Question about Brother MFC 490cw Color Inkjet Multi-Function Printer
My mfc 490cw will not print black ink. What should I do?
  • 310 Answers
Try to clean the print head 2-3 times,if not work you need to replace 100% the print head.If a have been usefut please give me a vote :)
Posted on Mar 14, 2011
komguy
  • 2306 Answers
SOURCE: black ink is not dispensing
There may be an air bubble in the black tubing, it will take several more cleaning cycles to clear. You can tell it to clean only the black and save the other inks.
Posted on Jul 01, 2009
SOURCE: my Brother MFC-490CW won't print
Did you try onboard print test by pressing INK LEVEL button. I am having similar problem but color prints but black does not. The printer has built in diagnostics that walks you thru some troubleshooting steps. It has you repeat cleaning 5 times and then asks you to replace cartridges if test fails...than repeat tests and call customer support if that does not work. Which I may do soon.
Posted on Jul 25, 2009
komguy
  • 2306 Answers
SOURCE: mfc-490cw what's unable to clean 35 ?
That error says that the carriage is not moving properly side to side or the encoder strip is dirty or out of position. You have to look inside for scraps or encoder position with a flashlight and mirror or remove the top cover to correct the problem.
Posted on Oct 15, 2009
cene765
  • 787 Answers
SOURCE: MFC-490CW two ink colours just not printing, it
Powerful cleaning is: Press menu, then start black copy, then four times arrow-up quickly after another.Machine will be in maintenance mode (all lights will flash).
press 7-6-4 and OK (or start-black-copy).
When finished press 7-6-3 then start black copy,
printer will do a power purge.
Leave maintenance mode by pressing 9-9.
If this not help better think about new printer, because cost of repairing this one is profitable.
Posted on Nov 10, 2009
pineworks
  • 4041 Answers
SOURCE: problem paper jam printer brother no mfc-490cw
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 27, 2010
Hello again can i not clean the printer head nozzles myself? in my brother mfc 490cw out of warranty but was working previously until black ink ran out copying but they are blank pages all inks are full
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, thenprint head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head. A Warranty does not cover blocked print heads.
Jul 20, 2011 | Brother MFC 490cw Color Inkjet...
I installed a new black ink cartridge(lc61bk) on a brother mfc-495cw and now nothing is printing.
Check out if you've installed it correctly. Also check out other ink cartridges, are they empty? If yes you won't be able to print anything. However, if all ink cartridges are OK then try to reset the printer or reinstall the drivers. You can find help in MFC 495cw users manual
Feb 27, 2011 | Brother MFC 490cw Color Inkjet...
MFC-490CW does not print black ink, what can i do to fix this?
does it print in any of the other colours? if not, it sounds like one cartridge is empty and the printer will not print until you have full cartridges.
Feb 08, 2010 | Brother MFC 490cw Color Inkjet...
Printer wont print
Try remove all cartridges then put back it one by one.Make sure the color cartridges are not empty too.The printer need all cartridges not empty to initialized and working.
Nov 25, 2009 | Brother MFC 490cw Color Inkjet...
Printer won't print black ink
From multiple online sources, this appears to be a fairly common problem with this model. As a matter of fact, my 490CW is experiencing the same exact issue. Called tech support and they're issuing an exchange. I'd advise that you do the same.
Oct 09, 2009 | Brother MFC 490cw Color Inkjet...
My brother 490CW won't print black ink
I HAD THE SAME PROBLEM, the printer started using all of my yellow ink.
Look at the black cartridge and check to see if the opening on the side is as it should be( a little ink is able to come out of it).
If not, then you need to replace the cartridge with another one.
This fixed my problem after a lot of wasted time with me trying to install the drivers again, which was not the problem.
Clean it a few times with the black only , then check the print, it may take 5-10 times.
Oct 03, 2009 | Brother MFC 490cw Color Inkjet...
Black ink is not dispensing
Jul 01, 2009 | Brother MFC 490cw Color Inkjet...
My Brother MFC-490CW won't print
Apr 25, 2009 | Brother MFC 490cw Color Inkjet...
Brother MFC 490cw Color Inkjet Multi-Function Printer Logo
613 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
