Hi sir i have a problem with my laptop it does not boot fan and disk laser work properly but there is nothing its black screen plz help
    Scholar:
  • 80 Answers
First thing to do is connect the laptop to an external monitor, see if it boots up. If it does then there is an issue with your LCD display. If not then it should at least give you an error or more information.
Please rate if this helps
Posted on Mar 14, 2011
The screen remains black, laptop won't boot, fan makes a low noise
try test an external screen to the computer, if you got it working, you have a broken backlight
Dec 29, 2013 | Computers & Internet
Laptop screen not working
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Oct 13, 2012 | Acer Aspire™ 5633WLMi PC Notebook
Booting issue with intel D865GSA
First remove the hard disk and see whether you have boot error if you have boot error insert the os cd in to drive and boot from the cd if it works fine you have a problem with the hard disk to clear the hard disk problem use a desktop computer and insert the hard disk as slave in the desk top and boot the desktop with the original drive then right click my computer click mange then disk management and find the laptop hard disk the delete all the part ion in the laptop disk then switch off the desk top and insert the hard disk in the laptop and reload the OS
Feb 14, 2012 | Intel D865GSA (BOXD865GSAL) Motherboard
Reboot and select proper boot device and press a key with black screen my laptop has no CD/DVD ROM
hi...
set up your bios with boot 1st harddisk...
if that appaer again..check your hard disk..
tht problems occur becous your hard disk not detact.
thnks&regards
Dec 10, 2010 | ASUS Eee PC 1000H Laptop
My Sony Vaio PCG-FR285M just shows a black screen at bootime
If your BIOS loads properly you have some display in your screen like text. But when you turn on and nothing readable on the display then you have problem in the BIOS. Try to flush updated bios in sony website. Recovery disk is only applicable if the system will display "Cannot find boot disk" or bios is properly loaded before you can boot from CD. If you wish you can boot it with Norton Ghost 12 Recovery Disk.
Aug 01, 2009 | Computers & Internet
Screen is black. Hear computer trying to boot up.
cpu fan failure try to put a big fan where the comp vents and air flows! and see if its not shutting down!
Jul 01, 2009 | HP Pavilion dv5-1000us Notebook PC
Boots but black screen toshiba satellite M300
See if you can plug in and external monitor and boot from scratch if the external scren comes on then the LCD on the laptop has had it. Ring Toshiba to get it fixed as its in Warrenty.
May 06, 2009 | Toshiba Satellite Pro M300-S1002X Notebook
Acer Aspire 5315 won't boot, black screen
I had the same symptoms on friends laptop. She had nothing to lose so gave me carte blanc.
Took out battery (to eliminate as problem) plugged in power, and powered up
Power light OK, HD flashed, CD flashed, then black screen. Powered down.
Did the following:
1) took cover off of fan/circuit board (see http://www.insidemylaptop.com/ for details). (4 screws)
2) take out fan (3 screws) and find huge amount of gunk on cooling fins at fan disch. Blew out with compressed air. Also cleaned fan blades.(reboot shows didn't fix.)
3) Repeated step 2, Pulled out memory sticks and cleaned terminals by rubbing with lint free cloth. Replaced memory sticks.
4) System boots normally. Replaced battery. Boots normally.
DAMN I'M GOOD!
Jan 05, 2009 | Dell Latitude D600 Notebook
Toshiba setellite black out
Sounds like the back light on the screen isn't working properly which will need to be replaced if this is the case. Check for a very dark image on the screen when it is booting up in a well lit room, if you can see the computer start up then it is the back light.
Jun 25, 2008 | Toshiba Satellite A60 Notebook
Nx 6110 boot up issue
None of the above. Sorry. All those "solutions" are "shooting in the dark". There is a definitive method of determining the problem here, without guesswork.
The "HP screen" you speak of is an "advertising mask" governed by the "quiet boot" option in BIOS.
This HP screen is shown INSTEAD of showing you exactly what BIOS is "doing" at that moment: First, a ROM checksum to verify BIOS is OK, then a quick system check of the most basic components, and if that goes well, the next thing it does is count AND check the RAM. Finally, after all that is done, it will look for a hard drive and query that drive for cylinder or LBA size, then look at MBR for sector zero, to find an operating system.
So here is what you must do to SEE all that taking place:
1. Make sure the system is TOTALLY cold (off, not in any ACPI state). Do this by pressing and holding the power button for 10 seconds, then release.
2. Remove Battery and the PSU (AC power supply)
3. Insert the PSU connector (only) this will also eliminate any battery problems. Batteries with dead cells can pull out so much current that you get slow boot/running performance. More on this later.
4. Now, start the computer, and keep pressing ESC key, quickly. It may start beeping. Stop and wait then.
5. Next, you will see a BLACK screen instead of HP screen. There will be some white text that scrolls. First the BIOS type and version. Next, RAM will be counted, and last, a HD will be reported. Last (or if any of the above have a problem) any errors will be reported. Some BIOS will specify the error, others will report it as "code XXX". Send me (post) this info, and I will analyze the problem.
NOTE: you can hit the PAUSE key at any time, to read the info, if it runs too fast for you. Then press PAUSE key again, to resume the BIOS data post process. Once you have reported back with any errors (as in step 5 above), we can also do this same thing with Windows, to "see" the black screen/errors reported as the PC boots.
Jan 22, 2008 | HP Compaq nx6110 PC Laptop
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
