Question about Powermax Visonic Powermax+ Extreme Kit - Wireless Security Alarm
How do I connect visonic powermax pro to a Redcare secure 2
The kit includes a line plug with 2 screws for wires. assuming it is a phone wire that is to be used which of the 4 phone wires should be inserted into the line plug.
Usually the green and red, but best way to find out is pop the phone port box where you land line comes into the house, and check to see what wires are used. Some countries use 2 wire systems others use 4
Feb 16, 2015 | Visonic Security Systems Visonic POWERMAX...
How can i reset visonic Powermax express
how can i reset poxermax system if i forget master installer code ?
Jan 24, 2011 | Visonic Powermax Express Home Alarm Kit
I bought a secureLinc Wireless Home Security System. I'm having trouble setting up the "Home" feature. Is their a phone number I can call for support?
Here are the manufacturer lines of securelinc:
VISONIC LTD. (ISRAEL): P.O.B 22020 TEL-AVIV 61220 ISRAEL. PHONE: (972-3) 645-6789, FAX: (972-3) 645-6788
VISONIC INC. (U.S.A.): 10 NORTHWOOD DRIVE, BLOOMFIELD CT. 06002-1911. PHONE: (860) 243-0833, (800) 223-0020. FAX: (860) 242-8094
VISONIC LTD. (UK): FRASER ROAD, PRIORY BUSINESS PARK, BEDFORD MK44 3WH. PHONE: (0870) 730-0800 FAX: (0870) 730-0801
INTERNET: www.visonic.com
Hope it helps
Cheers
TeaCii
If you own website, add live support almost free
Real security guard to watch your cctv for $1/day
Apr 16, 2010 | Visonic INC Smarthome SecureLinc Wireless...
I have a Visonic Powermax and we have it install in our Church however the member that installed it no longer attends our Church and I need to reset the Installer code so that I can conduct tests and add...
I found this on the "Home Securty Store" website:
To reset the Visonic Powermax installers code to 9999
The User Code 1 will also be reset to 1111
Unplug the ac transformer and disconnect the main units back up battery then flip it over and find the pins labeled "DEF" on the circuit board. Lower right side of circuit board.
You'll need to short the two pins closest to the bottom of the powermax+ unit labeled DEF,a metal paper clip works just fine.
Have someone plug in the ac transformer while holding the short.Hold this for 10 seconds then unplug the transformer before removing the short.
Remove the short and turn the unit over, plug it back in and try 9999 as the Installer's Code.
(If the reset did not work the first time, try again making sure the short between the def points remains closed during the 10 second power up.)
Jan 22, 2009 | Computers & Internet
Powermax Visonic Powermax+ Extreme Kit - Wireless Security Alarm Logo
137 people viewed this question
Top Powermax Home Security Experts
Lawrence Oravetz
Are you a Powermax Home Security Expert? Answer questions, earn points and help others
