Question about Maytag Centennial 3.2 cu. ft. SuperSize Plus Top Load Washer
How do i clean the water hose filter - Maytag Centennial 3.2 cu. ft. SuperSize Plus Top Load Washer
  • 1,940 Answers
On the back of the Washer, you have your hot and cold water hoses that hook up to the Washer Water Inlet Control Valves. Shut the water off at the Main water valves in the wall. Disconnect the hoses from the Washer and check the filters inside the Water Inlet Control Valves.
Posted on Mar 14, 2011
Washed some dirty runners & 2 small rugs on Daily Wash; came up with error code 5E cleaned debris filter any idea where water hose mesh filter is?
Usually on the back where hoses are attached to it . inside hoses are screens . turn water off ,unscrew the hose and check , then put hose back on tight .
Feb 14, 2016 | Washing Machines
Tip
LG Washing machine IE error code Solutions
An IE error code will appear if the washer has not filled with water in approximately 8 minutes.
Are the water valves opened completely?
If an IE error code appears on the washer, check to make sure both hot and cold-water taps are open completely. After both valves have been opened, unplug the washer for 10 seconds and retry the wash cycle.
Are the inlet hose filters clogged?
There are filters on the inlet hose connections of the washing machine. They are intended to filter away mineral deposits from hard water and other debris from getting into the unit. If clogged, water will not flow through these filters into the washer. Turn off both the hot and cold water taps, disconnect the inlet hoses from the back of the washing machine, and clean the inlet filters gently but thoroughly.
Are the inlet hoses attached properly?
If the inlet hoses are not attached to the machine correctly, it will prevent proper water flow to the washer. Turn off the hot and cold water supply then disconnect and reconnect the inlet hoses. Ensure that they are threaded properly. After the hoses have been reconnected, open the water taps completely, check for leaks, and unplug the washer for 10 seconds and retry the wash cycle.
NOTE: The inlet filters are inside the hose connections on the back of the washer. Because of their small size, take care when removing and cleaning the inlet filters so that they do not break.
on Jun 02, 2011 | Washing Machines
How do I correct a 4E error?
try unpluging for 15mins re try
Apr 27, 2015 | Samsung Washing Machines
How do I clean the filter on the Novotronic W 310 Miele washing machine
Cleaning the fluff filter and pump
Check the fluff filter initially after 3 - 4 washes to ascertain how often it is likely to require cleaning. With normal cleaning approx. 2 litres of water run out.
If the drain outlet is clogged, more water will be retained in the machine (up to 25 litres).
Caution: if laundry has been washed at a high temperature,
water draining out of the machine will still be hot!
Take the (yellow) filter flap opener from behind the detergent drawer facia panel. Open the flap.
Place a dish under the drain fixture. Turn the fluff filter lid round 2 - 3
times. Do not take it right out.
With large volumes of water when the dish is full, screw the fluff filter back into position and empty the dish before repeating the procedure.
Once the flow of water ceases, remove the fluff filter completely and
clean it.
Remove any foreign bodies (e.g. buttons, coins, etc.) and fluff.
Turn the impeller by hand to check that it is free to rotate. Any foreign objects causing an obstruction should be removed.
Clean the inside of the fluff filter housing. Remove any deposits of lime scale and detergent or foreign bodies from the thread of the filter housing and filter unit (as these objects can cause a leakage
of water). Put the fluff filter back and screw it in firmly.
Cleaning and care
To clean the water inlet filters
The washing machine has two filters to protect the inlet valves. These filters should be checked every 6 months or so, or more often if there are frequent interruptions to the water supply.
To clean the filter in the union in the open end of the inlet hose:
First turn off the stopcock.
Unscrew the threaded union connecting the free end of the inlet hose to the stopcock.
Remove the rubber seal from the recess. Using pointed pliers, take hold of the plastic filter bar, remove the filter and clean.
Put the filter and seal back in the reverse order and reconnect the
hose. Turn on the stopcock and check the connection is watertight.
Inspect the inlet hose which is subjected to high pressure while the machine is in operation. The hose should be replaced if there are small cracks in the surface, or if it has been otherwise damaged.
If replacing the inlet hose only use a hose able to withstand pressure up to 70 bar. Miele's own hoses meet this requirement.
To clean the filter in the water inlet valve:
Using pliers, carefully loosen the ribbed plastic nut on the inlet valve,
and unscrew.
Use water pump pliers to withdraw the plastic filter by the bar.
Clean, put back and secure.
The two filters must be put back in place after cleaning.
Mar 08, 2015 | Miele W310 Front Load Washer
How do i get my filter out of my bush a127ldw washing machine got E03 error am working my way through your list but cant get filter out
Water inlet filters
On the tap part of your machine's water inlet
hose and at the ends of water inlet valves, there
are filters to prevent entrance of the dirt and
foreign materials in the water to the machine. If
the machine is unable to receive sufficient water
although your water tap is fully opened, these
filters should be cleaned.
x Remove the water inlet hose.
x Remove the filters found on the water inlet
valves by using a pincer and wash thoroughly
with a brush. (1)
x Clean the filters of the water inlet hoses
located on the tap side by removing manually
together with the seal. (2)
x After you clean the filters, you can fit them
the same way as you have removed them.
Pump filter
The pump filter system elongates the life of your
pump, which is used to drain the dirty water. It
prevents lint to enter the pump. Cleaning of your
pump filter in every 2-3 months is
recommended. To clean your pump filter:
x Open the kickplate's cover, by pulling the
handle. (2-A & 3-A)
x Before opening the filter cover,place a cup in
front of the filter cover to prevent flow of the
remaining water in the machine.
x Loosen the filter cover by rotating it counter
clockwise and drain the water. (4-A)
x Remove the foreign materials from the filter.
x Check for the rotation of the pump manually.
x After you have cleaned the pump, fit the filter
cover by rotating clockwise.
x Put the kickplate cover into place.
x Do not forget that if you do not fit in the filter
cover properly, it will leak water.
Jan 21, 2013 | Washing Machines
Explain erroe 4E
When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
1. Turn off the water source to the washing machine.
2. Unscrew the hose from the back of the washing machine.
3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
4. Push the filter back into place.
5. Screw the hose back onto the washing machine.
6. Turn on the faucet and make sure the connections are watertight.
Also, please check the following:
• Make sure the source water faucet is turned on.
• Check the water pressure.
Jun 05, 2012 | Samsung WF337AA Front Load Washer
Describe your 4E problem in samsung front load Problem
Thanks for using FixYa!!
Sep 19, 2010 | Samsung WF203ANW Front Load Washer
I have a samsung 7Kg J845 front load washing mechine, when i turn on, water not fills enough ( only water fills couple of seconds after stops flows. the error shows 4E, Then i clean up all mesh filters...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 08, 2010 | Samsung WF203ANW Front Load Washer
Filter needs cleaning as water does not empty
I was unable to locate your filter in your machine but if it would help after you clean the filter you could install an inline filter between the valve and the hose. This is an RV filter it just screws on like the hose.
http://www.flowpur.com/html/rv_filters.html
The FP12GKE shows just how easy it is. Any RV filter will work.
Aug 19, 2009 | Washing Machines
Cleaning bottom filter
You should be able to drain the water first using the small hose next to the filter knob. Sometimes the hose is plugged up, in which case you will spill water out the filter, or a better solution is to pull the washer forward a foot and a half, tip it back so the water goes to the back of the tub, then remove the filter, clean it, and reinstall.
Oct 03, 2008 | LG WM-2277HW Front Load Washer
Maytag Centennial 3.2 cu. ft. SuperSize Plus Top Load Washer Logo
197 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
