Rev works auto mode does not,sesors are clear.when paper is istalled (auto mode) it does not respond.please help.
  • 1,915 Answers
Most likely the sensor that detects when you put paper in has failed. That is why the manual mode works but auto does not. If the unit has an manual forward you will probably find this the easiest, though less convinient way to deal with the issue.
Posted on Mar 14, 2011
Why doesn't OfficeMax OM99732 shredder work on Auto?
My shredder would not sense paper being inserted and the sensor could not be cleaned. So "Auto" no longer worked but the manual reverse DID work. I opened the thing up, reversed the polarity on the red and black wires on the connector for the main drive motor and VOILA!!! I can use my shredder in manual mode by switching it to REV. Be mindful that this keeps the motor running until it is switched off. This can heat the motor and cause failure so I limit my shredding to 60 seconds then give it a rest so it will cool down. Also there is no emergency reverse so watch your fingers and neck ties.
Dec 17, 2012 | Office Equipment & Supplies
How do I get the copier count on the Panasonic 150A?
Press auto/photo key, paper tray key, and one key sequentially to get into F mode. Press 7 and you will see F7. press start or okay the total count is under C02. Press auto/photo and clear/stop key to exit service mode. Hope this helps
Jul 18, 2011 | Panasonic DP-150A Copier
I have olympia cash register cm812 it says :paper: on screen nothing else works please help
Make sure paper is loaded in printer, press the clear button.
If still problem try reset.
Key to PGM mode, disconnect power, hold CLEAR & 7, connect power. Should be ok.
Dec 02, 2010 | Computers & Internet
Paper jam in Pixma MP810
Here is a good help tool on eHelp.
http://www.ehow.com/how_113761_clear-printer-paper.html
I hope this helps you out, if not please respond to this post and I will try to help you further.
Sep 01, 2009 | Canon Office Equipment & Supplies
Canon error code 6000 in mx308
please help me. i have canon print mx308. the have paper jams. paper has the full out from print. how i can finish the problems?
Jul 25, 2009 | Canon Pixma MP450 All-In-One InkJet...
Help me with a code reset panasonic fp7713
Press paper tray, zoom down key, and #1 keys simultaneously. "F1" displayed. press 8, start,then 09, start. DV will run auto for 3 min. hit stop/clear. F7-22 to clear PM count.Press stop/clear until F1 displayed. Press paper tray, zoom down, and stop/clear to exit maintenance mode.
Sep 08, 2008 | Panasonic FP-7735 Black and White Copier
Error code in E studio 150
Hello! I did it and it worked perfectly.
I entered the SIM mode : CLear - Auto- Clear - Auto- then I pressed 14 -Start- Clear and then , the machine automatically warmed up and came to ready...Please, How can I be a copier Tech? I'm so eager to learn that. LET ME KNOW SO I CAN HELP OTHERS. THANKS SO MUCH...
Feb 19, 2008 | Toshiba e-Studio150 Copier
Paper Jam
Remove all the paper from the paper tray so that nothing gets sucked up in there while you're working. Hit the cancel button a few times until the screen clears itself and goes back to the "Print", "Copy", "Scan" option screen.
On your computer, if the printer option screen is up (depending on what kind of computer you have, a small screen might pop up to tell you the print progress), hit cancel or clear on any of the lines that say "Paper jam", if there are any.
The next time you print something, only put as many pieces of paper in the feed as you need to print. This should eliminate a lot of the chance of actually getting a paper jam.
Please respond again if this didn't help. I'm not sitting in front of my own computer right now, so I might not be following the same steps that I usually take.
Feb 02, 2008 | HP Photosmart C4280 Aio Printer
147 people viewed this question
jasbo
jasbo
