Question about Dell Inspiron 6400 Notebook
Hello there. Accidently yanked the power cord with foot and pulled computer onto the floor the other day. It was about a foot and a half drop onto carpet. It landed on its side onto the USB mouse plug in and then landed flat open on screen/keyboard side. After this I received the dreaded 'blue'screen. Upon trying to reboot I got an error message saying no device detected...no bootable devices and it failed the hard disk drive test upon completing diagnostics. Please help!
    Problem Solver:
  • 15 Answers
Before assuming something more serious is the cause, I'd suggest you open the hard drive bay and check if the connector simply needs to be re-seated. I'd guess the bay is on the side the laptop fell on. There is typically a screw or two keeping the "bay" or "tray" from opening. You'll probably find a HDD looking symbol on it. Unscrew the screws and slide it out and disconnect and reconnect the cable and then put it back together. If it still cannot detect the hard drive after that, you may need to enter the BIOS and tell it to or you may have a more serious problem.
Posted on Mar 14, 2011
    Problem Solver:
  • 18 Answers
The dreaded no bootable device error. Well, there's two possibilities here. It could be a problem with reading the hard drive due to an error. In this case, you could try using SpinRite from GRC, which is pretty much the be all and end all for defect detection and recovery. GRC even offers a money back guarantee if it doesn't save your drive, no questions asked. Alternatively, you could take it to a repair shop if you're not confident in running this utility yourself.
If the problem has come from actual damage to the drive, such as a scratched disc, there's not a whole lot you yourself can do about it. You can send it in for repairs to see if the disc can be fixed or any of the data can be salvaged and transferred off the drive. Unfortunately, there are no guarantees, and this is also the more likely case in your situation.
Either way, best of luck in trying to get your files back! I've been in that boat twice before, and it's never fun.
    Scholar:
  • 135 Answers
It seems that it has got damaged by the drop . I also think that it is not covered under warranty anymore . In this scenario the best option will be to quickly get in touch with a local technician and check what all parts got damaged and work accordingly. But if it is covered under warranty then immediately contact technical support .
hello there.
Accidently yanked the - img.aspx?p=cbosfesa2yatsrf2ix2bltyztr%2fbthtof6z4byffmxn9axvezlzfxk3i%2begxtz0hlsnqbcy3wfgmwk12jlifpx13b1tarf4adrfqi2ydhss2mbhjmfofdw6u9yu%3d Home and Home Office Hardware Technical Support
Speed up your call (what should you do before calling Dell)
For faster service, please enter Express Service Code when prompted on the call.
1-877-293-1197 24/7
Deaf, Hearing Impaired, or Speech Impaired Support
1-877-DELLTTY Mon - Fri 8 AM to 4:30 PM
Solution Station
Need help with software, optimization, networking, viruses or other non-hardware warranty support issues? Call premium service phone support.
1-866-795-5597 24/7
    Guru:
  • 767 Answers
Normally the Blue Screen of Death is caused by faulty drivers but in your case it has been caused by a RAM or most likely hard disk failure. By getting the "No device detected error" it shows that your hard drive is damaged. You will need to replace the hard drive with another 2.5" laptop hard drive. Once the new hard drive is in you can find out if the RAM is faulty or fine. If after you replace the hard drive and your system gives a long beep or repeating beep then your RAM has too been damaged. I suggest taking your laptop to a repair technician to find out exactly which parts are damaged.
  • 49 Answers
It's a problem with your hard drive.
Either some connections came loose, thanks to the fall, or the hard drive is damaged.
You should take your laptop to a computer repair shop. If the hard drive is broken, they still might get some of your data back. Otherwise you'll need a new hard drive.
If you found this answer helpful, please rate it.
It will help me and other users that are searching for help.
  • 164 Answers
Hi Audrey, if the hard drive was operating (reading/writing) at the momento of the fall, it's very likely that it got busted and is very probably not going to work for you anymore. You can however try to see if the hard drive was disconected by the impact of the fall, try removing the HD and inserting it again, if that does nothing, then you will have to consider buying a new one.
    Sergeant:
  • 162 Answers
Unfortunately your hard drive might be dead. Does your hard drive makes any clicking noise? if it does you will have to change it out.
2006 pt cruiser oil leak three small drops all with in a foot and a half of each other
When the head was removed to replace the head gasket, likely oil was 'spilled' down the sides of the engine block. If it wasn't completely cleaned, it may have accumulated on the frame cross member or other components below the engine. I would clean up the drops on the floor and watch for additional evidence for a couple of days. If they keep appearing, take your car to the shop that did the work and have them check it out for you.
Aug 26, 2017 | Cars & Trucks
I plug the power washer in turn it on and the motor does not turn on and I hit the reset button also nothing I used it a day befor the next day nothing is there a fuse and so how I get to it
Before you take it apart (per my directions provided on another response to your posts), inspect the power cord. In particular, if somebody yanked on the cable to unplug it instead of pulling on the plug, look at the plug, and gently pull on or bend the cable while holding the plug to see if a wire might be broken or pulled loose right at the plug. If you suspect this, you may be able to confirm it by plugging the washer in, turning it on, and pushing the cable into the plug. If the motor runs at all - even an intermittent jerk, this is your problem, and you'll have to cut the plug off and replace it. Make sure the new plug is rated for at least as much current as is listed on the nameplate (the current rating may also be molded onto the original plug between the blades).
Jun 26, 2015 | Garden
Starter coard broken
The starter housing is removed with a #20 Torx bit, then the cord replacement becomes obvious. You'll need to prewind the spring about half it's capacity before engaging the cord reel to the rewind spring. Good luck with it. These cords won't break if you use short pulls, preferably with your foot holding the right hand hold to the floor.
Jun 03, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
My friend accidently yanked on the cord of PS2
you could try putting the wires back to gather other then that no.
Apr 02, 2010 | Sony PS2 Dual Shock 2 Controller...
Starter cord only pulls 1 foot
Most push mowers have 3 bolts on the side of recoil shroud. One in front, (where plug is) and two on side.
Apr 12, 2009 | Garden
Power supply doesn't seem to supply power to Gateway labtop
Well its likely that you could have damaged the power cord. If one of the internal wires got yanked when your foot caught the cord it could have lost it's connection. Try going to an electronics store and asking if they have any universal adapters, look on the back and see if your laptop model is supported. Try it and see if it works, if not return the cord and the problem will be with the female plug in the back of the laptop. Like you said its probably not the laptop
Hope this helps, please comment back if you have any further questions or information about the problem. Feel free to leave positive feedback if this helps, thanks for stopping by at Fixya!
Jan 20, 2009 | Computers & Internet
Dropped Toshiba Laptop...
Very good guess. If the computer is turning on and going through POST and it's coming up with that error, then it's the hard drive (hopefully not the platters).
If it makes noise (like clinking or grinding on startup), then you may be done for.
If it makes no noise (not even a hum) then the spindle isn't starting or may be stuck.
If it sounds fine, then it's the platters, and that's something on the microscopic level to fix.
You could google disksavers, they are an expensive company, but they have the correct means to save your data if you really, really, really, want.
Otherwise, if you have nothing to lose, take the hard drive out (usually there are some screws on the bottom which lock the hard drive in, just unscrew and simply pull it out, when the lappy is OFF) and put it into an enclosure (a seperate thing you can pick up for 20 bucks and return later if the hard drive really is bust. You can get them from most places, just make sure to bring your hard drive so they can help you with finding the right connector),
After it's good to go, plug it into another computer.
If you can't read from it (even with the additional power provided by the enclosures power cord(usually usb powered too)) then you can try putting the drive in a ziploc bag, and freezing it in a freezer for about 3 hours. Then try to read from it again (quickly).
If that doesn't work, then I don't know what to tell you mate.
Dec 15, 2008 | Toshiba Satellite A105 Notebook
My Vista Laptop immediatly shuts down after i pluck out the power cable.
It sounds as if the power pin (where the AC cord connects to the computer) has been damaged. The part to fix it usually runs under $10 but the labor is gonna set you back $100-200.
Because the connector pin is so fragile, the damage to the pin is caused by the day to day tugging and pulling on the power cord.
What you needed when you got the computer is a cable stay or cable retention device like the Jerkstopper. It takes up the strain when you yank or **** the power cord and minimizes the damage to the power pin. It's a very common problem with laptops.
Here's a short video that talks about the problem. . . .
Apr 20, 2008 | Toshiba Satellite 2410-S203 Notebook
NOT SCANNING CORRECTLY
I'm guessing you are using the USB version and the power that comes from the comuter via the USB cable.
It is quite likely that the problem you are having is due to power sag. .500ma is the limit from P.C. s
Do you have a 15 foot cord on there? If so try a 6 foot cord. Sagging still occurs with a 6 foot cable ...but only half as much. If the problem goes away you are on the right track.
I have a cable (I should say Motorola has a cable) with a separate power supply that should fix the problem.
Dec 15, 2007 | Symbol LS2208 Handheld
Dell Inspiron 6400 Notebook Logo
123 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
