Question about HP LaserJet P3005 Printer
LaserJet P3005dn has a blank control panel display
  • 113 Answers
We have had a lot of problems with this printer the main board seems to go frequently, HP repaired two under warranty, but they failed a couple of months later. if yours is still under warranty send it back to HP asap. If not cut your losses and get a different model I'm afraid
Posted on Mar 14, 2011
This problem is very danger but don't tech the blank sponge b/s the image transition is low you can fix the toner senses adjusted then fix the problem
Posted on Nov 24, 2012
  • mereegeta042
    mereegeta042 Nov 24, 2012
    this problem is very danger but don't tech the blank sponge b/s the image transition is low you can fix the toner senses adjusted then fix the problem
What does this mean on my HP LaserJet P3005dn Printer, error 49.c02
This error is usually caused by out of date firmware. The printer is getting commands from a program like Acrobat it does not understand. Click thi slink to go to support page for your printer. Drivers Software Firmware for HP LaserJet P3005 Printer series Download the current firmware, I suggest the easy firmware update which is the first option, and then run that file.
May 20, 2014 | HP LaserJet P3005dn Printer
Error 49.2F9D
the printer CB(control Bord) is detected change control Bord ather wise tern off and on
Jun 05, 2012 | HP LaserJet P3005dn Printer
Menu window is blank on hp laserjet p3005dn. No memory check, nothing. Multiple recycles of power... sometimes Data light come on, sometimes Ready light. sometimes all three. Menu window stays blank.
This seems like a bad formatter board problem. There has been a known issue with the formatter board for this printer. You may want to make sure if you are covered under warrenty. You could also try reseating all the connections on the board. Its located behind the right hand side cover.
Dec 27, 2010 | HP LaserJet P3005n Printer
HP Laserjet P3005dn printer makes a loud grinding sound while printing. Prints OK, but users are annoyed by the sound
Replace the fuser and the fuser drive gear. When you order the fuser make sure that they include the gear.
Nov 22, 2010 | HP LaserJet P3005dn Printer
My hp laserjet 3005 dn displays error 52. problem?
hello
i will help you solve the issue --
your printer is this one, correct ? HP LaserJet P3005dn Printer - model p/n Q7815A
review some information to verify where the issue comes from
manual = http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/bpl05339/bpl05339.pdf
user guide = http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00774394/c00774394.pdf
Nov 02, 2010 | HP LaserJet P3005 Printer
Hplaserjet p3005dn blank display
Is it blank and no back light?
Either way the display might have went dead/bad. These printers are not that old. I would call HP support to have it repaired.
Apr 19, 2010 | HP LaserJet P3005n Printer
Hp LJ P3005DN hangs during boot. Sometimes during
It would not surprice me if you have a defective formatter board. This is a very commen problem with this machine. Officialy you have to replace the formatterboard but there is also an other way to fix it. Put the formatterboard in to a preheated oven 190 degrees Celcius (350 fahrenheit) for 8 minutes. 8 out of 10 times it works fine fine and the machine is up and running. If this does not work you still can replace the formatterboard.
Dec 30, 2009 | HP LaserJet P3005dn Printer
What is MemTest failure replace DIMM0 on an HP Laserjet P3005dn?
It says to replace the DIMM, but you really need to replace the formatter. We run into this all the time with this model of printer.
Feb 13, 2008 | HP LaserJet P3005dn Printer
HP LaserJet P3005 Printer Logo
420 people viewed this question
Seeker5211
Seeker5211
