Question about Technics SL-1210 Turntable
Pitch problem out of nowhere!
My very lightly used/traveled 3-year-old 1210's have never given me a problem until last week at a gig when one of them started pitching erratically...fine at 0%, but pitch up and it would be slowing and speeding seemingly randomly and jerking all over the place. I got them home, used them all week with no signs of the problem, get them out last night for a gig and there it is again, one deck having severe pitch or motor issues...trust me when i say that these decks have very little mileage on them. When the problem occurs, it happens about 70% of the time when i pitch up from 0. Any ideas?
    Problem Solver:
  • 18 Answers
Ok ive also seen this problem many times and i have solved it many times also by simply cleaning the contacts (metal strips) i use "servisol super 10" switch cleaning lubricant but aftershave (alcohol) works fine. if this dont solve the problem then they will be ready for replacement but as you say they aint done a lot, so i reckon a clean and away :)
Posted on May 02, 2009
  • 476 Answers
HI Mattgood2
I believe this is a common problem more evident in decks that have a very hard life,
You pitch controls are probably due for replacements so I suggest you take then to the service agents to service them,
unless you know how to do the servicing
I grew up with Decks under my fingertips so I have seen this before and remember the only satisfing fix was a service and the pitch controls had to be replaced,
I thought I would have a go re-servicing myself and found far too many things to cover once the covers were off,
There are many things that need attention on the inside of these decks and the precise placement of each component is vital to the correct operation of this unit,peace of mind really
It takes a small amount of care to maintain these decks,
when they die or fail get a pro to fix the problem.
guess work only makes you look like an "Amatuer"
Please dont be offended (by my words) Ive done it too,LOL
I had a full dance floor and then nothing,the decks got replaced
What have you used to clean the pitch control sliders???
Posted on Aug 06, 2008
There is power going through my technics 1210,but the platter & strobe light still will not work
how do you know theres power to the unit if theirs no strobe light pitch adjuster light & the platter doesn't spin?
the power comes in & to the transformer first,then through the strobe switch, the transformer is what blows when you short the target light out.....i've seen this many a time when people try & change the target lights to blue neon.
Mar 04, 2013 | Technics SL-1210 Turntable
Security system locked down on 2003 CL55AMG
hello,try to check your battery in your remote key or use your spare key,then try lock and unlock your car,maybe 3 to 4 times until it"s work,ty
Apr 24, 2009 | Mercedes Benz Travel Alarm Clock
PROTRON 26 TWO YEARS OLD
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com
Jan 20, 2009 | Protron PLTV-26 26 in. HD-Ready LCD...
Technics Turntables
Sounds like you need a new pitch control. YOu can purchase a pitch control separately and install yourself, however soldering is required. You will have to solder off the old board, and solder on the new board.
You can purchase the PART HERE
- Davis
DJ PRO AUDIO
www.djproaudio.com
www.repairnyc.com
www.1200s.com
Jul 16, 2008 | Technics SL-1200MK2 Turntable
1210 mk5g pitch adjustor
switch off for a will and see.
if still bad. check the circuit board under.
with old electronic devices, capacitors are commly the ones that may go wrong/dry. which would cause oscillatory circuit to generate wrong signals or strobe or feebacks. if you know how to take out the circuit board, check it starting from capacitors.
Jan 22, 2008 | Technics SL-1210M5G Turntable
Old map installed in new unite
I googled garmin c330 software update and went to a garmin site for this same purpose. I had no problem getting a current update (within the last year) and at no charge. There is also a user forum that is very informative. I travel extensively and have used mine for a year now. I wish I had bought it sooner Ray
Dec 18, 2007 | Garmin StreetPilot C330 GPS Receiver
Platter problem
THE PITCH slider or the variable resistor could have gone faulty. A new pitch is only $25 i think. They may need to salvage the pcb from your old one as technics no longer manufacters them. I've never seen the pitch led stay on lock when the actual pitch is not at zero. Hopefully the pitch did not short out the brake or the variable resistors on the motor's circuitboard.
keep me poted.
Oct 25, 2007 | Technics SL-1210 Turntable
3 year-old threw it across the room
Sorry to say but probably not worth the repair as I've seen 1 gig going lesss then what it would cost round trip for you to ship this one off to the repair dept?? I bought a 256 gig last week with a voice recorder for 12 bucks.
Apr 10, 2006 | Sonic Impact Technologies 5070 256 MB MP3...
Technics SL-1210 Turntable Logo
266 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
