Question about Poulan Garden
On my gti 19t the two fuel line from the tank where do they go
Weed Eater GTI 19T
If it's the one that comes 'out' of the primer bulb it is the return line that goes in the fuel tank.
Aug 07, 2014 | Poulan/Weed Eater No. Te475 952711797 17"...
Replaced the fuel line on my WEEDEATER GTI 17 XP grass trimmer. Having trouble bleeding the fuel line. Is there a poecial technique? I filled the gas tank and let the gas flow through the line until I...
The fuel line is self bleeding, if there is a lot of air in the pipe there must be a hole in the pipe or the filter is not completlt submerged in the fuel.
Aug 01, 2011 | Garden
Does anyone have a diagram showing the fuel line replacement positions for a Weed Eater GTI 52? I'm having a hard time making sure I have the right lines to the right connections on the carburetor and...
Just remember the primer pulls fuel from the carb and dumps back to the tank, the shorter connection on the primer is the suction side so this conects to the carb, the shorter conection on the primer is the pressure side so this goes back to the tank.
Jun 01, 2011 | Garden
Does gti 85 have fuel filter where is it?
your fuel filter is connected to the fuel pump. the fuel pump is inside the gas tank.
Mar 22, 2010 | 1985 Volkswagen GTI
2003 vw gti fuel tank hole
they do leak kits in auto parts stores. if it's not that bad it should work. other wise, est. $200 gas tank, 3hours labor.
Feb 21, 2010 | 2003 Volkswagen GTI
I have a 1994 golg gti and after running for a few kms engine stops suddenly after a while starts again
What is a golg gti i know its a good German mad car but i havent heard of that one .
But no matter Check the fuel tank breather as 9 times out of 10 the breather is blocked and dont let the air in when you are taking the petrol out ...also check ORget the pump checked out as its in the fuel tank and its a high pressure pump and if you are loosing power in the pump then you wont GO and have to wait till the power comes back..
Let me know how you go Ron
Oct 07, 2009 | 1995 Volkswagen GTI
Lumpy acelleration
Use a fuel liquid fuel system cleaner for lines and injectors you have a partial blockage in the fuel system causing your car to not to receive enough fuel during hard acceleration. Raz,...
Aug 21, 2009 | 1995 Volkswagen Golf
Dont find location of furl pump on racer gti
Yes, it is all part of the pump and fuel sender unit that is normally mounted through the top of the fuel tank.
Apr 12, 2009 | Daewoo Lanos Cars & Trucks
Garden Logo
374 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
