Question about Cycling
So i dropped my moped in a 5 foot hole of water and now it wont run can someone tell me what i should do?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,508 Answers
First take it out of the water ( lol)
drain the fuel and oils and replace, dry out the air filter,drain and clean the carby , remove the spark plug, kick it over many times with ignition off. put new plug in and try to start it. do this as soon as possible before internal corrosion takes place, If it starts and runs and is a 4 stroke engine change the oil again.
might need to blow compressed air into the ignition switch and handle switches, to dry them out
Posted on Mar 15, 2011
Hello ive just gotten home from work and noticed my kymco wont go over 30mph now it shakes while riding and is really loud and laggy when rides baring in mind its a 125cc any ideas?
Hi, Michael there are few things you need to look at when trying to troubleshoot your scooter for power loss. How does it sound? If you run it wide open throttle when warmed up, does it peak out? or stutter? is it loud, or very quite the symptoms can help decide what to try. When you are going full throttle, the engine should get to a high RPM and sound smooth here are a few things you should look for:
1. Plugging air intake- will start well cold, but be hard to warm up and not reach top speed. The engine will stutter at high RPM.
2. Open air intake- to much air or air cleaner is disconnected- engine will not have power at high speed, make vacuum cleaner sound. Acts like it's running out of gas. ( sounds almost the same as a dirty carburetor.)
3. Plugged exhaust port the engine sounds and runs good, but has no power. Slow to take off. Same as plugged muffler, but if the muffler is plugged you get a very smooth exhaust note at idle. Humming instead of pop pop pop pop.
4. Fouled spark plug- backfire. If you get backfire, pretty good chance the plug is fouled.
5. On models with belts, the gear ratio drops as the belt gets thinner (most hondas have belts).
6. On a moped with high mileage, the belt will cause slow top end speed if worn thin.
7. If you have a bike with chain drive in an oil bath and you "OVERFILL" the oil amount in the chaincase, that makes for slow running as it requires too much power to turn the oil.
8. If your engine does not rev up well and stutters or sputters, like when it is cold with the choke on, the engine is running too rich. (too much fuel).
9. Is the air filter soaked with oil? Clean with soap and water!
10. Is the air opening in the airbox plugged? Very common for a spider or mud wasp to build a nest in one of the intake holes.
11. On some scooters it is common to get a leaf stuck in the intake port of the airbox, causing a 10mph drop in top speed.
12. Don't try to adjust the screws on the side of the carb to get lean or rich, as they are for the idle circuit only.
13. The idle air screw should be about 1 1/2 turns out on most scooters.
14. Say your engine revs but kind of wheezes or acts like it runs out of gas it is common to have a buildup of hard carbon on the inside diameter of the hole in the main and pilot jets, and it must be carefully removed.
15. If your moped does not idle the pilot jet is likely plugged.
16. Anytime a moped has not been used for 1 year or more, and still has the same fuel in it, good chance you will need to clean the jets.
17. The poor quality of today's gasoline has made this a rather steady bet.
18. Mopeds are affected more than most vehicles because the small size hole the jet requires is easily plugged, even by thick oily fuel, or water.
19. Drain your carb once in awhile! Most have a screw of some type at the bottom (where the drain needs to be) of the carb.
20. Make sure the air boot to the airbox is not on wrong, kinked, hard and shrunken.
21. Don't oil the air filter if you got the stutters.
22. On some scooters, you can leave one snap loose on the airbox lid to allow it to crack open, to get full rpm.
23. "WARNING" too much lean out on the gas, and since the fuel cools the piston, the piston can "MELT"
24. Still slow? Check the muffler tip. Make sure no carbon buildup is inside the tip, stick something in as far as it will go.
25. Common on some scooters to have the tip bent over on a curb, then carbon up solid. common of all types to have the whole muffler plug.
26. When you have the muffler off, is it heavy?
27. Can you get the baffle out to see if the holes are plugged?
28. Check the exhaust port on the cylinder.
29. If you can't see all the way into the piston, use a mirror and a flashlight to make sure the piston is ok and the port is not plugged where it meets the piston.
30. Common on all models to plug here, Just scrape it out so the hole is full size again.
31. Don't worry about the small film on the inside of the port, I am talking about a very thin film that forms a wall in the exhaust port right next to the piston.
32. A 1 1/2 inch hole can be reduced to the size of a pea...... With a thin film of carbon.
33. If you can see the piston ok, it's not the problem.
34. If you are in doubt regarding your exhaust pipe being plugged, put your hand behind the muffler to see how much pressure is expelled. compare to another bike.
35. It should blow pretty good and have a distinct pop pop pop pop sound while idling, not a steady humming.
For more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Troubleshooting
ScooterCommunity
KYMCO INK 125 Service Manual
https://www.oemmotorparts.com/oem2.asp?M=kymco
KYMCO INK 125 Owner Manual
May 30, 2017 | Kymco Motorcycles
When the cars in park and i give it gas, there's a chatter coming from the engine when the RPM's drop back down after letting foot off the gas. Can someone help me out with this please?
here's what i would do.
Make a diagram of the serpentine belt routing then remove the serpentine belt. Start the engine and try to duplicate the symptom. Only run the engine for a few minutes as the water pump will not be driven by the belt unless you have the DOHC 3.0 liter.
If the noise is gone than you can concentrate on the accessories (alternator, water pump, a/c compressor, p/s pump, idler pulley, tensioner, etc).
If the noise is still present reinstall the serpentine belt.
If it sounds like a tinny rattle than it could be an exhaust heat shield. When the engine is cold raise and properly support the vehicle and start tapping the exhaust to see if you can find anything loose.
If there is nothing loose than I would suggest having your local shop take a listen. A trained ear will be able to quickly tell what the noise is and some possible causes.
Hope that helps. let me know if you have any questions or what you or your shop finds out. Thanks for using Fixya.com!
Mar 13, 2012 | Cars & Trucks
Got a kinroad 50cc scooter wont start got fuel got spark can anyone help?
SEE IF IT WILL START ON A FEW DROPS OF GAS, IF SO YOU NEED TO CHECK FUEL DELIVERY ,DRAIN OR CLEAN THE CARB MAY HAVE WATER IN IT OR IT MAY BE THE SOLENOID ON THE CARB THAT SHUTS THE FUEL OFF IT SHOULD CLICK WHEN YOU TURN THE KEY ON... JAY FL
Feb 02, 2012 | RTO 50cc Moped Scooter
I have water in rear passinger foot well can you help
Sounds like someone left the door half opened or the window down just a little or your back window seal is leaking.
Jan 21, 2011 | 2003 Volkswagen Passat
2003 VW Golf 1.9 GTI Turbo Diesel
Hi,if you want to make sure its your airflow meter,get a buddy with the same car and just test his in your car..(A.F.M is situated on the left,behind your battery is the filter box,the pipe connecting to the box is where it sits)
Mar 01, 2010 | 2003 Volkswagen GTI
Moped wont start
is there a spark a decent one if not try changing plugs if still no spark it could only be the cdi,coil and magneto get back to me buddy
Sep 13, 2009 | 2005 Tomos Se 125 F
Kenmore 385 model Automatic Button Hole Apparatus Jams Thread?
Practice and practice some more! Use the same fabric and interfacing as your project and a NEW needle (the correct needle) This is for the Sears Kenmore 385 automatic button hole maker. Make sure you pull the bobbin thread through the Guide Block - it is that simple. Make sure you pull your thread to the back of the machine though the presser foot slot - the correct presser foot. Account for both thread tails before starting to sew. Keep thread tails to the back of the machine 4-5", insert fabric under presser foot keeping thread tails clear. Mark button hole and sew.
Mar 30, 2009 | Kenmore Drop-In Bobbin 505S-21BH...
Digger how to
Hammer rebar into the ground to create pathways for water. Grab a hose and soak the ground to soften it before using the post hole digger. Wait until the water has had a chance to soak in. Raise the post hole digger and drop it, jaws open, into the ground. The jaws will cut into the ground and soften it even more for removal. Continue to use the weight of the post hole digger for the hard work, circling around the edge of the hole. Drop the digger down with force once you've loosened up a circle of soil. Open the handles to grab a bite of earth in the jaws and lift it out. Continue with Steps until you've removed all the loose soil, making a hole 1 foot in diameter.
Aug 27, 2008 | Woodland International Chipper Knife for...
Cycling Logo
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
