Question about Tools & Hardware - Others
Need a manual for a Reliant 6" belt sander. Modal
muttandjeff
  • 359 Answers
SOURCE: Porter Cable belt sander
try to rig the nozzle of a shop vac to the part where the bag would normally connect and run the sander simultaneously with vac for a few minutes and see if that helps
Posted on Jan 11, 2009
SOURCE: I need manual for Craftsman 315.11720 belt sander
Place the front roller against a workbench or the curb and push until it locks. Remove and replace the belt, to release the locking mechanism, use a flat head screwdriver and push the roller into original position. Simple.
Posted on Jul 11, 2009
SOURCE: User Manual for Delta 31-460 Sander
I'm not sure if this is the correct way to post a response, but I have a manual for Delta 31-460 sander. Let me know if you still need one.
Posted on Oct 22, 2009
SOURCE: broken drive belt on belt sander
My answer comes almost a year after the original question, but I'll post it anyway for those who end up here after a search.
Black & Decker no longer supplies drive belts for the BR400 sander, but you can get a replacement elsewhere if you know what to ask for.
The belt is a synchronous, single-sided "XL" series belt, and mine had 120XL031 printed on it. The belt width is 0.31in or 5/16in or 7.9mm. Its pitch (distance from tooth to tooth) is 0.20in or 1/5in or 5mm. Its total height is 0.09in, and tooth height is 0.045in. It has 60 teeth, making the total length 12in.
I found a replacement at sdp-si.com, part number A 6R 3-060031.
Look here for timing belts (inch), then narrow the search for single-sided, .200 (XL) pitch, 60 grooves, 5/16 width.
Posted on Jun 16, 2010
  • 40 Answers
On my model 315.11720 3"x21" Craftsman belt sander to change out sanding belts you push the front roller in until it clicks to lock in its retracted position (a pry bar may help here), switch out sanding belts then unscrew the tracking tensioner a bit on the opposite side with a allen wrench until the roller snaps back in place. I never remember anything about using a screw driver to force it back forward position again. Then readjust the tracking if necessary with a few short sanding load tests and you're good to go. Oil is dropped in the front roller center by removing the flat head screw - it should say "Oil Here" around the screw.
Posted on Aug 19, 2010
Need a belt for a belt sander OZITO BSR-1000 75MM X 533MM MOST LIKELY GET 6 AS SO THIN MOB 0415337515 dave charles
belts are available from any good tool shop or large hardware shop
belt lengths and widths are stamped on the back of the belt
Dec 13, 2016 | Sander Tools & Hardware - Others
I would like a pdf copy of the manual for a Rockwell 361 belt sander?
this covers the 361
some one loaded the instuction booklet side ways
page 6 is the belt fitting
14 pages
http://www.manualguru.com/rockwell-sonicrafter/361c/users-manual/page-4
Apr 29, 2016 | Tools & Hardware - Others
Where can I find a Manual for?
The manufacturer's website might have a pdf or similar in its support page.
Aug 21, 2014 | McFeelys Dayton Belt & Disc Sanders 2" X...
I have a wide belt sander that was made by Sunhill Machinery. I bought it used and it has has a digital controller. The manual does not give any instructions on how to use the controller and I have also...
I have a Reliant 6" belt/disk sander
Reliant dd79 3/4 hp, which is suppose to rise to a vertical position.
I need a manual for this.
e-mail delhotel@comcast.net
Jan 07, 2011 | Sunhill Machinery Sunhill Spiral...
I need an owners manual for a Craftsman 6" x 9" Belt & Disc bench top electric sander. Where may I go to "download" a copy. The specs for this sander are : 6" x 48" belt at 2700 FPM ...
Go to: Searspartsdirect.com and enter the full code number minus the decimal point. That will take you to a series of drawings with parts lists. Hopefully, they still list the owner's manual. Good luck!
Aug 04, 2010 | Garden
Need a manual for a Craftsman belt & circular sander
I found a PDF file on Sears.com website for the original manual for my belt / circular sander.
Oct 21, 2009 | Tools & Hardware - Others
Jul 20, 2009 | Tools & Hardware - Others
Describe your Black & Decker BR318
This is a good sander but no portable belt sander is really a floor sander.
Jun 13, 2009 | Black & Decker BR318 3" x 18" Belt Sander
Tools & Hardware - Others Logo
307 people viewed this question
Top Tools & Hardware - Others Experts
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
