Question about Stoves 60" VULCAN RANGES GAS(CLICK HERE): 60XLFOUR OPEN BURNERS 36" GRIDDLE TOPTWO STANDARD OVENS Kitchen Range
6 burner 1 oven vulcan range burns low flame fron burners. I have another vulcan on the line that burns a strong flame. what can be done to the weak one?
bigg t
  • 640 Answers
SOURCE: Gas burners won't light
I would check the pilot orfices and the regulator on the unit.Seems like not enough gas pressure.Let me know
Posted on Dec 11, 2007
burzerko
  • 254 Answers
SOURCE: new gas range converted to propane
I think it sounds like one of two problems either the wrong orifaces were installed in the gas valves for the conversion or the pressure on the output side of the gas valve was not set correctly.
Posted on Jun 22, 2008
jyackle5
  • 8197 Answers
SOURCE: Coverting a Vulcan 260L commercial range to Propane
Yes you can convert to LP gas. go to this web site to get the parts.
http://www.vulcanhart.com/manuals/F-30536.pdf
Go to page 9 and look at parts # 57 - 60 that is the part you need to change. You need to know the sea level that you are at though so you get the right part.
Now if you go to page 8 you will find where it goes part # 53 thru 61
To order the parts go to this web site
http://www.vulcanhart.com/parts.cfm
If any ? please fill free to ask.
Posted on Dec 17, 2008
Maytag317
  • 1136 Answers
SOURCE: broiler works, oven settings - no flame, no heat.
Hi, it sounds like the oven ignitor might be bad. Remove the floor panel inside the oven and you will see the ignitor attached to the burner assembly. Turn the oven on and see if it glows. You can test the connection for the ignitor and see if it gets 120V to it. The most common problem with the gas oven is the ignitor. Most of the time, the ignitor glows but is not strong enough to open the gas valve.
Please let me know if this was helpfull or if I can assist you further.
Thanks
Vic
Posted on Jul 17, 2009
  • 42 Answers
SOURCE: Newhome stoves 600 SIDO oven ignites but flame stays low
your problem is the fsd ,iam a x gas service eng.
Posted on Sep 28, 2009
I have an old gas stove. No igniter.Lights with pilot light only. Stove top burners work fine.Oven does not ignite. The pilot lite is on.I smell no gas when I turn it on.
Pilot flame has to hit the thermocouple. If pilot is dory flame.will be weak and not reaching the thermocouple that tells the oven there is a flame and opens the burner. If the pilot is strong and no gas to burner than that thermocouple. ( 100% safely valve is worn out) replace that and you are good
Dec 30, 2017 | Kitchen Ranges
My oven will not ignite, what's the problem?
Hello there:
Bake igniter Usually when an oven won't bake, it's because the bake igniter is weak or burned out. The igniter is a small, round or rectangular device, that's about 1 inch by 4 to 8 inches. It's near the burner itself. The burner is the tube-type device the gas flows through before it's ignited. It has many small holes on the sides to let the gas, when ignited, form a long, low flame. If the igniter is weak, if it glows red but doesn't get hot enough, or if it's burned out, the gas doesn't flow to the burner and the burner won't ignite. If this is the problem, you may need to replace either the igniter or the gas safety valve. Usually the igniter is to blame. Other causes Other reasons that your oven may not bake are: The clock settings are incorrect (if you have timed baking or a self-cleaning oven). The thermostat is defective. The safety valve that prevents accidental gas flow is defective. The selector switch is defective.
Oct 09, 2010 | Whirlpool GS563LXSS - stainless Steel Gas...
Oven takes a long time to heat up.
Hello. To go 12 years without issues is excellent. Now however you will have to make a decision to repair or replace. Be sure to get a firm estimate before you repair and compare that to the cost of replacement.
here is what may be causing your problem:
  • The clock settings are incorrect (if you have timed baking or a self-cleaning oven).
  • The thermostat is defective.
  • The safety valve that prevents accidental gas flow is defective.
  • The selector switch is defective.
Aug 15, 2009 | Maytag MGR5750 Gas Kitchen Range
The oven gas does not come on? Top and Broiler does. Oven igniter does glow
If your oven won't bake, check these:
Bake igniter
Other causes
Jul 11, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Had no gas coming into the oven of my Viking 305. bought a new dual thermal valve and replaced it. now i have small flame on left burner and none on right. right after installation, flame was strong for...
Are the burners on top getting enough gas? Is there enough gas coming out of the wall? Did you purchase the correct dual valve? Is the orifice sizing correct? Make sure the holes are not plugged on the burners. And u should also check to see if your line has debris in it. Either unplug the holes or check the pressure out of the line in the wall. What makes you think the right one isn't getting enough gas? Could it be an ignitor? Anyways, the burners have a 5 yr warranty. Try replacing those. Good luck.
Apr 28, 2009 | Viking VDSC365-6B Dual Fuel (Electric and...
Low flame on gas top burner
Hello Husky!! We can help you get the correct parts to repair this wonderful range. You sin=mply need another burner head to be replaced. We have parts and will make sure we get this out to you asap so you get back up and running soon. How many burner heads would you like to order? Please call or email us asap and we'll get these parts right out to you. We look forward to working with you. 972-859-0929
Feb 01, 2009 | Stoves 60" VULCAN RANGES GAS(CLICK HERE):...
For caloric gas range, the bake function did not kick in after setting the temperature dail. Display window shows on but no gas burning. Temperature stays at 100 degrees.
if this helps please vote me a fix ya
Jul 18, 2008 | Kitchen Ranges
Amana oven won't turn on gas flame
Sounds like the oven ignitor has become too weak and needs replaced. When power is applied to an ignitor it builds up resistance in order for the gas valve to open and let gas flow to the burner. When they become weak this will not happen. If you notice a whiteish color on the ignitor or it doesn't have a strong full glow that is a sign of it going bad.
Nov 11, 2007 | Kitchen Ranges
Stoves 60" VULCAN RANGES GAS(CLICK HERE): 60XLFOUR OPEN BURNERS 36" GRIDDLE TOPTWO STANDARD OVENS Kitchen Range Logo
24 people viewed this question
Top Stoves Kitchen Ranges Experts
Paul Carew
Oloyede Monsuru
Tony Houde
Tony Houde
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
