I have a hard time getting it to scan anything. It doesn't seem to work but the laser light is on and it makes soundes like it registered the scan but no numbers pop up.
  • 27,725 Answers
The drivers for the scanner might have been corrupted
you might have to uninstall the printer/scanner restart your computer then reinstall the printer/scanner and its drivers
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options plus you can troubleshoot
lift the lid on your scanner lay the photo face down then select scan document/photo it will ask what format you want to scan it then it will ask where you want to save it browse select the file/folder where you want to save it (my pictures) most common
hope this helps don
Posted on Mar 14, 2011
I have a 2008 Chevy Trailblazer. Problem started with the air conditioner blowing hot air and when it does this, I noticed the temperature gauge doesn't register anything.
Hi Christy.
It sounds like your BCM, (Body Control Module) is failing, or your Connector/Connectors to your BCM could be at fault. They could be corroded, Damaged, burned, loose, and/or could possibly have bad wires on or going to the connectors. I would take it to a mechanic that you trust and have them check it for you. Do you have a check engine light on? Hope this helps.
Nov 04, 2016 | 2008 Chevrolet Trailblazer
Everytime my notebook gets started up it freezes about 45 seconds later
It seems alot of people have had similar issues with these PC's.
Sounds like it could be a virus or registry error. But could also be a hardware error. Does the machine run hot? If so, try cleaning the vents and running it on a hard, flat surface. If that doesn't work I would try running an anti virus and/or anti malware program (in safe mode if that's on option) If that doesn't find anything, then you could try reinstalling the O/S.
Is there a recovery partition on the hard drive?
If none of the above works, then it is probably a hardware issue, hard drive or RAM error, something like that.
Mar 16, 2012 | Sylvania Computers & Internet
I'm running it on a laptop with windows vista home edition. All worked well until I dropped it. The pc doesn't detect it anymore, the blue lights don't flicker anymore, and it makes a ticking...
Dropping a hard drive is never a good thing. They are very sensitive moving parts inside a hard drive and they don't take well to falls. It sounds to me like there was some damage when you dropped it and it may no longer work properly. The clicking is the hard drive trying to read the data and failing. You mentioned that it seemed to come back to life a couple of times...try and recover the data if you can, and contact Western Digital Tech support if you are still under warranty. Hope that helps!
Aug 25, 2011 | Western Digital My Book Essential Edition...
My 1994 Camry idling problem.? It's a 1994 Camry V4, 2.2 L. After i changed the head gasket, my car idle became too slow. It seems like it doesn't have the cold engine starting idling anymore, i...
If it runs fine and the idle is the only problem you could try idling it up some with the idle set screw on the throttle body it sounds like it may be a little bit out of time those toyotas have a fine lins on the timing.
Jul 03, 2011 | 1994 Toyota Camry
Was just given a 1995 RCA Remote Monitor XS Stereo Colortrak TV. Seems to work fine, but remote doesn't. Can change channels manually, but after about Channel 5, it skips most on the way up to 99. How...
Just about any One For All remote control will work with this unit and any other remote controlled devices you may have.
This sounds like when doing the channel scan the scan was interrupted and therefore went from the channels it had already found to the ones that were at the high end of the register. Also, when you are in the setting menu, you need to specify the input as either cable or antenna, preferably cable, which will also scan each channel from 2 through 125. Please let me know if there is more information you would like and I hope you have found this helpful.
Jul 01, 2011 | Televison & Video
My sony dvd slv-300p blue light progressive scan light is on and i cant do anything ?
my sony dvd vcr combo has a progressive scan flashing light when plugged in. i put a vcr in and now it's stuck. none of the buttons seem to be working. it is making a clicking sound inside on machine. how can i get this thing to work again?
Jan 23, 2011 | Sony SLV-D300P DVD Player/VCR
Canon Laser Class 8500
Wrong category, this printer doesn have a fax function.
Nov 23, 2007 | Samsung CLP-500N Laser Printer
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
