Question about Toshiba 61A61 61" Rear Projection Television
Toshiba tv 61a61 screen all red - Toshiba 61A61 61" Rear Projection Television
  • 1,476 Answers
Jeffjo7,
Your unit is 10 years old and more than likely needs the drives adjusted on the blue and green guns. I have a tip at http://www.fixya.com/support/r6814105-adjust_screen_drive_crt_projection_tvs
which explains the process to adjust the screen drives for the best picture.
Thanks for using FixYa and for the great rating.
hardrocko
Posted on Mar 14, 2011
4 Suggested Answers
  • 1894 Answers
SOURCE: Toshiba no picture
then your optical section has fault.
Posted on Mar 17, 2008
maklean
  • 1665 Answers
SOURCE: lines across screen
I think its an electronic interference problem
Posted on Mar 25, 2008
  • 210 Answers
SOURCE: I need to order a new Protective screen for a
Try CHS charles hydes & son web site
Posted on Oct 25, 2009
I have the Toshiba 61A61 TV. I am not sure what exactly happened, but when the TV was on, suddenly the picuter went black. I still receive the normal sound, but can't get any picture (totally black). I...
Check all connections?Unplug,replug the cable box about an hour later let it upgrade it software.The projection lamp has not been replaced in this tv the last 1 1/2 or 2 years?The tv been on and watches at lest 4 or 5 hours a day?Yes,than the projection lamp life is over.Require a new projection lamp.
Sep 03, 2010 | Toshiba 61A61 61" Rear Projection...
Lines across screen
Mar 25, 2008 | Toshiba 61A61 61" Rear Projection...
Toshiba no picture
Mar 17, 2008 | Toshiba 61A61 61" Rear Projection...
Tshow me how replace ir sensor on toshiba tv 61a61
http://www.fixdevice.com/smanuals/file/31211.html
Please find above your service and repair manual, inside it shows you everything you need to know to accomplish this.
It is NOT a difficult task. BUT you will need a soldering iron on some sub chassis. Others use a plug and Wire, and one simply unscrews the old, unplugs from the sub board and replace. Other ones are soldered to a sub board, and need to be removed with a soldering iron. Either way it's a doddle. (Easy to do)
Aug 25, 2010 | Toshiba 61A61 61" Rear Projection...
I have a toshiba 61a61 that wont turn on but i unplug it and the red light turns on off and the same when i plug it in dont know what i can be
standby relay not latching in, may be a safety precaution due to a temp sensor or other power board protection, or the relay might just be failing !
Hope this help's as when you take it to the shop they might not charge you too much if they think you know what it might be !
Sep 22, 2009 | Toshiba 61A61 61" Rear Projection...
Stay on power light but no light or sound
No picture, no sound and all the fuses are ok, means there are no shorted components in the circuit, more than likely the tv is not generating horizontal drive to produce and feed hv to the crt and no b+ for the audio circuit. The tv is big enough to keep and repair if you are cosidering a repair estimated around 400dlls. I think the problem would be located in the deflection board.
Sep 09, 2009 | Toshiba 61A61 61" Rear Projection...
61A61 TV IS WILL ONLY PICK UP ONE CHANNEL #66 AND NOT CABLE INPUT
Cable companies are slowly but surely reducing the channels you can get without a digital box, which they will supply. You will need to cantact them and rent a HD cable box or converter from them that will work with your displays built-in tuner. However, if your display is HD compatible, then I would just asked your cable company for and non-DVR HD cabe box and connect it to your display with component cables....
May 30, 2009 | Toshiba 61A61 61" Rear Projection...
Conversion
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 29, 2007 | Toshiba 61A61 61" Rear Projection...
Toshiba 61A61 61" Rear Projection Television Logo
111 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
