Question about Danby DHCC6020 Dehumidifier
Unit is not collection water is bucket.. - Danby DHCC6020 Dehumidifier
  • Danby Master
  • 43,501 Answers
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Posted on Mar 22, 2011
I have a Haier dehumidifier, model DE45A-L and recently it has started leaking water and not collecting in the bucket. When we dump the water out it seems to just come from everywhere in the front. The...
There may have been a failure in the area where water is collected and directed to the bucket but also check to determine whether the bucket is reinstalling correctly after it has been emptied.
Sep 02, 2014 | Dehumidifiers
The full bucket light stays on yet no water is collected
if water full light stays on the compressor wont start and remove water from air , investigate why light stays on ? is bucket really full? is sensor knocked out of its fragile holder ? is bucket all the way inside machine so that sensor is connected ?
Jul 04, 2014 | Kenmore 54501 Dehumidifier
My dehumidifier's red light illuminates seconds after turning on the unit even though no water has been collected... it is unusable
Shannon, this is also an indication that the water collection bucket was not reinstalled properly. Turn the unit OFF, unplug the unit and remove the water collection bucket. While it's out, check the top of the bucket for a float valve (if yours is so equipped). As it may be stuck in the UP position. If so, jiggle the arm of the float valve to make it return to the down position. When you reinstall the bucket, be sure that it fit's "squarely" from top to bottom into the bucket holder and makes firm contact with the bucket safety removal switch on the back wall of the bucket holder. The bucket should not tilt down at the bottom when installed properly.
Lug the unit in and turn is ON. If all was checked and done correctly, the bucket full light should not illuminate.
Hope this helped you and thanks for choosing FixYa.
Sep 08, 2011 | Dehumidifiers
It says it is full and there is no water in there and it will not run because it thinks it is full]
Usually when this occurs, the unit "thinks it's full', because either the water collection bucket is not installed properly or the float valve (if you model has one) in the top of the bucket, is stuck in the "UP' position.
Turn the unit OFF & unplug it. Remove the water collection bucket and check for the float valve. If it's stuck in the UP position, jiggle the handle to make it return to the DOWN position. Then reinstall the bucket, being sure that it fits into it's holder "squarely" from top to bottom and is making firm contact with the Bucket Safety Removal Switch on the rear wall of the bucket holder. If installed properly, the bottom of the bucket should not tilt down at all. Plug the unit in and turn it ON. If everything was done correctly, the Full Bucket Light should not illuminate.
Aug 11, 2011 | Fedders R6DH45X Dehumidifier
Dehumidier works fine! However it leaks water even when the bucket is empty and started. Some water collects in bucket but most runs out on the floor. What is wrong?
The drain hole of drain tube, that transports water to the bucket is clogged.
To solve this problem, do the following:
Remove the water collection bucket and look up inside the bucket holder cavity. You will see either a drain hole or small tubing that drains the water into the bucket. Using an appropriately sized, 18" long, plastic Zip Tie, carefully insert the tip of Zip Tie into the hole or tubing. Continue to push it in until you reach a bend in the tubing. You will need to gingerly work the Zip Tie past this bend, until it either bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip Tie back out while rotating (twisting) it. This will breakup any clogs. As you reach the inserted end of the Zip Tie, be prepared, as some water may follow. Reinstall the bucket, plug the unit in and turn the Master ON/OFF Switch to ON. Set the humidity extraction level to 35% or Maximum if you have a manually controlled unit. Allow the unit to run, while you monitor it for any leakage.
NOTE: If you don't have a Zip Tie, you may use something similar ( i.e.a long pipe cleaner), but NO wire coat hangers
I hope this helps you solve the problem.
Jul 09, 2011 | Haier HD656E Dehumidifier
Just stopped working. When I turn unit on the power light comes on for about 2 seconds then goes off, nothing else happens. Any ideas?
It may simply be that the water collection bucket is not installed properly or the air intake filter is clogged.
Turn the Master ON/OFF Switch to OFF and unplug the unit from the wall outlet. Remove the air intake filter and clean it, if necessary. While the unit is unplugged and OFF, remove the water collection bucket and reinstall it. Making sure that the bucket fits "squarely" from top to bottom, in the bucket holder. It must make contact with the bucket safety removal switch, to activate the unit. Once you have reinstalled the bucket, make sure the bottom of the bucket is not tilting downward.
If you cleaned the filter, be sure it is totally dry, before reinstalling it. Then plug the unit back in, turn the Master ON/OFF Switch to ON and if everything was done correctly, the unit should start and run. DO NOT OPERATE THE UNIT, WITHOUT THE AIR INTAKE FILTER INSTALLED.
Hope this helped you to troubleshoot and solve the problem.
Jun 18, 2011 | Maytag Dehumidifiers
Water is not collecting properly in the bucket. I ran it for an entire day, and only about half an inch collected in the bucket while more than that amount of water leaked from the unit. There was a puddle...
heatman101
Apr 30, 2011 | Soleus 8649045FB Dehumidifier
Water leaks out of the bottom of the humidifier and the bucket does not fill up. The water just leaks out.
Based upon my experience with the same problem on my Kenmore 54701 last summer: The condensate water collects in a plastic pan below the coils. This pan has a single drain hole where the water flows down into the bucket. When I suddenly found water puddling on the floor instead of in the bucket, I opened up the unit, and I found that the collection pan's drain hole had become blocked by "bioslime". I cleaned out the goo from the drain hole, and the problem was solved.
Apr 22, 2010 | Kenmore 54701 Dehumidifier
No water collecting, unit running
the collector base under the tubes just collects water and drips it through a hole into the water bucket. there must be a loose hose(if it has one) or the base collector or bucket has a crack, as they usually are plastic. also if the unit is sitting on a very uneven floor this will happen
Jul 24, 2009 | Goldstar DH3010B Dehumidifier
Unit runs but water collects on the floor
The drain hole within the unit is most likely plugged up with an accumulation of crud. (Common problem). Depending on the make/model, you may be able to access that drain hole by simply removing the collection bucket. If not, then unplug the unit and remove the housing to gain access to the internal drain.
Jun 19, 2009 | Goldstar DH304 Dehumidifier
Danby DHCC6020 Dehumidifier Logo
107 people viewed this question
Top Danby Dehumidifiers Experts
Bill Long
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
