Question about Pioneer DEH-4300UB Car CD/ MP3 Player
I can't seem to be able to switch Demo mode of and that, i think is the source of why everytime i turn off my car, all the the settings i've changed come back to what they were. That includes switching off demo mode as described in the manual... Any help?
  • 1,940 Answers
Check your Wiring, as it sounds like your Constant +12 volt wire is connected to the Switched +12 volt wire. This would cause all settings to return to factory, just like when you lose power due to a bad battery or battery disconnect. Since you switched off Demo mode, and it comes back, this has to be a wiring problem, or a defective unit, but more than likely a wiring problem. On most pioneer units, the Yellow wire is the Constant 12 Volt (battery) and the Red wire is the Accessory 12 volt (switched).
Posted on Mar 14, 2011
I have a jvc kd-r45 it will not recall any pre set radio stations after it is switched off and demo mode kicks in every time i start it up. Tried reset any ideas?
I don't think you have the memory keep alive wire attached to a constant 12V+ source. This is why it is not keeping set stations and reverting back to demo more every time it is switched on. Usually the memory keep alive wire is yellow.
Jan 18, 2012 | JVC Car Audio & Video
My unit returns to demo mode everytime I restart my Chevy s-10 and I loos all the presets and clock settings
Make sure the yellow wire is going to a source that has 12v going to it when the key is turned off. The yellow wire controls the memory and needs a constant voltage source.
Sep 15, 2011 | JVC Car Audio & Video
Kenwood w-3537 how to turn off demo mode
To turn off the Demo mode you need to:
Press source button, then select stand by mode.
Using the FM/AM button select Demo display
To set the demo mode hold the source button for 2 seconds
it will switch from on and off.
If this doesn't help I have included a link of the manual, it's on page 25.
http://www.kenwood-electronics.co.uk/WebFiles/File/uk/download/Instruction%20Manuals/KDC/KDC-W3037_W3537_W4037.pdf
Jan 09, 2011 | Kenwood Car Audio & Video
Automatically goes to the demo mode on start-up
to turn off demo mode put radio into stand by were it is running demo mode and hold number 6 till it switches off. As for the key problem its the key that is making the key live connection on your model of car so this can not be changed. sorry
Apr 29, 2009 | Car Audio & Video
Stuck in demo mode. how do i change it?
Hello jayme84,
To cancel "DEMO" mode on the JVC:
Enter the PSM (personal settings mode) and turn DEMO off.
1) Press and hold "SEL" until the display changes.
2) Use the left/right rocker switch until "DEMO ON" is displayed.
3) Turn the volume knob to select "DEMO OFF".
4) Press "SEL" to exit.
Hope this helps.
Apr 28, 2009 | Car Audio & Video
How do i set the time and remove the demo setting
Hello again johnworley6,
To set the time and/or cancel the demo mode, you need to enter "PSM" mode. Do this by pressing and holding the "sel" button for 4 seconds. Use the left/right rocker switch to select the item. Turn the "volume" knob up/down to change the item. Press "sel" again the exit PSM mode.
So to turn demo mode off: 1) Press and hold "sel". 2) Press right until "demo" is displayed. 3) Turn volume knob until "demo off" is displayed. 4) press "sel" again to exit PSM.
To set the time: 1) Press and hold "sel". 2) Press right until "CLOCK H" is displayed. 3) Turn volume knob until correct hour is set. 4) Press right until "CLOCK M" is displayed. 5) Turn volume knob until correct minutes are set. 6) Press "sel" to exit PSM.
Hope this helps. If it does, please rate as "FixYa".
Apr 25, 2009 | Car Audio & Video
Pioneer DEH-P4000UB not turning off.
I thought the same thing but what is happening is when it turns off it is in demo mode and it looks like it's not off. When you hold in src it changes to something that says "USB/IPOD.. " scrolling. Press display and it turns demo mode off. Then it will turn on and off properly.
Jan 09, 2009 | Pioneer DEH-P4000UB CD Player
Stuck in demo
I had the same issue and was about to give up.
cleaning, key combos and such didn't work out.
Solved the dirty way, as described some comments above:
"Just took the faceplate from the "push-menu" button and hit it against a hard surface [not too hard but not too soft hits] and thats it, it worked again."
ah, the good manners!
Jun 07, 2008 | Aiwa CDC-X504MP CD Player
Kenwood KDC-MP635 STUCK IN DEMO MODE
Turn the unit onto standby then press and hold the menu button then scroll down to demo using the toggle switch on the right then press and hold the toggle switch for a few seconds and it will change to demo off. It's not too difficult but you are correct, it doesn't tell you correctly in the installation instructions.
Jan 25, 2008 | Kenwood KDC-MP635 CD Player
DEH-P670MP Display goes from regular to extra bright, then back
Your deck has "reverse mode" activated. To turn it off, just turn off the power by holding the source button. The press the preset "5" button. When you turn the deck back on, reverse mode should be disabled. (If this doesn't work, try the same procedure with button "6". One's for reverse mode, the other for demo mode, but I'm not sure I remember which is which).
Jul 01, 2007 | Pioneer Premier DEH-P670MP CD Player
Pioneer DEH-4300UB Car CD/ MP3 Player Logo
476 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
