Wont empty and wont spin. - Washing Machines
    Brigadier General:
  • 6,277 Answers
Sorry, you do not say the make and model of your particular machine but in this case it doesn't actually matter as many will not go on to spin if they are not able to empty completely. I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and the motor is unable to empty the machine.
Here are my complete, general pre-typed guidance notes for checking both the filter and the motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 14, 2011
E20
does it do every thing else just will not empty might be the pump either blocked or broken if there is water to a sertain point in the washer it wont spin it has to empty so far befor it spins off hope this helps ivan
Sep 24, 2012 | Frigidaire Affinity ATF7000E Front Load...
It wont spin out
if it doesnt go into spin brushes in main motor could b stuck or worn check also outlet tube and waste pipe not blocked if it goes into spin but doesnt empty check spin pump not jammed but most common fault brushes in main motorworn
Mar 18, 2012 | Whirlpool Washing Machines
Zanussi z918 washing machine wont empty or spin although the pump seems to work
if the pump seems to work, check outlet hose for blockage/check pump filter as well
Dec 09, 2011 | Zanussi Washing Machines
Wont spin
Probably down to the water not emptying from the machine in the empty cycle and the machine won't spin because there's still water in the drum. If this is the case, the root of the problem is almost certainly a blocked filter, restricting the draining of the water and not allowing it all to pump out in time during the empty cycle. You probably need to find and clean your filter.
Feb 02, 2010 | Washing Machines
Drum wont turn on the spin cycle, it's ok on a
if its pumped all water out and wont spin sound like your motor brushes are worn.
Oct 16, 2009 | Zanussi ZWF1230W Front Load Washer
I have a Legacy SAV405DEWW machine wont run
I just had the same problem. The washer would stop about 2/3 through the spin cycle and not start again. Replaced the timer. That did NOT solve the problem.
Jul 20, 2009 | Maytag Legacy Series Top Load Washer
Changed brushes still wont fast spin and empty water
Let me ask you who told you to change the brushes... Im curious!
Jun 10, 2009 | Washing Machines
Matag top load washer wont spin or empty
Set the timer for manually for the spin cycle and trun it on.
If it does not spin replace the lid switch.
Mar 14, 2009 | Maytag Washing Machines
Washer wont empty and spin
BAD LIDSWITCH OR THE SCREWS ON THE LEFT SIDE HINGE ARE LOOSE CAUSING THE LID TO BOW UP APPLY PRESSURE ON THE LID TO GET IT TO START SPINNING IF IT DOES TIGHTEN THE SCREWS ON THE HINGE IF IT DOESN'T THE LIDSWITCH NEEDS TO BE REPLACED
May 30, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
Top Washing Machines Experts
