I have a konics kn 2200 temperature controller. I want to set it up for a type K temperature probe. Can you assist please. Martin
5 Suggested Answers
SOURCE: set probe temp or remove probe
my oven keeps telling me to input a temp probe and it keeps blinking and its getting on my nerves.
Posted on Sep 14, 2008
  • 338 Answers
SOURCE: Set probe temperature
If i remember correctly i believe this is actually a wiring issue. you would need to turn the power off open the control panel. and look for a control board with the probe connection on it. there should be a tech sheet in the compartment to help you identify it however if it is the problem they would be purple wires on the connector that need to be reversed.
Posted on Nov 28, 2008
eastelect
  • 9 Answers
SOURCE: Temperature probe in Kitchenaid YKEMC308 stopped working
4455636 sensor, 4451442 thermostat 4450812 thermostat controller, could be all three, I usually start with the controller over 80% of the time thats it
Posted on Nov 30, 2008
national_a_r
  • 148 Answers
SOURCE: I have just purchased second
Your temperature meat probe part#4448948
Put your model number on the kitchenaid website and download the manual for free: http://shared.whirlpoolcorp.com/product_literature/literatureSearch.cmd?form_state=literatureSearch&context=&siteCd=KAD&userType=&searchTerm=kebs278db
Have a great day!
Posted on Dec 07, 2010
What does F1 mean?
The F1 error code indicates a problem with the electronic control board for the oven or with the oven temperature sensor probe. A technician will need to diagnose and repair this type of failure.
The technician will normally check the resistance of the temperature probe. If the temperature probe resistance is normal, it is likely that the electronic oven control will need to be replaced.
Mar 12, 2017 | Kitchen Ranges
Kitchen range displays square box indicating probe is inserted while it is not. Then regular beeps are heard and requires entry of the probe temperature to be set while showing a current probe setting of...
Hi
This means a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 09, 2011 | KitchenAid KERC507 Electric Kitchen Range
Hi there. Our Moffat stoveModel 24K60 has been in service since 1966, and, with a few minor service calls is still ticking along. No pun intended, but that's the problem. The clock is not only...
Hello there schematics for your unit will be next to impossible to find on the internet. My guess is that your unit uses a manual type timer as units that old usually have the timer independent of the other functions of the unit.therefore you wont be able to find any wires which power the unit. Mostly the timer will run on its own as a result of sensors on the unit. Both options which you have considered are gud but lubricating the bearings seems more likely although getting at it might be a bit difficult what you need is a watch expert usually they have methods of loosing out the entire clock mechanism taking it for servicing and fixing it back on your unit this way the bearing noise will stop. Also if you decide to take of the clock completely the same procedure applies.
Hope this solution has been helpful?
Apr 15, 2011 | Kitchen Ranges
Kenmore Electric Range f10 code
The F10 indicates that the electronic oven control board senses a runaway temperature condition in the oven through the oven sensor circuit.
This can be caused by a faulty oven temperature sensor probe or a failed electronic control board.
Oven temperature is detected by the control board as it monitors the resistance through the oven temperature sensor circuit.
You could have a failed oven temperature sensor, a wiring harness failure, an open thermal switch or a failed electronic oven control board that would cause this problem.
The first component to check would normally be the oven temperature sensor probe.
If you have a volt/ohm meter, you can shut off the breaker for the range and remove the screws that mount this sensor to the back wall of the oven.
Carefully pull the wire harness into the oven cavity until you get to the wire harness disconnect plug.
You should have enough slack to pull it this far into the oven.
Disconnect the sensor but do not let the wire harness retract back through the back wall of the oven or it will be hard to reconnect.
Measure the resistance of the oven temperature sensor with your volt/ohm meter. At room temperature, the resistance should measure around 1100 ohms.
The resistance chart is shown in the image below.
If the resistance is above 2200 ohms at room temperature, then the sensor probe is causing the F10 error code and will need to be replaced.
You can order a new sensor probe from the Sears PartsDirect website. The part number for the sensor is 316217002.
If the resistance is normal, then one of the other causes mentioned above is producing your F10 code.
You would need to access the electronic oven control board (Timer) in the console and check the resistance at the sensor circuit connection to the control board as the next step in troubleshooting this problem.
http://media.fotki.com/1_p,wbqdsfkrfqtswfqxgtqsskgwtqkq,vi/krdbrtqkgxkrbbqbrwb/1/1303472/5961857/image37801img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 14, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Refrigerator freezes food even on the lowest setting.
I am relly familiar with the PSS26MSRSS but some models are different. That model has an arraingment of thermistors located is several places that sens signals to the motherboard through the control panel. The control panel has these that branch out like temperature probes. Some models have electric dampers that get stuck or told to open very wide because one of the thermistors/thermostat probes is being blocked by food storage or just simply defective. If you want full instuctions and my assistance please let me know, Sea Breeze
Apr 10, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Mar 24, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Oven has stopped heating up
Hi.
This oven should have two elements.
If both broiling and baking element are not heating, then the most common fault causing the problem is a defective temperature probe.
The probe is located inside the oven cavity.
On most ovens there is only one temperature sensor, connected in line on the circuit from electroning oven control to baking and broiling element.
When the probe fails, it will affect both baking and broiling function.
The temperature probe is tested reching the probe, cutting or disconnecting its wiring, and testing the probe at room temperature, with a multimeter set on impedance at Rx1. If the multimeter reads no continuity (circuit open), then the probe must be replaced.
If the temperature probe is good, then parts that may be responsible for the fault are oven electronic control and wiring. Having both elements failing at the same time would be rather unusual.
If only one element is failing, then the fault is probably the element. In that case you can test the element removing it from the cavity, and testing Ohms on the element. If circuit is open , then the element must be replaced.
Regards.
Mar 03, 2010 | Baumatic B180 Electric Single Oven
Konical Minolta 2430 dl Streaking
Try cleaning the rollers.  Directions can be found starting on page 83 "Maintaining the printer" here:
http://www.kn.nl/data/handleiding/174952/user%20guide_engels.pdf
Jun 12, 2009 | Konica Minolta magicolor 2430 DL Laser...
F30 - F10 error messages
The F30 error code indicates that the electronic oven control board detects an "open" oven temperature sensor probe circuit.
This is usually caused by a failed oven temperature sensor probe.
Replacing this component will likely fix your problem.
You can order this part from www.searspartsdirect.com website.
If you replace this part yourself, be sure that you unplug the range to disconnect electrical power before accessing this component.
On some models, you can replace the probe by removing the screws that mount this component to the inside back wall of the oven.
Carefully pull the probe inside the oven cavity until you encounter the wire harness disconnect plug.
Unplug the sensor and replace it with the new one. Mount the new probe on the back wall of the oven.
On some models, you have to remove the lower back oven panel to access the sensor probe.
If you replace the probe and still have this problem, you will need to unplug the range and measure the resistance through the violet wires that plug into the control board (this is where the sensor probe circuit is connected to the control board).
If the resistance through the oven temperature sensor probe circuit is normal (about 1100 ohms at room temperature) then the electronic oven control board will need to be replaced.
http://media.fotki.com/1_p,wbwdqtgkkqdrrfgxgtqsskgwtqkq,vi/ktrrwffdrxkddstsrtq/1/1303472/5961857/image45310img-or.jpg
Jul 28, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Heating & Cooling Logo
268 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
