I have a Soyo mtsytpt3227ab flat screen tv. When i turn it on, it has sound but no picture. Tried it in a totally dark room, and no backlight. When checking it out, i noticed that the power board "clicks" once when u turn power on. No bad caps or other visible problems on power board or the inverter board. Is the click normal? Or should i replace the power board? All i have to test with is a multi meter, and dont even know where to begin checking voltage. Help!!!
  • 3 more comments
  • austin r Mar 15, 2011
    My nxt question is tht, if it is the power board, my p.b. # is a r4041203023. The only power board is a (r4041203025). Is that the correct board? Thx
    Thx. Will try new power board.
  • austin r Nov 23, 2011
    replaced backlight inverter board, now have a backlight but no video or picture at all. t-con board?
  • 10,594 Answers
It seems back light inverter board is defective in said symptoms because you get sound in tv but no picture. Please point strong flash light at tv screen to observe faint image, if image is there then replace back light inverter board that is available with shopjimmy.com
And if no faint image found then power supply board would be defective and it is available with shopjimmy.com
Hope these info will help.
Thanks.
Posted on Mar 14, 2011
  • Shahid Electronics
    Shahid Electronics Mar 15, 2011
    Yes, it would be similar/ compatible power board. You may please install new power board.
    Thanks.
Sound no picture
inverter board issue.
Feb 22, 2017 | LG Televison & Video
I have had my 55" Vision for a year and a half. Today I was watching a movie and the picture went dark and audio stayed on. If I turned the TV off and then back on it would light up with no Vision logo...
Sounds like you have a backlight problem. To verify this, turn on the set and dim the lights in the room. Take a bright flashlight and shine it on the screen. If you see a faint picture, you either have a back inverter or a bad backlight bulb.
Sep 02, 2013 | Vizio GV42L 42 in. LCD Television
Can the lamp be replaced for a Polaroid TLX03210B
You likely have a LCD set there which may likely use a back light inside to light the image, get the room as dark as you can and with a flashlight illuminate the screen from a angle, with set on if you can see the faint image on the screen of the program you have a Backlight issue'
1. Voltage not there or not being switched on for backlight.
2. Actual back light bad.
If the image can be seen with a flashlight one of the above is the issue and your "picture will appear very faintly" also suggests this.
Dec 18, 2012 | Polaroid Televison & Video
Lcd flat panel, no picture
Most LCD sets use backlights---in a dark room with a flashlight look carefully with set on to see if VERY faint images can or cannot be seen--if see them the backlights are not on or not powered up.,
Nov 05, 2012 | Toshiba Televison & Video
JVC LT-52P789 no picture just sound
If this is an LCD TV, show a flash light on the screen from a safe distance. If you can see picture, it means the backlights have gone off and the TV might need servicing.
Aug 23, 2012 | JVC LT Televison & Video
I have an AVOL 55' LCD tv and when I turn it on there is no picture. I put a DVD in and played it and I can hear sound but when it's the tv by itself there is no picture or sound at all. Ple
tried to look at the darkened room if their is a white screen, it could be the t-con board. if totally black screen, it could be the inverter board was busted or the screen back light itself.
Aug 02, 2012 | Televison & Video
My 42" hd Sanyo flat
chances are your backlight inverter circuit has failed, repaired one a few months back with the same problem. To verify this, take the tv in a dark room. plug it in and take a bright\ flash light and shine it on the screen. turn the set on, you should see either the screen saver or video from your source. If this is the case, your inverter is at fault. Depending on your model, your backlight inverter is built onto your power supply board so you will have to replace the power supply/inverter board. Not hard to do, you can do it yourself with care.
Sep 23, 2011 | Sanyo 42 in. LCD TV
My Westinghouse SK-32H540S pictures shuts off after 10 seconds. the sound stays on but no picture. is it the troubleshoot? i tried unpluging everything and repluging it and still the same thing happens...
This problems are the tv 1 or 2 long LCD inverter boards are dead.These 1 or 2 long LCD inverter boards provide the tv LCD screen pannel a backlight to produce a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those refurbishes 1 or 2 long LCD inverter boards for the replacement.
Mar 24, 2011 | Westinghouse SK-32H540S 32 in. LCD TV
Sound but no picture
Most likely you have an inverter problem. The inverter powers the backlights so that the picture can be seen. You can try holding a flashlight close to the front of the screen in a dark room and if you can see any trace of a picture, the backlights are not lit. This can be a pretty hot circuit to work with. Have a shop check it out for you. Thanks for using fixya.
Jan 12, 2010 | Televison & Video
Televison & Video Logo
190 people viewed this question
Top Televison & Video Experts
Electro Med Services...
