Question about Canon imageRUNNER C6800 Copier
Hola amigos tengo un problema con el adf de la canon irc6800 le e hecho un memory clear y luego de eso ya no me reconoce el adf el resto funciona bien, el adf reconoce la hoja pero al momento de hacer la copia sencillamente me marca papel atascado y al abrir y cerrar el adf el error de papel atascado persiste ,como lo puedo solucionar??
4 Suggested Answers
pineworks
  • 4041 Answers
SOURCE: error 5600 Canon ip1700
Hi there
You can try this it some times works.
Super Canon User's method of resetting IP1600
1.Press Resume button hold for 1 - 2 minutes (count to 1 to 15-16)
2.Open the cover right away
3.Release Both cartridges out and then put cartridges them back again
4.Close The Cover
5.Turn Off Then Turn On again.
You can download the Resetter tools program from my website.
Click Link = http://www.4all2sell.com/reset-tools/ip1600st-RESETTER-TOOLS.zip
1. Download software for Canon iP1200, iP1600, 2200 Printers.
2. Unzip downloaded file by etc
3. Run GeneralTool.exe
4. Select the connected USB port number from USB PORT
5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION
6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selected waste ink counter will be reset. MAIN resets the main waste ink counter, PLATEN resets the platen waste ink counter.
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters.
Free WinZip http://www.winzip.com/downwz.htm
Please call back to vote
All the best: Pineworks
Posted on Feb 27, 2010
  • 40 Answers
SOURCE: error canon 3220 E000004-0004
try cleaning the photointerrupter at the behind of left top delivery ***'y
Posted on Mar 08, 2010
edy_bubat
  • 259 Answers
SOURCE: Hola tengo un problema con una canon 5000 y marco
check the tube of waste toner.
position at back side and below of copier.
Posted on May 16, 2011
Tengo una ford f150. 2005 cuando le pongo la palanca en la D para abansar y acelero no funciona se parina y derepente agarra. O cuando ago un stop en una luz roja cuando cambia a verde acelero y se patina....
Alacrana si tu troca le esta pasando eso ya tr recimiendo que compres una transmision usada o nueva ya ya los discos de adentro estan gastados si le metes arreglo que sea reparacion para la caja completa asi te vas a haorrar gastar aya ya ak en cada taller o mecanico a domicilio
Apr 16, 2012 | 2005 Ford F-150 Regular
Tengo problemas con mi HHR la luz del T/C no se apaga y cada vez que pongo el cambio en Reverse o Drive hace un golpe en el motor, como puedo solucionar el problema?
Hola, Tengo Una HHR Y Cada Vez Que Me Aparece El T/C Me Empieza A Dar Golpeteos En La Caja Cada Vez Que Meto Drive Y Al Avanzar Da El Golpeteo De 1 A 2 Despues De Esto Tambien Me Aparece El Check y Al Aparecer Esto Ya no Enciende Desde El Control Remoto Yme Gasta Un Poco Mas De Gasolina Me Han Dicho Varias Personas Que Son Los celenoides Y Tengo Esa Duda
Apr 13, 2012 | Chevrolet HHR Cars & Trucks
Hola: tengo problemas con mi portable super multi driver LG GP08NU6B, ya que mi Pc no lo reconoce, cuento con el windows 7; y pienso que el problema es por que ya tenia antes instalado otro lector de...
A mi me ocurre exactamente lo mismo, en una netbook donde no tenía ninguna grabadora instalada funciona ok, pero en la pc de escritorio o en la notebook no funciona, todas tienen windows 7. El soporte telefonico o via mail de LG me mandan a la tienda donde la compré...!!!! Es raro,le busque varias soluciones pero no logro hacerla funcionar!!!
Jan 23, 2011 | LG GP08NU6B DVDWriter Black External...
Acaban de componer mi camioneta (pontiac montana sv6 1999) porque los buzos hidraulicos estaban pegados y no pasaban aceite (le pusieron nuevos), al siguiente dia de uso empezo a fallar la aguja del...
hola ayuda por favor. tengo una pontiac montana 97 y la falla es que en ocasiones da marcha pero no enciende a la primera. hace como que arranca pero se apaga. pero si acelero un poco al dar marcha si arranca y ya se mantiene normal. que sera. gracias. saludos
Nov 19, 2010 | 1999 Pontiac Montana
Tengo problemas con un Multifuncional HP Laserjet M1522, por alguna razon empezo marcar ERROR 5 Y NO PUDO INICIALIZARSE el SCANNER , Funciona como impresora pero no como copiadora o Scaner, , parpadea la...
59c05df4-3e41-4402-8674-16fa865682b6.jpg1e27574a-853d-43f0-83e9-639f0eb8015f.jpg6f9cb0d0-efc0-4725-b485-113c15667e78.jpg639e37f6-dbca-4b87-baf4-9919d68a26d4.jpgf319f64c-35bb-4a4d-b11b-3637a94260fd.jpgdf4c7415-80c2-478b-9083-7ef214ae9172.jpg027f0e9b-f662-4bc9-916c-d62c423d9e73.jpga1eea8bc-2311-4ede-b6b1-2b036b38dc64.jpg7ada6481-ced7-4dab-b710-09760d6b9498.jpg04f42b95-4eec-4796-8556-1ef7ab6cddbe.jpgHola amigos, tambien tengo este problema con una impresora, reinstale el firmware y no funciono, lo que note es que el motor estaba quemado, lo desarme y lo rebobine, compre el alambre me parece que fue calibre 33, aprox 25 mts, 260 vueltas con una resistencia de 10ohms por bobina. bueno despues de esto lo monte y funciono un poco mejor. pero al parecer es la tajeta logica pregunte a un proveedor de hp y su valor es de aprox 3000 pesos mx, lo que hice es hacerle un agujero al escaner.
Detalles.
viendo de frente el escaner del lado izquierdo le hice un agujero de 3mm. y le puse un cincho largo(pueden usar algun desarmador, el cincho se lo puse doble para que no se doblara, el cincho debe entrar con facilidad pero no muy olgado para que no se doble, al introducirlo no es necesario sacarlo ya que el carro lo sacar, es por eso que no debe quedar apretado). esto me permite mover el carro del escaner a lo posicion "0". posicion de partida y hubicacion de la banda indicadora(Empujarlo unos 3 cm aprox, despues solo se calibra).
La finalidad de esto es de manera manual regresar el carro, se apaga y se vuelve a encender y listo. funciona nuevamente.
Este error me aparece despues de haber utilizado el ADF, el cual el carro se mueve al lado izquierdo para poder escanear automaticamente los documentos. posteriormente no puede regresar.
Aqui pues es donde le podemos ayudar a regresar a su posicion original.
Espero que les ayude en algo.
Aug 29, 2010 | HP LaserJet M1522nf Multifunction Printer...
ROS failure
Hola buen dia OKI B6500 la falla que presenta es ERROR DE ROS crei que era el laser scaner pero le puse el de otra impresora en buen estado y nada siguio al poco tiempo igual de hecho el que le quite lo puse en la impresora que esta en buen estado y sigue funcionando, este error OKI B6500 lo hacen muy comunmente este tipo de impresora,En OKIDATA me comentaron que lo provocan varios sensores sobre todo el de tapa superior pero aun que lo corrijas funciona pero al poco tiempo lo vulve hacer que mas puede ser si ya le cambien el sensor de tapa sup.,laser scaner,sensor de deteccion de toner., en OKI no especifican cual es el provoca este error nada mas dicen que son varios sensores.
NOTA: de hecho un colega hizo lo mismo y no le la corrigio lo que hace es la apaga varias veces sacando y poniendo el toner y a veces bingo funciona de hecho tiene una impresora que inicia bien pero al poner el toner se apaga o marca error que hacemos las tiramos tienen menos 80,000 paginas alguien tiene un buen TIP
Aug 19, 2010 | OKI B6500 Led Printer
Mi problema es q no tengo chispa pero si tengo pulsos de inyeccion y activacion de bomba de gasolina quisiera saber si es pastilla o bobina o sera la computadora?
Necesito saver que ano es el carro para poderte ayudar pero por lo general a esos carros se le va el modulo de control de la chispa si usa distrbuidor esta adentro pero eso varia de acuerdo con el año asi es que te aconsejo datos mas claros para ayudarte con una mejor repuesta
Jan 09, 2010 | Honda Civic Cars & Trucks
Tengo una camioneta isuzu y se acelera y
Hola Ruben
No estoy seguro, pero tengo un Amigo 90 que le pasa lo mismo.  Según creo el problema está en los controles electrónicos de las válvulas (esos aditamentos que están a la izquierda del carburador, segun lo ves desde el frente, sobre la salpicadera derecha del auto)
No se como se corrige el problema.  Supongo que cambiando los controles de las válvulas.  Una cosa que puedes revisar es que las mangueras que comunican el carburador con esas piezas que te menciono no tengan entradas de aire por grietas por resequedad.
Si alguien más sabe una solución mejor, espero con gusto su respuesta.
Yo quisiera cambiar el carburador por uno 100% mecánico mejor
Oct 03, 2009 | 1993 Isuzu Amigo
Gigabyte GA-K8N Pro-SLI won't boot and no beep codes
hi kathy,
there are a few things you can try, reseting the cmos, with the jumper usually located near the battery. if you cant find that, try removing the battery for 30 mins and then popping it back in. if no luck from there, you could try another cpu, if that dont work then it may just be the mobo! good luck!
hope it helps!
Feb 11, 2009 | Gigabyte GA-K8N Pro-SLI Motherboard
Problema en el ps2
Amigo, creo que solamente se dasabilita eso por el jumper, pero la pregunta es, el board sin teclado conectado funciona, o sea despierta, si es asi, conecta el teclado USB cuando la maquina este funcionando, con el sistema operativo (windows, linux, o el que sea) , si no arranca, puede ser problemas de memoria, prueba cambiarlas y me dices, un saludo Marlon de la Rosa
Feb 01, 2009 | AOpen MX4LS (91.88Q10.001) Motherboard
Canon imageRUNNER C6800 Copier Logo
144 people viewed this question
old marine
old marine
