I have a 51 inches big screen TYPE # AC120-60HZ-200W and after watching TV for about a hours or less the TV begins to flicker and the picture gets hard to see, so we shut it off. And after waiting awhile and turning it back on the problem is gone, until it heats up again. Someone had told me that they think it is possiblity the Lamp over heating, is this problem fixable. The TV is a Samsung 2004 model - # HLN5065WX/XAA and Serial # 31DX802147E -its lamp code is BP96-00224C(P). I guess what I need to know is this TV worth fixing and were do I get the part to fix it or should I just send it to the junk pile.
  • 4,234 Answers
First look in the back and be sure that the fan is turning and that the airway is clear. There are airflow sensors inside that may be shutting down the set because they are dirty and can not detect the flow correctly or the lamp may just be getting too hot. Normally there is an indication on the front of the set with a flashing code. Look for that and try to match the code with one listed in the owner's manual.
Keep us posted.
Dan
Posted on Aug 01, 2008
Snow on screen with no picture.loud noise on audio
42" Vizio TV flickering strobing easy way to repair VW42L ...
? 2:49
https://www.youtube.com/watch?v=Qba7_YHnXwM
Dec 2, 2013 - Uploaded by ozzysslayer
42" Vizio TV flickering strobing easy way to repair VW42L HDTV10A LCD TV ... EASY How to Fix Samsung LCD TV Flashing Flickering Screen!Missing: vp422hdtv10a ‎snow
Vizio Replacement Boards - ecoustics.com
www.ecoustics.com > ... > Plasma & LCD TV Forum
Apr 15, 2009 - I have a vizio p42hdtv10A that just went into a black screen. .... I have a Vizio VP422 HDTV10A that will not stay on or show a picture. I removed ... Vizio vp422 hdtv10a
Dec 20, 2011
May 13, 2011
More results from www.ecoustics.com
Dec 30, 2015 | Vizio VP422HDTV10A 42 inch 720p LCD HDTV
The problem is a shaky picture with a static line that's vertical when watching regular TV. This problem does not happen when not watching in HD through our Myth TV (DVR). Closed captioning does not...
Regular TV, you mean by the aerial and internal tuner, if it is like that, then it is a problem with the TV tuner board.
If by regular TV you mean an external TV box, then the TV box is faulty or you have a cable or ferquency problem.
Sep 13, 2008 | Televison & Video
Samsung tv model LNS3241DX flickers
I'm not sure of a jumper wire to cut, but one of the first things is to clean out the dust that has accumulated on the electronics. You can blow out the back with compressed air or disassemble the TV case and dust it. Sometimes a layer of dust can cause excessive heat to build and shut off any type of overload circuit. Good luck!
Dec 18, 2013 | Samsung Flat Panel 32-inch 720p 60hz...
My Plaroid FLM-3201 LCD Television takes 4 hours to come on.
The power supply could be on the way to failing completely.
Aug 26, 2017 | Polaroid FLM-3201 Television
My RCA television is making a ticking sound and the screen is flickering is this worth fixing the TV is about 15 yrs old
U had this tv for 15 years but u watches or used the tv less than 8 hours everydays?Yes,than this tv set have alot of life left in it like another 5-7 years more.Yes,if the repair cost is around $500 or less.Because u will not get that kind of screen "61 size for $500 dollars.
Aug 12, 2011 | RCA D61W136D 61 in. TV/DVD Combo
Flickering screen and lining-out on top inch at first
This sounds like tiling. are you using a cable box?
May 07, 2010 | Vizio GV42L 42 in. LCD Television
Screen Flicker then tv shuts off
please re solder  first all parts specially in hot area, and observe if problem still occur, then next is replace filter capacitor. observe also too hot parts and check for change value resistor.
Feb 25, 2010 | GE D52GW12 52" Rear Projection HDTV-Ready...
Sony-kp51ws510 picture turns to a blue hue with flickering colors
hello there this is an easy fix unplug the tv and take the back of the set, once inside the set you will see 3 coloured bulbs and a big mirror in the back theses over time get dusty and dirty and if you smoke it can get really bad you simply just need to clean the bulbs and the mirror with computer screen wipes or some sort of window cleaner be sure not to get everything wet inside this should sort if for you nice and clear again!
Thanks For Using FixYa
Feb 07, 2009 | Sony KP-51WS510 51" Rear Projection...
DLP TV starts to loose picture after 1 - 1/2 hours of use
This tv has a 3 board video path. Analog main pcb --->Digital main pcb --->DMD pcb. see which inputs have the problem to narrow it down. if only some inputs, suspect analog board. if everything flickers(all inputs and menu), suspect the dmd or engine. you can see the lamp shine out the back. if the lamp is flickering, suspect lamp or ballast.
Nov 22, 2008 | Samsung HLN5065W 50" Rear Projection...
Televison & Video Logo
125 people viewed this question
Top Televison & Video Experts
