Question about Kenmore 62832 / 62834 / 62839 Bottom Freezer Refrigerator
I'm not sure which one I have, but purchased my approx. 2 yr. old Kenmore bottom freezer refrigerator from a trusted contractor doing some work in my home. I have a problem with the left produce bin... everything freezes. I have the humidity set to low, and it's set to the lowest cold setting. This problem makes that drawer basically unusable. I've thrown away a lot of food. Is there a setting I need to know about? The fridge setting is at 3. I LOVE this refrigerator, excep for this one little problem.
  • Kenmore Master
  • 2,306 Answers
Cold air from freezer blows into refrigerator compartment right behind that tray. Freezes stuff in that tray. Pizpoor design. Known issue. With GE refrigerators also of same design. That kenmore most likely was build by GE. GE/Kenmore deny the issue but thousands of posts online about it. No solution. Sorry. Good luck.
Posted on May 19, 2017
the dr
  • 447 Answers
SOURCE: kenmore 73503 not cold enough
Is the fan in the freezer working?? Is there Ice on the rear panel in the freezer?
Posted on Dec 04, 2007
  • 31 Answers
SOURCE: Kenmore Elite bottom freezer drawer won't shut
Has something fallen behind the drawer, and is preventing it from sliding back all the way? Remove the drawer by pulling it all the way out and lift it up and out. Look for anything that has fallen back there.
Posted on Jan 07, 2009
  • 1524 Answers
SOURCE: My refrigerator freezes my food solid
Replace cold control
Posted on May 03, 2009
  • 145 Answers
SOURCE: My Kenmore Elite refrigerator keeps freezing the food!
Replace your thermostat and will work like new again
Posted on Jun 07, 2009
  • 4070 Answers
SOURCE: I have a brand new kenmore elit bottom mount
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Posted on Sep 21, 2009
Bottom of Kenmore freezer vents icing up. Did test recommended weeks ago, replaced defrost timer. Worked fine for a few weeks and now is back to icing up and fridge not cool at all. Melted ice again with...
If the timer didn't fix your problem, and it sounds like it didn't, then there are 2 other components to a defrost system. The defrost heater, and the defrost thermostat. Both are located around evaporator. Back inside wall of freezer will have to be removed to access these parts. Thermostat will be clipped near top of evaporator coil. Heater will be near bottom of coil.
Sep 15, 2017 | Refrigerators
Compressor will not come on.
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Jul 11, 2010 | Maytag MBF2556HEW / MBF2556HEB /...
My refrigerator and freezer aren't working!
Apr 19, 2010 | Kenmore 64802 Top Freezer Refrigerator
2 yr old kenmore refrigerator with bottom freezer. Refrigerator not cooling. Freezer is
This unit has an electronic speed control on the condensor fan which controls the cooling in the refrigerator unit. The electronic control failed which allowed all items to work as intended just without a high enough fan speed to cool the refer unit.
Aug 23, 2009 | Kenmore Refrigerators
4 year old amana refidge bottom freezer died on me yesterday. Is their a 5 yr waaranty
You would have to look at your original warranty paperwork to be sure but I would doubt it. Most of Amana's refrigerators only come with a one year warranty. Even if it is a five year warranty you will most likely have to show a proof of purchase and pay a service fee for the tech to come out.
Jul 29, 2009 | Amana ABL2222FES Stainless Steel Bottom...
Water in bottom of refrigerator under vegetable bins.
there should be a tray that guides water from freezer to a drain located in the fridge section normally held with one screw . take it off and unclog drain ( use a vacuum to **** out sludge) clean tray/guide and mount back on. make sure all moisture is cleaned out after drain is cleared.
Jun 20, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water build up in the freezer
When your refrigerator defrost the condensation has no place to exit to because of a restriction in the drain and that could be water that has turned into ice or possiably a food partical or foreign object. Defrost it compleatly by leaving freezer door open for aprox. an hour at least make sure ref is level front to back an d you should not have this problem anymore. Please rate me and let me know if this helped. Thanks
May 22, 2009 | Kenmore 73262 / 73264 / 73269 Top Freezer...
Kenmore Elite - Interior water dispenser stopped working
Frozen water tank, some of these had an insulation kit that will prevent this from happening. Make sure you have water coming out of valve to tank, if so it will probley be a frozen tank. Make sure fridge is on factory settings. If it doesnt thaw out, check into the frozen tank kit...
Jul 14, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore Fridge- all lights blinking
sorry to say this but the mother board has took a hit replace this and all will be well
Dec 31, 2007 | Kenmore 53642 / 53644 Side by Side...
9 yr.old GE profile top/bottom refrigerator
There could be many things that cause these symptons. Defrost timer not working, bad door seals, or lack of freon. It may be less expensive to replace the frige than repair it.
Oct 20, 2007 | Kenmore 18.3 cu. ft. Top Freezer...
Kenmore 62832 / 62834 / 62839 Bottom Freezer Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
