Question about Insignia 42" LCD Flat-Panel HDTV
The volume is stuck at 100 (max) and when I go to the menu button it just rotates through all of the options. When I try to reduce the volume, it blinks fast between 99/100 without an reduction.
  • 1,940 Answers
It sounds like the a switch on the TV is stuck. This may just be a stuck button, or a bad Switch Board. Try moving the buttons around to stop the problem. If this doesn't work, you will probably need to replace the Switch Board.
Posted on Mar 14, 2011
What do you do when Alcatel one touch tablet is stuck on sprint yellow screen and won't do anything
I'm not familiar with that specific tablet, but all Android devices have a way to enter a recovery mode menu that allow you to clear the cache or do a full factory reset. First, try the 'clear cache' option. If that doesn't work, you'll have to do a full factory reset (and you'll lose all of your apps and data).
  • Turn off your tablet all the way.
  • Then press and hold Volume Up + Power button until you see the Recovery Mode menu.
  • From menu on your screen choose option "clear cache" or "delete cache" by using Volume buttons to scroll and Power button to confirm.
  • Try to restart your tablet. If it still doesn't work, then do the same thing again, but this time...
  • From menu on your screen choose option "wipe data/factory reset" by using Volume buttons to scroll and Power button to confirm.
  • After that select option "Yes -- delete all user data", and confirm that.
May 04, 2016 | Tablets & eReaders
Volume button sticks and raises to max level and cannot be turned down.
It sounds from your description there is a fault in the audio section electronics rather than with the button.
Dec 06, 2015 | Car Audio & Video
Onkyo tx-ds656 stand by power light comes on volume control knob rotates to max but display or unit wont start
Try factory reset: while holding the(CD) button on front panel,press (POWER) button.
After "Clear" is displayed the unit should be back to its factory default. :) If this dont work for you take the unit to be checked by service . :)
Jan 24, 2014 | Onkyo TX-DS656 Receiver
Volume is at MAX every time i start my Samsung TV LCD LA37A550P1R
Check your manual for resetting the TV to 'Factory Default'. I have heard of this happening before. It may need you to press a combination of buttons on your remote. Usually you have to be pressing the buttons in sequence with the TV in standby, then wait for a service menu to appear. Look through this menu for the words 'Factory Reset'. It may be in a sub menu. The TV may well switch itself back off and then on again. At which point your problem should have gone away.
Dec 21, 2013 | Dell W1700 17 in. HD-Ready LCD Television
Tv volume stuck on max, volume + signal stuck, button is fine.
The problem is on the board with the controls----if remote receiver is not on same board disconnect that board--if it is unsolder the vol and channel buttons--the front buttons have priority over the remote--buttons will look fine but the switch under each will be your problem---better hope it is as only other cause is a microprocessor gone mad.
If you have a Ohm meter I can tell you how to prove this--going to have to get at the buttons--if you want to prove it is or is not a issue with the micro switches you are going to have to unsolder or test them.
SD TECH
Apr 26, 2012 | Televison & Video
The screen stopped rotating. what can I do?
You will have to do a factory reset, which will restore the default settings on your device.
1) With the device powered off, press and hold the Volume Up and Power buttons at the same time.
2) When you see the Samsung logo, release the Power button, but continue to hold Volume Up until the recovery screen appears.
3) Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
4) Press Volume Up to continue.
Mar 14, 2011 | Samsung Galaxy Tab Tablet PC
Center channel volume decreases in surround mode, making it difficult to hear conversation in movies. How to i increase center channel volume?
There should be a setup button or menu button...when in setup go to surround settings and change to desired volume
Dec 27, 2010 | Sony STR-DE598 Receiver
How do I unlock the volume control?
Zenith Electronics Corporation is a long-time leader in electronic enterainment products.
Aug 24, 2008 | Zenith C27A24T 27" TV
Controls
Press and hold the menu button (either on the remote or the display itself). Other forums have said you only have to hold it down for 10 seconds, but that isn't accurate. I had to hold my menu down for about 30-45 seconds to unlock the OSD.
Aug 25, 2007 | Dell W1700 17 in. HD-Ready LCD Television
Insignia 42" LCD Flat-Panel HDTV Logo
365 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
