Question about Dryers
Frigidaire gallery dryer glgr642as2 spins but "thumps" ones each turn. I opened the top and took the front off. Belt is on an in the tensonier.pulley. I don't see anything loose.. any suggustions
  • Dryers Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Posted on Mar 14, 2011
I have a 2012 top loading frigidaire gallery washer. It recently started making a loud thumping noise during the wash cycle. When it spins out it smells like burnt rubber. Any ideas? Thanks
There is a rubber belt between the motor and the rotating cylinder.
If it is frayed, then part of the belt is hitting something during the "wash" cycle, and rubbing much faster during the "spin" cycle.
Replace the belt.
Aug 27, 2015 | Frigidaire Washing Machines
Frigidaire gallery stackable dryer with a thumping sound
POSSIBLE BAD ROLLERS, BAD DRUM GLIDES, WORN BELT, DAMAGED BELT TENSIONER? AND BAD FELTS ON THE DRUM ITSELF
Feb 25, 2015 | Frigidaire Dryers
Frigidaire Dryer thumps while turning, even with nothing in it. What's wrong.
The roller on the belt tensioner needs to be replaced. The top & the front of the dryer has to be removed to gain access to it. HINT replace the belt also when replacing the roller
Apr 03, 2010 | Dryers
Frigidaire was tub makes loud thump noise during spin cycle....
Need more information to make an accurate diagnosis, try removing the front panel (two screws at bottom) and visually check first the belt (all the way around) and then the springs that hold the tub suspended.
I would bet on the belt.
Quentin
Jul 22, 2009 | Frigidaire FEX831CS Top Load Stacked...
Loud thumping noise in Frigidaire model # FDE336RES2
You have to remove the top lid. Then remove the front panel. Then remove the belt and drum.
Your problem is a bad rear drum support assembly.
Remember to unplug the dryer.
Mar 27, 2009 | Frigidaire FGR341AC Electric Dryer
Drum not spinning
Pretty easy fix. start by popping the top
Once you get that up then remove the front. The rear hatch gives access to the idler assembly, look in there to see the status of the belt before popping the top. The bumping could have been from a bad st of glides on front or a bad bearing on back. Impossible to tell till ya give it a look see.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 06, 2009 | Frigidaire FDE336RE Dryer
GE Dryer DVL 223GB1WW
To access these dryers you open the door and look up at the 12 oclock position and their will either be 2 or 4 screws holding down the top. These must be removed and then you can get the top to come up(or off on newer models). Once you have the top up you can get to the screws which hold the front on (2). Then you simply remove the front and get it out of your way. On these dryers there is a friendly rear hatch to help you replace the idler. As far as the thump tha could be from anything. Once you get the dryer apart you should be able to locate and remedy the problem.
Dec 22, 2008 | GE DBVH512EFWW Dryer
Dryers Logo
216 people viewed this question
Top Dryers Experts
