Question about Garden
I need to know if I can get a gear for a 1984 Duracraft bench band saw. M>N> BBS 412 4" depth cut 12 throat cut..This is the small one of the 2 gears.
  • 4088 Answers
SOURCE: I just opened a 12"
As this is an unused machine, take it back to Sears for replacement (Sears used to have a 'satisfaction-guaranteed' policy--hope they still do)! It appears that the frame is for a smaller saw blade than 12". Good luck!
Posted on Nov 29, 2010
puertobori
  • 7733 Answers
SOURCE: I have a 107624-02 saw. Motor of saw runs but
Try at eReplacementParts.com : Power Tool Parts and Tool Repair Diagrams
also look at ToolPartsDirect.com - Your Tool Repair Supply Store.
Posted on Jan 18, 2011
rowdy45176
  • 2176 Answers
SOURCE: how to take apart the gear box on a milwaukee deep
unplug tool, remove the handle assembly making note of the wiring, turn the tool over and remove the rear pulley under that you will find 2 torx drive screws remove them and then gently tap the housing to start to remove the gear assembly. remove the 4 bolts holding the gearcase to the motor housing and pull apart, when apart you can finish tapping and the lower gear along with the top one will "jump out" Let me know if you still have any problems
Posted on Jan 26, 2011
  • 2239 Answers
SOURCE: INQUIRY: I HAVE A MCCULLUCH
Run it on a 25-1 fuel oil mix with good quaility two stroke oil, use a non fling chain oil in the chain oil tank to lubricate the cutting chain
Posted on Apr 11, 2011
  • 2239 Answers
SOURCE: The chain saw cuts through
Cutting in a curve is either the cutters are longer on one side than the other, or the bar rails are badly worn, more so on one side.
Posted on Jul 12, 2011
How do I replace a band saw blade in a Duracraft bbs 412?
Here's a step by step process http://bandsawblog.com/how-do-you-change-a-band-saw-blade/
Oct 17, 2014 | Saws
Tighting blade for duracraft bench bandsaw model bbs412 variable speed
You mean tensioning the blade? I suggest you to read the blogs on bandsawblog.com. They have blogs about band saw blade tensioning, tracking and tuning up band saw.
Sep 28, 2014 | Saws
Duracraft Bandsaw 20412 Manual
Is it a three wheeled band saw? It's probably the same with older craftsman 3 wheeled bandsaws, do some cross referencing.
Aug 29, 2014 | Saws
How to put together the drive shaft assembly on a Grob 4V - 36 vertical band saw
I suggest you to check the operators manual. If in case you don't have the manual, contact Grob's technical assistance or you can get a manual available online. I got old manuals from bandsawmanuals.com but they don't have available manual for 4v-36 . By the way, I like the solid build saws from Grob, what's your usual cutting workload? I have 7x12 band saw with a Haltbar band saw blade from sawblade.com ,I cut structural steel, channel, angle, tube, plate, pipe, round bar,
Dec 27, 2013 | Grob 4V-36 - 36" Throat Band Saw
Need a manual for duracraft bench band saw vs-312
Try checking with www.bandsawmanuals.com . They're providing free manuals for different models and brands of band saw.
Mar 07, 2013 | Saws
What is the 'throat' on the scroll saw?
the throat refers to the distance between the blade and the rear frame of the saw. this distance allows the woodworker to know how big a piece of wood can be cut by the saw. industrial scroll saws can have throats up to 30 inches
Jan 28, 2013 | Saws
How long is the band saw blade on model 113.24330C
I can't find a Sears model 113.24330C but there is a 113.243300 so hopfully part of the last 0 got worn off. That model is a 12" bench top band saw that uses a 1/4 X 80-inch blade.
Mar 19, 2012 | Craftsman Saws
I just opened a 12"
Nov 28, 2010 | Craftsman Garden
Changing blade on bench saw
unplug tool, remove the throat plate and you should have 2 wrenches that were supplied with the tool, one is to hold the spindle and other for hex nut, generally these are standard threads, use gloves so as not to get cut by the teeth. Let me know if you need more assistance and if so please furnish the brand and model number.
Sep 22, 2010 | Saws
Throat capacity
Throat Capacity is the distance between the saw's blade and frame. The throat determines the maximum width of the saw's cutting capacity. Saws with wide throats allow you to make wider straight cuts and scroll larger pieces without obstruction from the frame.
Aug 27, 2008 | Delta Machinery 14" Band Saw with 1HP...
Garden Logo
63 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
