Question about Compaq Armada M300 Notebook
How to bypass a BIOS set up password on the notebook
    Scholar:
  • 172 Answers
Remove all power sources, ac adapter and main battery if you have one. Then disconnect RTC battery for 30 seconds. It is located under the tear shaped cover on bottom of computer. Reconnect RTC battery and ac adapter but DO NOT PUT BACK THE MAIN BATTERY until you have reset the date and time.
Please rate & vote , if you like solution..
Thanks
Posted on Mar 14, 2011
    New Friend:
    Problem Solver:
  • 11 Answers
The bios means Basic Input Output System, so if bios boot password, no one can jump over. However, if it is to enter the bios setup password, you can use software to crack.
Or wish come http://www.laptopbatteryinc.ca If your laptop battery or laptop power supply and laptop ac adapter hardware understanding or demand.
Posted on Mar 06, 2013
    Scholar:
  • 135 Answers
Using the jumpers The canonical way to flash the BIOS via hardware is to plug, unplug, or switch a jumper on the motherboard (for "switching a jumper" I mean that you find a jumper that joins the central pin and a side pin of a group of three pins, you should then unplug the jumper and then plug it to the central pin and to the pin on the opposite side, so if the jumper is normally on position 1-2, you have to put it on position 2-3, or viceversa). This jumper is not always located near to the BIOS, but could be anywhere on the motherboard.
To find the correct jumper you should read the motherboard's manual.
Once you've located the correct jumper, switch it (or plug or unplug it, depending from what the manual says) while the computer is turned OFF. Wait a couple of seconds then put the jumper back to its original position. In some motherboards it may happen that the computer will automatically turn itself on, after flashing the BIOS. In this case, turn it off, and put the jumper back to its original position, then turn it on again. Other motherboards require you turn the computer on for a few seconds to flash the BIOS.
If you don't have the motherboard's manual, you'll have to "bruteforce" it... trying out all the jumpers. In this case, try first the isolated ones (not in a group), the ones near to the BIOS, and the ones you can switch (as I explained before). If all them fail, try all the others. However, you must modify the status of only one jumper per attempt, otherwise you could damage the motherboard (since you don't know what the jumper you modified is actually meant for). If the password request screen still appear, try another one.
If after flashing the BIOS, the computer won't boot when you turn it on, turn it off, and wait some seconds before to retry. Removing the battery If you can't find the jumper to flash the BIOS or if such jumper doesn't exist, you can remove the battery that keeps the BIOS memory alive. It's a button-size battery somewhere on the motherboard (on elder computers the battery could be a small, typically blue, cylinder soldered to the motherboard, but usually has a jumper on its side to disconnect it, otherwise you'll have to unsolder it and then solder it back). Take it away for 15-30 minutes or more, then put it back and the data contained into the BIOS memory should be volatilized. I'd suggest you to remove it for about one hour to be sure, because if you put it back when the data aren't erased yet you'll have to wait more time, as you've never removed it. If at first it doesn't work, try to remove the battery overnight.
Important note: in laptop and notebooks you don't have to remove the computer's power batteries (which would be useless), but you should open your computer and remove the CMOS battery from the motherboard.
  • 63 Answers
Pull out the CMOS battery (the little watch-style battery on the motherboard). This will reset all of your BIOS settings including the password.
How do you bypass a power on password for a hp pavilion notebook pc
The power on password feature is a bios setting on the computer.
Enter the bios by pressing the F10 all the time at startup.
Inside depending on what version of the bios you have you will see the option of power on password option.
Simply take this off in the settings
Apr 06, 2012 | HP Computers & Internet
Ive got a E system and it needs a bypass password this wasnt entered in to the system when it was first brought please help
Does the laptop ask for a password as soon as you power it on?? If so it is your bios master password to bypass any current password that is set. http://unlockbiosrecovery.com/Unlock_Fujitsu_Bios.php can supply you with the bios master password you need for only $20 and they guarantee it to work or your money back. I do laptop repair and I use them when I need a bios password reset or a hard drive password reset.
Aug 25, 2011 | Fujitsu LifeBook E780 Notebook
How do i bypass the password for the bios
There is only 1 way and that is tearing the laptop down to get to the bios battery. Unseat the battery for about 2 minutes this should set the bios back to factory settings without a password. Good luck dont break anything getting there.
Aug 10, 2011 | Toshiba Portege 7100 Notebook
Need to bypass bios password
just download....rescue trinity software so that you delete a bios password that is only things to do, there is no solution to bypass the bios password except you know the password..
Jun 21, 2011 | Toshiba Satellite A135-S4527 Notebook
BIOS restore
To reset the BIOS to factory settings read the information from this link, disregard the first point as that applies only to bypassing the BIOS password, the other 3 solutions not only will reset the BIOS password but will also bring the BIOS to factory settings.
Feb 10, 2011 | Acer Aspire 1642ZWLMi Notebook
My Little 14 y boy set BIOS Password that he can't figur now !! how to bypas plz ?!!
You can't bypass it, but you can reset the BIOS password. To reset the BIOS password read the information from this link. I would recommend trying Hiren's Boot CD first, and use Kill CMOS from the CD to wipe the BIOS.
Jan 10, 2011 | Toshiba Satellite A135-S2266 Notebook
Bios password
Bios Password - HDD password - Master password - Unlock laptop - Reset bios password - Bios password removal - Bios Password Recovery - Clearing the Bios or CMOS Password
http://hdd-biospassword.blogspot.com/
Feb 15, 2010 | IBM ThinkPad T43 Notebook
When i on the laptop it is asking password even before the bios settings load ?/
Follow the link below on how to bypass BIOS Password.It just the password which will enable BIOS to load.
http://www.fixya.com/support/t3809902-bios_passward
Hope it may be little helpful to you.
Jan 05, 2010 | Toshiba Satellite A135-S2276 Notebook
I have a compaq nx6310 laptop. how do you get setting password
You can disable bios security passwords by disabling them. Go to bios by pressing F2 at splashscreeen. Find administrative passwords and then disable. You will need to enter the password to disable.
If the password you speak of is not in the bios but the windows. Go to control panel, users and remove password.
Sep 13, 2009 | HP Compaq nx6310 Notebook
Compaq Armada M300 Notebook Logo
146 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
