Question about Dell Dimension 8200 PC Desktop
When I turn on the dell dimension 8200 the light on the power button does not turn green, it stays amber color blinking and the computer does not turn on, is it the power supply that is gone bad?
    Scholar:
  • 172 Answers
Check all below possibilties & see if it works.....
  1. GGGY diagnostic lights can indicate a bad motherboard, or possibly a hard drive failure.You could try opening the case, then remove and reseat all the power and data cables, cards and memory and see if the system bootsCheck for burnt/charred power connectors on the motherboard and for any capacitors with bulging tops or are leaking, the tops should be perfectly flat.
  2. Could you please check out if the you are not having a battery problem. This could be the source of all the trouble that you are having.
  3. do the fans and hard drives spin
Please rate & vote, if you like solution
Thanks
Sandeep
Posted on Mar 14, 2011
When I turn on the dell dimension 8200 the light on the power button does turns green and the computer does not turn on. It makes a lot of noise also.
Posted on Sep 10, 2012
  • 115 Answers
It's difficult to tell. If there is beeping then the order and types of beeps mean something. If there is no beeping then it is virtually impossible to tell what the issue could be. You may have to take it to a repair shop. Repair shops should give you a free estimate and tell you what the issue is.
Dell dimension 8200 help
A steady or Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Apr 09, 2014 | Dell Dimension 8200 PC Desktop
I have a Dell Dimension E521. When I cut the power on everything comes on including the monitor, but the monitor will stay black. It does say something about power save hit any button but the screen
A solid green light means the computer is operating normally.
A solid yellow light indicates the power supply is operating normally but the computer is not processing data.
This could mean there is a problem with the CPu or another component on the motherboard.
((A blinking yellow light indicates the power supply is receiving power from the wall, but not functioning properly.
This generally means the power supply itself is bad and should be tested or replaced.))
A blinking green light means the computer is in standby mode.
You should consider visiting Dell Support and downloading the manual for your
your Dell computer. So use the LED power light codes if your Dell computer has them.
hope this helps
Sep 10, 2012 | Dell Dimension E521 PC Desktop
Blinking amber light on the on/off button.
No light : The computer is turned off (S4, S5, or mechanical OFF)
Steady green :The computer is in a normal operating state
Blinking green : The computer is in a power-saving state (S1 or S3)
Blinking or solid amber See "Power Problems"
check power
Sep 06, 2011 | Dell Dimension 4300 PC Desktop
The start green light on our dell dimension 9100 is blinking amber. I can turn off the machine and back on but machine won't boot up. Any ideas? span.jajahWrapper { font-size:1em; color:#B11196;...
If you see the boot screen, then it is a problem with your operating system (windows)
If you do not see the boot screen, then it is the power supply or the motherboard isn't working.
If it turns green but you never see the screen come on, then it may be the video or the monitor.
If it does go directly to blinking amber, it is probabbly the power supply. It should only take a little while for a computer person to plug in another power supply and test it.
You can actually take a power supply out of someone elses computer and plug it in (don't even have to mount it in the computer)
Plug in the motherboard plug(s) and the hard drive only, then attempt to start.
If it does work, it is your power supply, if not then it is your motherboard.
Jan 24, 2010 | Dell Dimension 9100 PC Desktop
Can't boot up Dell 5100 Dimension, amber light flashes
When you mean the amber light, is that the blinking hard drive access light or the power light? Different cases have different colors on it. Mine has blue and green lights.
If you see the boot screen (bios) and then after it goes to boot, does it blink and hang?
This could be a simple operating system issue, hard drive or hardware/motherboard issue. If you could provide more information, that would help.
Jun 28, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Blinking amber light with green 4 light
If the power light is blinking amber, the computer is receiving electrical power, but an internal power problem might exist.
Try, unplugging the power cable from the pc, and reinsert it, if this does not help try a differnt power outlet, if this dont help, open the computer, take the power Molex conector out of the mother board and try turning it on, if this dont help, take out the Memory modules and reseat them, if this dont work you may want to ring up dell support.
Hope this helps!
Jun 15, 2009 | Dell Dimension 9100 PC Desktop
Computer will not turn on
  • Blinking Amber/yellow: Initial state of LED at power up.
    Indicates system has power, but the POWER_GOOD signal is not yet active.
    If the hard drive LED is off, it is probable that the power supply needs to be replaced.
    If the hard drive LED is on, it is probable that an onboard regulator or VRM has failed.
Apr 28, 2009 | Dell Dimension 4600 PC Desktop
Amber light on power button of Dell Dimension 4500
ok - the amber light of doom on a dell means one of two things - either your power supply is pooched - or your motherboard, If under warranty dell will send out a friendly tech to replace them - if not it will cost you a bit. get the price and consider if it worth upgrading instead. Contact your dell rep or dell tech support and see what they say
cheers Pete
Nov 30, 2008 | Dell Dimension 4500 PC Desktop
Dell Dimension 5100 Won't start up
Hi
First disconnecting the power cord and re-seat all connections (Keyboard, Mouse espercially). Connect up the power cord and try powering the PC.
To help you troubleshoot a problem, Dell Dimension 5100 has four diagnostic lights labeled "1," "2," "3," and "4" on the front panel. When the computer starts normally, the lights flash. After the computer starts, all four lights display solid green. If the computer malfunctions, the color and sequence of the lights identify the problem.
If the computer failed to start up check the diagnostic lights color and sequence and Check the link below for more info (Assuming you have another system that can access internet)
http://support.dell.com/support/edocs/systems/dim5100/en/sm/tshoot1.htm#wp1120147
Alternatively, contact Dell Support with the diagnostic lights color and sequence to raise a service call if the system if under warranty.
Mike
Mar 31, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 8200 PC Desktop Logo
271 people viewed this question
Alun Cox
