Question about GoVideo DV2150 DVD Player/VCR
Need a remote for aDV2150
The remote has had a melt down when you put new bateries in it gets hot at the battery conections
  • 1 more comment
  • harborsail Aug 03, 2008
    I know I need a new remote ? is where to get one Thanks
  • harborsail Aug 06, 2008
    Both there website and 800 # do not work
  • dan0302 Nov 16, 2008
    We can not locate the original remote for this GO.VIDEO DV2150 combo DVD+VCR unit. Without it the unit is useless, the website and 1-800 # is also useless. What remote can we buy to replace this & where can it be purchased?
  • 979 Answers
Be SURE the the batteries are placed correctly in the remote-bacwards can do exactly what you describe. If the cells are in there correctly, it just might be time for a new remote...accordianman
Posted on Aug 01, 2008
  • Michael Borelli Aug 03, 2008
    Go to their website and look under "support" to see if parts are available for this unit...accordianman
Just can not turn modele191va on with remote. Just got it home and nothing works . Please help
Generally:1step check bateries in remote
2step is to find IR mark or simular point on device ,and check that is not some object in front which can broke or close or hide that,in way that signal from remote can not came in controled device
3step is to come more close and find IR glass on device and put remote top side where is IR(infra red) diode to exact direction
4 step is to visually check top of remote,and remote IR signal point of reception,maybe is some sticker on it.
And if is new,remote and device,which is not previouslly used, sometimes makers even they put charged batteries,they put some paper or plastic which prevent contact of bateries that bateries in remote get discharged, so look for it,and remove it..
(sorry i dont own device,but this is way for all, if your device and remote not use IR signal that only means that remote not need be putted in allmost good direction,if work with radio signal,but i dont belive it,as its rare,and more expensive way for remote control)
Aug 30, 2012 | Vizio Audio Players & Recorders
Remote starter keeps running my battery down
Parasitic drain on the battery , You can diagnose this problem easy . Watch these videos . You will need a voltmeter .
The BEST Way TO Perform Parasitic Draw Test
The Trainer 27 3 Ways Of Finding The Cause Of Key Off Battery Drain...
Sep 08, 2017 | Mercury Cars & Trucks
It wont crank like not getting power
ok sounds like you have a dead battery
1) if turns but slowly:
posible causes:
1.1) old dead batery/
or underchaged battery >check altenator in this case
did you leave your headlights turnt on and drained the battery of its charge?if so get a jump start and then run the car for 30-45 mins to rechagre the battery
if you have at your disposal anothere batery that you know has a good charge
try starting your car with that batery(not using jumper cables) hook it up!
if the slugish turn over is still there
1.2) check your wire conections for corision this means completly disconecting 1 lead at a time (only on one end of that lead)and cleaning them with a wire brush or some sand paper.
(on the battery and the starter also the ground strap conection to the frame.)
2) WONT TURN OVER AT ALL:
posible causes:
2.0) dead battery >try charging it>get a jump start
2.1) blown turnkey igntion fuse
2.2) blow fuse for main har nes wires
2.3) bad starter
2.4) corosion on wire conection (most often the batery terminals)
2.5) starter replaced and hooked up incorectly.
2.6) alram system preventing the turnkey igntion system from getting power
Feb 24, 2010 | 1994 Mazda 626
I want to get a replacement remote, mine is no good, installed new batteries and still nothing, very disappointed!
the polarity of the battery is good? the old batery was leak? try to find in you area a similar remote or universal remot if you put the right battery
Feb 14, 2010 | BUSlink LT-15V3 15 in. LCD Television
Battery went flat now wont take key code in drivers door 1994 p38 range rover.did some engine work battery disconected for about a week. when engine work finished.conected batery started fine. went...
key code lock out usually happens when you have entered the wrong code too many times leaving the battery connected should allow the timer to run down for 30 mins so you can try again, it is cumulative though so the more you get it wrong the longer you have to wait. make sure battery is fully charged first.
Jan 30, 2010 | 1994 Land Rover Range Rover County
Electrical Demon in my 1999 Taurus SHO
could be a bad diode in the alternator. make sure the car is off with batery conected and charged. need a test light and jumper cable and digital multimeter. disconect only the negative cable conect one end of test light to batery cable and the other end to batery terminal.if the amp draw is higher than 4 amps it will light up.now conect the multimeter to the neg batery cable with red probe and black probe to neg batery terminal . multi meter on (dc 10a) if it reads between 0.8amps and 1.5amps a light is on or a relay is stuck. to check relays use a old wll charger (phonecharger) cut ends of and connect one wire to 85 and other to 86 on realy it should click. now use the multimeter select continuity and see if it beeps. if it does it works. now remove the phonecharger. and reconet the multi meter to 30 and 87 on relay it should not beep. buy a multi meter from wall mart (innova ) for $30
Mar 05, 2009 | 1999 Ford Taurus
I have a 96 Ford Probe that I purchased a few weeks ago. I had both of the belts and the thermostat replaced and then I started losing power so I was told to replace the battery cables and terminals. I did...
Sorry I can't so much for you on this one except tell you that you have a hot wire or cable grounding out somewhere. I obviously is a large power line since it melts the positive post when contact is made. Check the positive cable that runs down to the starter. It may have been pinched or possibly melted through the rubber case that encloses the cable. Follow the cable from the batery or soleniod down to the starter and check where it may have come into contact with the hot exhaust and melted through. Good luck I hope this gives you a good starting point. Let me know the outcome. I would be glad to help more if you need it.
Feb 24, 2009 | 1996 Ford Probe
Camera gets hot
It sounds like your camera has a dead short in it. Either that or a defective battery. Do not leave the batery in teh camera it could melt things. Seriously! Did the camera get wet? If not and the camera is undera year old then Olympus will repair it under warranty.
Mar 08, 2007 | Olympus Stylus 600 Digital Camera
GoVideo DV2150 DVD Player/VCR Logo
Top GoVideo Televison & Video Experts
Demonic-2011
Demonic-2011
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
