Question about Hitachi UltraVision CineForm 55VG825 55" HDTV
Replaced lamp in 55vg825 approx 1500hrs ago & lately the picture has lost brightness compared to when the new bulb was installed. Is there another adjustment or is the bulb defective already? Past experience dictates the bulb either works or doesn't work.
  • 1,476 Answers
Bjac,
You are correct about lamps working or not, but that is the extremes. Over the course of operation all lamps lose brightness as the hours add up. All lamps will lose their brightness over time.
Typically lamps only last at best 6000 to 8000 hours. That is not long if the unit is used most of the day everyday. In addition the cheaper the quality of the lamp, cost and manufacture, the quicker they go down hill.
Assuming that you have a low quality lamp what you are experiencing is normal. You may be able to improve the brightness and clarity of the picture by cleaning the lenses, mirrors and screen. I have a tip at
http://www.fixya.com/support/r4690955-clean_lense_screen_in_projection_tv
This tip is labeled projection tv but is also appropriate for cleaning an LCD or DLP unit.
Thanks for using FixYa and for the great rating.
hardrocko
Posted on Mar 14, 2011
I turn on my Mitsubishi WD-73833 TV and it turns itself off
Lessing of brightness on a DLP set is a sign of imminent bulb failure.
A new bulb is in order.
Nov 23, 2013 | Mitsubishi WD-73833 73" HDTV
I installed a new lamp and the tv is still blinking saying the lamp is bad. There is no picture.
its most likely the ballast which is causing the issue. The ballast is what provides the power source to light the lamp. You can get the ballast at www.tvrepairworld.com and they can provide instructions on how to replace the ballast
Mar 31, 2013 | Mitsubishi WD-73733 73" HDTV
Hitachi 55vg825 - sound fine / but no picture- only indicates No sync signal on tv-
It could be the lamp---if you remove the lamp look to see if it is shattered inside---average life on lamp is 2,000 hours or 2 years.
May 16, 2012 | Hitachi UltraVision CineForm 55VG825 55"...
Picture way too dark to watch comfortably. Have already adjust all settings to maximize brightness. Bulb was replaced late last year and says 1,000 hours have been used but projector has not prompted me...
Unfortunately dim image is normally due to a defective lamp assembly. I'd recommend removing the lamp and inspecting its condition. You'll notice black corrosion build up or a bubble is starting to form around the filament of the bulb if it is what's causing the dim image.
Aug 06, 2011 | Mitsubishi HC1600 Projector
Picture Seams a little dark
Its possible that your lamp is nearing the end of its lifespan.A new lamp will give you more brightness.
May 14, 2010 | Hitachi UltraVision CineForm 55VG825 55"...
Picture is very dark on all channels. Settings have not changed. Do I need to replace the bulb?
You may need a drive PCB. This PCB can cause the picture to be too bright, no brightness or picture too dark, intermittantly or permanantly. Do check the bulb though and see if it is foggy looking or dull especially if it has not been changed. Thanks for using Fixya.
Oct 27, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Picture getting dimmer (?)
Hi, yes it`s time to replace the lamp, and remember to turn maxxed out brightness to normal once you replace the lamp :) good luck, video-tek
Jun 29, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony KDF-E42A10 Screen is Not Bright
try a lamp first, through best buy their about $150 -250. If that fails it might be the optic block assembly which is about $1,000, and i just recently had replaced, and the picture is as bright and clear as when i got it two and half years ago
Sep 01, 2007 | Sony KDF-E42A10 42 in. LCD Television
My picture brightness is uneven - there is a persistant bright field on my screen.
I have the exact same problem with my AE700. It a started about the same time, around 2500 hours for me. I lived with it untill I could afford a new bulb which arrived yesterday. The old bulb was still working at a 3603 hours when I installed the new one. But the new bulb didn't fix the problem for me either. I may try to take it apart this weekend and give it a good cleaning. Andy
Jan 07, 2007 | Panasonic PT-AE700U Multimedia Projector
Hitachi UltraVision CineForm 55VG825 55" HDTV Logo
429 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
