Question about Dryers
Kenmore Electric Dryer Series 80
Interior light no longer works. Replaced bulb and still does not work.
  • 481 Answers
It could be the light bulb socket itself or the door switch.
Posted on Aug 01, 2008
Light pilot light on kenmore 80 series gas dryer
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 24, 2010 | Kenmore Dryers
My Kenmore 80 Series dryer is no longer heating up? What part needs to be replaced??
Gas or Electric? If Gas it could be the gas valve isn't opening, this keeps the burner from lighting. If electric your heating element is most likely burned out.
Aug 03, 2010 | Kenmore 84052 Dryer
MY KENMORE 80 SERIES DRYER ISN'T HEATING
remove the entire exhaust vent and clean it thoroughly. Any build up of lint inside of it will cause the moister sensor in the dryer to shut down the burner or grid which ever you have, gas or electric
After cleaning it and it still does not work correctly the sensor is at fault and needs to be replaced
May 17, 2010 | Dryers
Dryer interior light and motor will not turn on
plug something else into the wall outlet to make sure you're getting power there and try changing the bulb.if there is power check the door switch,move the paddle in and out and you should hear a clicking sound,if you don't change out the door switch,also check the back of the dryer at the block where the power cord connects to the dryer and make sure you have power there.also is there a gfi plug anywhere near the dryer that might have to be reset,i've seen this,also i've come across whoever wired the outlet switched the hot wire and the neutral around so when the machine is plugged in the wiring isn't correct
Feb 04, 2010 | Kenmore 63942 Dryer
Kenmore 80 series dryer no work
bypass door switch , if that doesnt work and you have replaced start switch already. then i would unplug unit remove back panel and look for the blower housing , on the blower wheel housing or to the right should be a white thermostat with 2 wires going to it.round shaped and it mounts to the blower housing by pass it and it should work however dont leave it bypassed. hope this helps
Sep 19, 2009 | Kenmore 60832 / 60834
NO heat but runs, Kenmore 80 Series Dryer model# 110.66832500
i had the same issue and replaced the light bulb inside in the back of the dryer and now it kicks out heat. not sure if that acts like a fuse or needs to work to complete the circuit, but it works now.
Nov 27, 2008 | Kenmore 62802 Electric Dryer
Kenmore series 80 Gas Dryer: No heat
ck the thermo fuse then ck the gas valve for power and the igniter to see if its broken probley igniter if you dont see a glow comeing from it
Mar 18, 2008 | Dryers
Dryers Logo
203 people viewed this question
Top Dryers Experts
