected to a router/pc. If you are hooking up a wireless router new you need to power cycle/reset your cable modem before you hook up the wireless router so that way it can refresh its ip address.
Posted on Apr 09, 2009
smartr10U
  • 1305 Answers
SOURCE: I have the sbg900. It suddenly quit working. I get
Best to call up the cable company and go thru the phone prompts...you may just find that they're having trouble in your area...
They can also send a reset signal to your modem too.
Give em a call..
Posted on Jun 07, 2009
puertobori
  • 7733 Answers
There is a great article at Working with Windows Wireless Networks
If you need more help post back! Thumbs and testimonial are welcome!
Posted on Aug 15, 2011
  • 5387 Answers
SOURCE: in need of a user manual for SBG6580 wireless
The User Manuals for many of the Motorola modems and gateways are available from Motorola on their support site: http://www.motorola.com/Support/US-EN/Consumer-Support/Cable-Modems-and-Gateways . Select your model. On the next page, use the drop down menu to select User Manual in the Select A Topic drop-down menu. Then click Search. The direct link to the manual for the SBG6580 is http://www.motorola.com/staticfiles/Support/US-EN/Home-and-Office/Cable-Modems-and-Gateways/SBG6580-SURFboard-Wireless-Cable-Modem-Gateway/Documents/Static-Files/SURFboard_SBG6580_UserGuide.pdf . Note you will need Adobe Reader or a similar program to read the file.
I hope this helps.
Posted on Oct 03, 2011
I have a portable wireless speaker model AWSBT7 will not go into the connect mode when pressing the button to sync up device I do not get the two beeps or the light does not flash faster
Hi Jerry, Are you using this method to pair your device?
Pairing
The Bluetooth-enabled device that you wish to stream audio to your speaker system must
fi rst be paired to the speaker. The process is simple, and in most cases the pairing process
needs to be done only once.
To pair your Bluetooth-enabled device with the speaker:
1. Make sure your device's Bluetooth is turned on. See the wireless and/or network settings
menu on your device to check.
2. If the speaker isn't already on, press the On-Off button to turn it on. You will hear a beep
to indicate the speaker is turned on. The indicator light on the back of the speaker starts
fl ashing blue.
3. Press and hold for 3 seconds the Pair button to enter pairing mode. You will hear 2 beeps
to indicate pairing mode is entered. The indicator on the back of the speaker starts blinking
faster.
4. Open the Bluetooth settings menu on your device. Select "AR SPEAKER" from the list of
devices available (you might have to scan for devices). If your device asks for a password,
enter "0000".
5. A confirmation screen will appear on your device once the speaker and the device are
successfully paired. The blue indicator turns solid blue to indicate successful connection.
The speaker is now ready for you to stream audio from your device.
Oct 24, 2014 | Audio Players & Recorders
Motorola SBG6580
Open Device Manager and set the wireless adapter Power tab to not turn off to save energy. Or modify Sleep mode to not turn off wireless adapters and USB devices. USB if you use a USB wireless adapter.
Jan 29, 2018 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
I have a Motorola SURFboard Gateway SBG6580 modem. I want to use the wireless for my DS lite but it says that I need an WEP key, but I don't know how to enable it. Help!
Your wireless is set up with a password. You need to get that password before you can connect any more devices. From a computer that can connect to the internet go to 192.168.0.1. Then type admin for the username and motorola for the password. I believe from there you click Wireless then click Primary Network. You should see your wireless network name and password from there. I'm getting this from the modems manual here: http://www.midcocomm.com/_files/files/SBG6580.pdf
Oct 16, 2012 | Arris SURFboard® SB5101 Cable Modem
Gateway wireless keyboard detection
Insert the installation CD that came with your wireless keyboard set into your computer's CD-ROM drive.
Use the CD to install the drivers for the wireless peripherals.
Insert batteries into the keyboard .
Use a screwdriver to remove any screws that hold the battery bay covers closed.
Connect the wireless signal receiver to your computer.
Receivers for wireless keyboard and mouse sets usually use a USB connector.
Your computer will automatically detect the receiver.
Turn on your keyboard if the devices have power buttons.
Press the "Sync," "Connect" or "Pair" buttons on the keyboard , depending on your model.
If present, press the "Connect" button on the wireless signal receiver as well.
Your wireless keyboard set is now connected.
hope this helps
Oct 13, 2012 | Gateway One Computers & Internet
How to install the headset to my EVO 4g
To pair the Plantronics BackBeat 903 with an EVO 4G:
On the 903 headset:
With the headset powered off, press and hold the "Power/Pairing" button until the LED indicator flashes blue and red. This will put the 903 headset into pairing mode.
Use the iPod Touch menu to search for the headset and select 9xxBackBeat.
(If prompted, enter 0000 for the PIN code/passkey. Some devices also require you to accept the connection. Headset is paired when LED flashes blue.)
On the EVO 4G:
Turn the Bluetooth on from the Home screen, tap Menu, Settings, Wireless & Networks, Bluetooth.
Pair the EVO 4G by going to the Home screen, press Menu, Settings, Wireless & Networks, Bluetooth Settings, Scan for Devices. Follow the on screen prompts to pair the devices.
Good luck from Headsets Direct - 800-914-7996.
Aug 13, 2011 | Plantronics Backbeat 903 Bluetooth...
Reset button was hit but cannot log in with admin and motorola locked out and cannot get lap top to connect
It seems I didn't push the button long enough or I pushed it and then pulled the power cable. That got me into some weird condition where internet would work but was not able to login to the router.
The right way:
- Press and hold the reset button until the devices lights start to shutoff
- Wait
- Login with the defaults: admin/Motorola
May 14, 2011 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
I installed a new vista on my 6715b and ever since my laptop have stopped showing available wireless connections, how do i solve this problem?
First, make sure that the drivers for wireless adapter are installed. If not, the drivers for vista are available from the following link.
HP 6715B Note Book Drivers
Visit this link from HP Official Support. Select the correct version of Operating System (Vista) and download the required Drivers.
Also, the computer has a wireless button, Press the wireless button to enable/ disable wireless. (If the wireless light is blue, wireless device is on. If the wireless light is off, wireless device is off)
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck!
Don't forget to convey your feedback
CreativeTECH
Feb 03, 2011 | HP Computers & Internet
Dell wireless keyboard and mouse will not work
Normal 0 Go to Control Panel and click on Sound.
Next click Bluetooth Devices.
Click Add button, lower left corner of the Bluetooth Devices window.
Insure batteries are installed.
Press the Connect Button on the Keyboard (Usually located on the under side of your keyboard) this allows Windows to see the keyboard so you can pair the keyboard to the computer.
On the computer choose My Device Is Set Up and Ready To Be Found.
Click NEXT.
The keyboard should appear in the Add Bluetooth Device Wizard Window.
Select your Keyboard and click Next.
When prompted, select Choose a Passkey For Me and click Next.
Windows will generate and display a Passkey.
Type the Passkey specified on the Bluetooth Keyboard
(do not use the keyboards keypad when typing the passkey)
No charters will appear on the monitor when typed, but if you make a mistake, you can backspace.
You must enter the Passkey within 30 seconds.
If you don’t enter the Passkey within 30 seconds, click Back and click Next again.
Once the Passkey is entered, the Keyboard should be connected to the computer.
Finish and follow any on screen instructiond.
Hope this helps. Bud
Dec 15, 2008 | Dell Wireless Keyboard Optical Mouse w0147
Arris SURFboard Gateway SBG6580 DOCSIS 3.0 Wireless Cable Modem Logo
1,434 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Jerry
Jerry
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
