Question about Dryers
Takes too long to dry - Dryers
  • 1,998 Answers
Have you tried dlinting your dryer the main cause for a dryer to break down is due to lint build up most technicians charge about 100 to do this job and its a simple proces of taking the unit apart and using a vacuum to **** up all the lint build up you would have to remove the inner drum of the unit and after taking out all the lint go to the back panel and also remove the blower housing which is the back area of the lint screen lint that the dryer produces is what actually makes the heater and the thermistors short out you can also perform continuity tests on the thermistors to assure that they are working properly as well as the heater. remember to unplug your unit before performing any continuity tests. If you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations in the future Thanks Rick
Posted on Mar 14, 2011
It is taking far too long to dry, this has only recently started? what could be the problem?
Does it get hot? If it does, then the problem is reduced air flow, caused by a lint filter that hasn't been cleaned, masses of fluff in the exhaust pipe (usually on bends), or the external vent not opening properly. Birds can also nest in the vent pipe if the vent isn't protected or is broken.
If it doesn't get hot, you need a new element. Some dryers have two elements if the dryer has a high and low setting. just one element can fail.
Jan 20, 2016 | Zanussi TC7102W Electric Dryer
What setting for drying clothes takes the shorties time
make sure your filters and around your drum is clean that is a reason for clothes taking long to dry
Oct 13, 2014 | Dryers
Taking to long to dry clothes
How long does it take you to dry your clothes? Normally, it takes 50 minutes (1 cycle) to 1.5 hours to completely dry clothes. However, if it's taking you at least 3 cycles (probably 2.5 to 3 hours) to dry a single batch of clothes, then, there might be a problem with your dryer's igniter.
Jan 09, 2014 | Speed Queen AGS17AWF Gas Dryer
LG Dryer takes too long to dry clothes
Sure the outside vent is not clogged up? If so it will overheat and turn it self off and do a poor job of drying the clothes.
Also check and make sure that all of the heating elements are working properly.
Jul 09, 2017 | Dryers
Takes long to dry clothes
on your side, it is better you don't touch anything internal in the dryer as you can hurt yourself and spoil the device even more. have a professional take a look at it before you use it any further.
Jun 11, 2010 | Kenmore 62802 Electric Dryer
Dryer takes hours to dry
sound like you dry not heating,might need to replace the element
Apr 24, 2010 | Whirlpool GGW9250PL Gas Dryer
AUTO CYCLE TAKES A VERY LONG TIME, HEAT IS OK, GAS DRYER
First thing I would check is the vent. If you have good heat but it is still taking too long, usually it is caused by a vent that is either too long , kinked or clogged. if the dryer is auto dry and not electronic dry then you will need to gauge weather the load needs more or less dry. If it is just taking a long time for the clothes to dry, more than likely the vent. If the clothes are dry before it is done running then it is more than likely a setting issue. Way out of the box .... are your clothes spinning out dry enough in your washer? do they dry in the normal time on timed dry?
Dec 18, 2009 | Dryers
The dryer takes about 3 hours to dry whereas it
make sure the vent hose and outside door flapper is clear. Try drying one load with the hose off to see if its better.
Sep 08, 2009 | Dryers
Dryer takes a long time to dry.
This sounds like the vent is plugged up. The dryer gets rid of moisture through the dryer vent and hose. When this gets plugged up it will take a long time to dry or the hi limit will shut it off. When the dryer vent or hose is partialy blocked it will take vary tong times to dry the clothes and will eventualy cause the dryer to stop drying all together.
Nov 14, 2008 | Dryers
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
