Question about Hitachi C10FSB 10" Sliding Dual Compound Miter Saw
I have the old model c10fsb mitre saw but need to replace the two parts of the handle & the trigger,where would i get them ?
    Genius:
  • 1,015 Answers
You can go to www.toolpartsdirect.com and search by brand name than tool description by model number then view a schematic to get part numbers. You can also call direct at 1-866-597-3850.I hope this helps you. Good luck and thank you.
Posted on Mar 14, 2011
Can't lock miter angle with slide handle
There is a plate under the turntable which needs to be replaced, remove centre bolt locknuts and washer (44,45 and 46) from the underside of the base and lift the turntable off taking care to not loose the detent spring (36) and steel ball (37), turn it upside down and remove the spacer plate (31) and replace it, use a small amount of grease on the spring and steel ball during assembly to keep them in place
Jun 24, 2015 | Hitachi C10FSB 10" Sliding Dual Compound...
How to fix a stuck trigger on a compound mitre saw
Go to eReplacementparts.com and buy a new one. Enter your make and model. A cut finger is not worth the time trying to fix the old one.
Sep 05, 2014 | Saws
Blade guard for power craft compound mitre saw WK 1200
Lows, Home Deport, Ace Hardware, Tractor Supply, Target, Wal-Mart. Kmart, about any major store. Harbor Fright. Etc.......
Jun 23, 2013 | Saws
Problem with m y dewalt 704 mitre saw type 1, at first the trigger stuck, and now the saw won't run at all, any help would be appreciated.
you need to change switch,when trigger stuck,2 contact on switch weld ,after no contact at all because of wear
Jun 04, 2012 | Dewalt Tools & Hardware - Others
Macallister mitre saw sparking
I would plug it into another outlet first. The small arcing that you see might be normal especially on stopping because of the brake. If another outlet doesn't work then I would take it back. Upon startup this saw will draw more than the rated running amps.
Feb 26, 2012 | Saws
Do you have any info on the craftsman model 137285850 mitre saw. owners manual? problem with mitre guage for angles, was removed not sure where it installs on base
You can see a breakdown of this that might help you go to
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Saw-Parts/Model-137285850/0247/0744300?pathTaken=&prst=0&shdMod=137285850
Hope this helps!
Feb 20, 2011 | Garden
Need to re assemble trigger of ls1040 mitre saw, is there any instructions
go to MAKITA TOOLS.COM under benchtop on the menu select miter saws and your model number once in there there is a menu showing instruction manual, parts assembly and you can geta full print out diagram of how it should go together
May 03, 2009 | Makita 10" Compound Miter Saw LS1040
My mitre saw wont lift up into the cutting position it seems stuk
look on the left side of the saw just past the blade there is a knob there pull it out as you hang onto the handle of the saw ,the knob is spring loaded,plus the if you dont hold onto the handle the unit will come up very fast.possible of hurting you or the saw.
Mar 29, 2009 | Ryobi ZRTS1342L Factory-Reconditioned 14...
Need a detailed schematic for handle of a hitachi C10FC mitre saw
I would go to Ereplacementparts.com and type in your exact model number (there are about 5 saws) and they you can download a schematic of your tool. Hope this helps.
Dec 30, 2008 | Hitachi C10FCE2 10" Compound Miter Saw
Hitachi C10FSB 10" Sliding Dual Compound Miter Saw Logo
336 people viewed this question
Top Hitachi Saws Experts
John Trevino
JOHN LAPIER
Are you a Hitachi Saw Expert? Answer questions, earn points and help others
