Question about KitchenAid KEMC378 Electric Double Oven
How do I change the light in my double oven microwave KEMC308
  • 33 Answers
The light cover at the back of the oven needs to be unscrewed. There is normally 2 or 3 little screws involved. Once it has been removed it's like any other light bulbs, unscrew and change. Make sure to put back the cover tightly in place or the light will burn when the oven turns on.
Posted on Mar 14, 2011
SOURCE:
The microvave oven has "door" in the display and the microwave doesn't work
Then one of the micro switches either has failed or has slid out of position
Nov 29, 2013 | KitchenAid KEMC308 Electric Double Oven
Problems with KitchenAid KEMC308 Electric Double Oven DISPLAY
either the touchpad ur pushin or the control board behind is has a bad connection or one of them is defective......u will prob need service some of those u must pull out to acess the componets, not a cheap repair if one of those, usaually at least a couple hundred dollars per part
Feb 05, 2010 | KitchenAid KEMC308 Electric Double Oven
Light is out in Microwave Oven
You have to pull the complete unit from wall, take top setion apart to get to lamp, do not attempt to change this lamp unless you have knowledge of electricity and what it can do to you if you FAIL TO TURN IT OFF FIRST.
Oct 01, 2009 | KitchenAid KEMC308 Electric Double Oven
KEMC308 has frozen, unusual looking display info. Nothing works.
Try unplugging it or flipping the breaker to the oven. Leave the power off to it for a minute, then turn it back on.
Mar 27, 2009 | KitchenAid KEMC308 Electric Double Oven
Need to replace light bulb in kitchen aid microwave
KitchenAid wants $58 for the replacement bulb. I bought it for $1.99 from www.lightbulbsdirect.com and it works just fine. The Item number is Q5G412V. It is a halogen 5-watt, 12-volt bipen G-4. Replacing the bulb requires some dismantling of the microwave. At first I was nervous about removing so many parts to get to the bulb but in the end it really wasn't so bad. The only tool I needed was a Phillips screwdriver. I surfed the net a eventually found instructions left by a friendly Blogger that guided me through the whole process. KitchenAid engineers were so STUPID when they designed this microwave. It takes two hours to replace a bulb that should take 5 minutes. Oddly enough, replacing the bulb in the normal oven below the microwave oven is a piece of cake.
Jan 19, 2009 | KitchenAid KEMC308 Electric Double Oven
Burnt out light bulb in microwave
well it is an absolute nightmare changing the light bulb in the microwave. you have to basically remove the microwave from the rest of the appliance to get to the light after remove panels and other parts. if you intend on doing this take your time. best solution is to have a repair do it that way if it doesn't work he/she is liable not you. best of luck
Jun 20, 2008 | KitchenAid KEMC308 Electric Double Oven
KEMC308 Microwave oven door
Had the same problem and bought the part online. It's not difficult to replace, simply hold the door by the handle as you loosen the 2 screws. Put the face of the door on the floor and remove 2 screws holding the plastic insert. You will have to remove the front vent panel (2 Screws) just below the microwave door.Then you might have to move the oven vent over to get to the final 2 screws on the bottom of the plastic panel. Once you have the palstic panel off the springs are exposed, simply look at how it is placed in the holder before you remove the damaged one. Replace and then re-assemle the door.
May 23, 2008 | KitchenAid KEMC308 Electric Double Oven
KitchenAid KEMC378 Electric Double Oven Logo
364 people viewed this question
Top KitchenAid Ovens Experts
Marvin
Marvin
jdthefixer
Craig Butler
Craig Butler
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
