Question about Armitron Watches
How to change time on watch with three buttons
In my fastrack digital watch 38033sp01. how i change time?
Hi Chappy ,
its look like a simple 4 button digital.
normally you would press the mode button three times and then the seconds would flash , using the two button on the right side of the watch you can adjust and move onto the hours minutes etc.
when you havea djusted the time etc press mode once to return to normal time.
Aug 25, 2017 | Watches
How to change the time on the Xonix field ranger water risitance 50m watch
looking at a watch online it is astandard four button lcd watch .
most work by pressing the mode button three times , this will make the number flash, then use the top right and bottom right to adjust and move to the next number field.
at the end of setting just press mode again.
Aug 20, 2017 | The Watches
HI, I brought my OTS sports watch in China, i forgot we have 12 hours differents in US, so now in US is 10:31am but my watch is 22:31, i tried so many times and can't change it, please...
http://www.worldofsportwatch.com/en/product-3315.html
This is a link to a website that has OTS watches on it. Click on the OTS watch you have and there is a manual selection. The instructions are a bit hazy but basically you have to press the mode button 3 times, the reset button to get to what you want to change, and then the start button as many times as needed to change it to what you want. I finally corrected my watch time and date using it. Thankfully!
Aug 18, 2010 | Watches
How do i set time on unlisted watch
dear sir
there r three buttons in which there r combination of buttons. your stopwatch button may not set the time . the middle button may set the time for u
Apr 09, 2010 | Kenneth Cole KC2315 watch
Athletic wrist watch stuck in 24 hour mode
Maddening, isn't it? Fortunately the solution is here:
http://www.ehow.com/how_5593310_set-athletic-works-watch.html
1 There should be four buttons: mode, reset, start and light. Find the mode button and press it three times until it is in the set time mode.
2 Find the reset button, which usually is located on the bottom right side of the watch face, and hold it until the time starts blinking.
3 Press the start button to change minutes.
4 Press the reset button again to switch to hours.You will know it worked when the hour starts blinking instead of the minutes.
5 Press the start button to change the hour. The watch can handle two modes: standard and military. As you press start, the hour will change from AM to PM, noted by an "A" or a "P" in the top right. When you get through 24 hours, the watch will change to military time and an "H" will be displayed instead of "A" or "P." Keep pressing start to go through another 24-hour cycle and it will revert back to standard time.
Apr 30, 2009 | Watches
How do i set alarm on a gap sport watch?
For setting Time & Date...
1. Push "MODE" button three times (change Mode to TimeSet)
Time -> StopWatch -> AlarmTimeSet -> TimeSet -> Time ->...
2. Flashing Second Number Digits
3. Push "RESET" to select...
Second -> Minute -> Hour(12hr<->24hr) ->...
Date -> Month -> Day of Week -> Second -> ....(repeat)
4. Use "START" to set each item...
For setting Alarm ON/OFF
1. Push "RESET" button then Push "START" same time...
Alarm ON -> Alarm OFF -> ... (repeat)
Jan 09, 2009 | Columbia All Sport Digi Watch l
I have a roger black pulse work and i do not know how to work it as it didnt come with instructions. i cannot set the time and it is beeping like a timer but i cannot switch it off can you help?
good morning! to set your watch is you need to press the adjust button up to three second after blinking the digit on you watch press the mode button to select the digit that you want to change, to change the digit use the two button on the right side of your watch,after setting press the adjust button once and your watch is gona be normal,thank you ! god bless !.
Aug 27, 2008 | Watches
Daylight savings time change without auto change in watch
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
http://world.casio.com/wat/download/en/manual/
You will need a pdf reader on your pc, you will find all instructions in there.
Mar 10, 2008 | Casio G7500G-9V G-Shock Vibration Watch
Aquatech Sport Chronograph Watch
quickly press the bottom-left button twice.
then, press the bottom-right button once, and then the top-right button once. this should add 1 to the day. keep pressing the top-right button until u get the right day, the press the top-right button again.
now, how do u change the time format back to twelve hr. ?
Dec 20, 2007 | Watches
Watches Logo
35 people viewed this question
Top Armitron Watches Experts
Ansel Alberto
Ansel Alberto
Michael Vincent Cruz
Are you an Armitron Watch Expert? Answer questions, earn points and help others
