Question about Timex Watches
I need to change the time from 24 hour clock to a 12 hour clock
  • 12 Answers
SOURCE: 24 hour-12 hour time
Press Set - hold (top Left button) -When the sec start flashing go to the bottom left button press it 3 times -When the hour flashes press the bottom right button 1 time -Press the top left 1 once with
Posted on Jul 05, 2007
  • 29 Answers
SOURCE: How do I get my Timex WR50M watch out of the 24 hour (military) time and back to a 12 hour clock?
Hold down the adjust button bottom right then press the mode button top left you will notice the a or p that stands for am/pm will disappear & reappear. If you have an a or p on your display then you are out of military time.
Posted on Mar 12, 2008
  • 2501 Answers
SOURCE: coleman watch Model No. 40-328 How To change from 24 to 12 hour
I couldn't find the instructions for your watch but as watches tend to have similar operating characteristics, try this:-
Press the mode button until you come to a message that says something like "12hr" or "24hr" or something that indicates display change.
Then press one of the two buttons on the right to change to the display you require.
Some experimenting may be required!
Posted on Feb 03, 2010
cmcduncand
  • 714 Answers
SOURCE: how to change from 24 hour to 12 hour on g shock
http://world.casio.com/wat/download/en/manual/
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
Posted on Feb 19, 2010
escapement
  • 2334 Answers
SOURCE: Changing from 12 hr to 24 hr on a Casio Data Bank 150
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals. Rate me, please ...
Posted on Apr 02, 2010
I cant fix the analog of my watch pasnew model PLG_1002AD GRADE A QC 6
Ignore the instructions I found its not as easy as they say first you need to sync the digital and analog to do this press all four buttons at once and hold for 3 secs tho sets the digital clock to 12 Now press mode till you see h-s hold reset till h-s flashes hold the start button in the analog will start moving its slow so be patient set analogue to 12 exactly ignore the minutes that have passed press preset the minute hand will automatically adjust once done press mode go to the main watch screen hold preset use mode to select hours minutes date year month etc and start to change the values keep it on 12 not 24 hour clock set the clock and press preset the analog will now automatically adjust to the time once done you can change to 24 hr mode if you wish
Mar 06, 2015 | Watches
HOW DO I CHANGE MY WATCH FROM 24 HOUR MODE TO 12 HOUR MODE?
click on mode or setting option.then you will see the default time.edit it..try to change it using select or any mode available.there you can see 24hr clock and 12 hr clock.select which one you want.if it is in 12 hr then the time will be displaying like eg:7:00am or 7:00pm it means that it is in twelve hours.if it is showing 7:00 or 19:00 it means it is in 24hr clock.
Jan 29, 2011 | Casio W71-1V Wrist Watch
Timex 1440 sport indiglo 50m convert from 24 hour clock to 12 hour clock.
There are several models of your watch not all of which appear to have a 12/24 hour display format.
Try this extract from a manual; press the MODE button six times to enter the 12/24 adjusting setting and then use the START/STOP or SPLIT/RESET button to change the time.
Press the mode button to return to normal operation.
Dec 06, 2010 | Watches
Activate the 24 hr clock function
Press the mode button until you find the setting for 24 hour or 12 hour setting. (It is likely that the message will be abbreviated because of the limitations of the display, so some interpretation may be needed.).
You change the setting by pressing one of the other buttons on your watch - some experimenting may be needed.
Mar 10, 2010 | Watches
Timex 1440 time from 24 hour clock to 12 hour
Hi bowingman,
To use 12- or 24-hour time for your watch, please follow the instructions below.
1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
Hope it helps.
Thank you for using FixYa.
Oct 09, 2009 | Timex 1440 Nylon watch
Changing from 24 hr system to 12 hr system
  • Press "MODE" (lower left hand button) three times to get to the screen where the numbers are blinking, indicating that you can adjust the time
  • Make note of the hour if you don't have another clock handy
  • Press "LAP/RST" (lower right hand button) once to get the hour numbers to blink, indicating that you can change them
  • Press "ST/STP" (upper right hand button) to move the hour forward until you go past 24
  • At this point, you will notice a little "A" next to the time to indicate AM, and if you keep going past 12 hours, it will cycle back to 1, this time with a "P" next to it to indicate PM
Apr 18, 2009 | Lucien Piccard 26024 Wrist Watch
How do I set watch as a 24 hour mode clock ?
With TIME displayed, press and hold ADJUST, then press MODE to switch between 12- and
24-hour format.
Nov 02, 2008 | Timex 1440 Nylon watch
Mar 11, 2008 | Timex 1440 Nylon watch
Watches Logo
93 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Mark Schmit
Mark Schmit
Carol
Level 1 Expert
Are you a Timex Watch Expert? Answer questions, earn points and help others
