Question about Maxi-Cosi Mico Infant Car Seat
Hi can I get the shoulder belt pads andcrotch belt pad as I am missing them
  • andrea blake Mar 14, 2011
    hi which country are you in please?
  • 396 Answers
Here is Maxi-Cosi's phone number. Have your model number and date of manufacture ready when
you call.
1-800-951-4113. Mon-Thur 7AM-6PM and Fri 7AM - 4:30PM
Posted on Mar 15, 2011
What should the shoulders on my suit be doing? I know it sounds silly but I think the shoulder pads in my suit are too big but the assistant told me that it is part of the fashionable design.
Obviously I haven't seen your specific suit so I can only answer with general guidelines but your shoulder pads shouldn't come out any wider than your shoulders.
If you stand sideways against a wall, the shoulder pad shouldn't touch the wall before your arm does.
Generally you should trust your gut instinct and if it doesn't feel right when you look in the mirror, you won't be comfortable in it.
Feb 14, 2013 | Clothing
Why do Footballers wear shoulder pads?
The shoulder pads to protect the payer from collisions with other players and they are probably the most intricate pieces of equipment that the players wear. Shoulder pads consist of a hard plastic shell with foam padding underneath. The pads fit over the shoulders and the chest and rib area, and are secured with various snaps and buckles. Shoulder pads are what give football players their "broad-shouldered" look.
Jan 14, 2013 | Football
How do you put the footmuff on the maxi cosi carseat?
Open the carseat harness and have the carseat in front of you so you\'re looking at the seat. Slide the shoulder harness pads down the length of the harness and off over the harness clips. Unzip the footmuff and place it into the seat and thread the harness through the holes at shoulder and crotch position. Replace the shoulder harness pads onto the harness. You can now place your baby in, do up the harness + tension correctly, then zip up the footmuff to keep baby cosy.
If you\'re still using the headhugger/lumbar support wedge this can be used underneath the footmuff.
Nov 06, 2012 | Maxi-Cosi CabrioFix (Black Reflection)...
Adjusting quinny buzz harness for a newborn
Hi
This is not feedback we've heard before! Remember there are two places to adjust the harness - underneath the shoulder harness pads and at the waist position. To adjust underneath shoulder harness pads you need to undo the popper from the harness, slide the pad down the length of the harness and adjustment point revealed to make harness smaller.
Jan 03, 2012 | Quinny Buzz Jogger
How do you move the straps for a bigger child
Hi
Undo the popper on the shoulder harness pad. Slide the pad down the length of the shoulder harness strap.
Unhook the metal D ring.
Feed the short length, low down anchor point back in behind the seat fabric. Bring the longer length, higher up anchor point out at the desired height.
Re-attach the D ring. Adjust the harness straps accordingly.
Slide harness pad back up shoulder harness and re-attach popper.
Sep 11, 2011 | Quinny Buzz Three Wheel Stroller
Need to remove the cover from a britax eclipse si..how
Press and hold down the harness release button. With your other hand below the chest pads, pull the shoulder straps forward as far as possible. With the Eclipse Si fully reclined, open the seat-belt guard at the back of the shell. Pull the yoke out from behind the seat and unhook both shoulder straps. Pull the cover from the top of the seat so that you can see the slots in the seat shell. Pull each shoulder strap and chest pad strap forward and towards the centre of the shell, easing the metal tab and straps through the slot. Then thread them through to the front of the cover. Unfasten the buckle and remove the comfort pad. Gently pull the cover off the seat, easing the shoulder straps, chest pads, harness buckle and adjuster strap through the slots in the cover.
By Geraldine Thorne
Feb 24, 2011 | Britax Eclipse Si - Chantilly
I am trying to refit the straps on a britax car seat (For children 9-18kg) but I cannot get the straps attached to shoulder pads positioned so they are on top of the shoulder straps when coming through the...
hi here is a manual for the eclipse version i have a first class and mine fit the same way so assume they all fit like this, if this doesnt work i will try to help further I know how to do it but cant explain in words
click here anyway worth a try
http://www.britax.co.uk/media/142518/11.pdf
Feb 07, 2011 | Baby Gear
How do you push the caliber back so the pads will fit
Loosen the bleeder valve assembly a few turns while applying pressure to the pads. A small amount of brake fluid will probably spray out as the pads move, so have a pan or a rag ready. As soon as the pads hit the edges of the caliper, retighten the valve, being careful not to let the pads move.
Nov 08, 2009 | 2006 Kia Spectra
Removing seat cover maxi cosi priorifix
To be able to remove the seat cover from your seat you have to 'unhook' the seat belts at the back of the seat:
First extend the seat belt to the maximum length.
Then put the seat at the maximum recline.
At the back of the seat-'shell' you will then see a metal hook that hold the shoulder straps: unhook and pull forward.
Reassembly is just the reverse.
A few more tips when removing the cover from a PrioriFix: take care not to damage the white extruded foam when pulling the belts forward and when taking off the cover. When the foam is not protected by the padding it may easily snap.
The seat padding is cold wash only and no spin-dry, otherwise the seams may loosen.
Please don't hesitate to use the contact form at http://www.babycare.nl if you need any further assistance.
With kind regards,
Babycare.nl Sales Desk,
Erwin de Raad
Jun 21, 2009 | Maxi-Cosi CabrioFix (Black Reflection)...
How to fit the quinny sleeping bag?
If you unstrap the harness at the shoulder pads, you can then pull the whole strap through sleeping bag and push the bottom part through the hole on the seat, then reclip through shoulder pads.
Oct 16, 2008 | Quinny Buzz Jogger
Maxi-Cosi Mico Infant Car Seat Logo
427 people viewed this question
Top Maxi-Cosi Baby Gear Experts
Dorel UK
Dorel UK
Kristy Richie
Kristy Richie
Level 1 Expert
Bear Mark
Bear Mark
Are you a Maxi-Cosi Baby Gear Expert? Answer questions, earn points and help others
