Toshiba TV My T set has just dropped about half my channels. How do restore them?
  • meltona Aug 28, 2008
    How do you find out if the TV is on antenna or cable?
  • 520 Answers
Check the to see if your tv is set for antenna or cable reception. Put it on the proper setting.
Posted on Aug 02, 2008
Toshiba LCD TV/DVD 15LV505 lost channels. Rescan = fewer channels. Now in Setup, when I press the remote down-it skips the Channel option. What must I fix/change in Settings to get the Channel option?
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
Dec 08, 2016 | Toshiba Televison & Video
Bbc1 and 2 have disappeared
Hi. If you mean those channels have disappeared, it might mean the cable or satellite company has moved or dropped them. If you don't have a set top box, try re-scanning for channels. If it were the TVs fault, you most likely would lose all the channels.
Mar 14, 2015 | Toshiba 42RV500E 42 LCD TV
How do I return my settings so that i see all my channels?
Cek the main menu and see if your in anntenna mode instead of cable. if so switch to cable and scan and save channels.
Feb 02, 2013 | Toshiba CF30F40 30" TV
TV picture won't come on, just get white static
Hello
There may have some crack or loose to the circuit board during drop. Just get it serviced. No more component should be repalced. Only service should be done. OK.
Feb 03, 2012 | Toshiba Televison & Video
Toshiba Freeview Tv, Model 19A 615 DB. Re-tuning I pressed Menu, Set-up, Restore Defaults, then Yes to delete previous settings, and OK. Absolutely nothing happens, Help please?
hi,
To Re- tune your TV you have to go to the Auto tuning option in the menu. do the following procedure for auto scan all the available channels.
To tune the free view analogue channels do the following procedure.
1. Press the Menu/setup button on the remote.
2. Select Auto tuning and press enter.
3.Select the country and press enter.
4. Select start and press enter.
The automatic tuning will search for available broadcasts and should store the channels in the correct order. During the search the sound is muted. When all programs have been stored, the normal TV screen will appear.
If you can sent your email address through fixya then i will sent the user manual for Toshiba 19A 615 DB.
ok
Sep 07, 2011 | Televison & Video
Toshiba TV sound vanished
It is possible that the TV set has an SAP (secondary audio program) setting that has been turned on. To check this go in the the menu, find audio settings, usually the correct setting for this is Stereo, other setting may include Mono, Surr-Stereo, etc.
Feb 05, 2010 | Toshiba 36A40 36" TV
Help Toshiba TV Problem!!! Background sound
Restore the set electronics to factory defaults. Check manual for location of reset button or contact toshiba for reset protocol
Sep 21, 2017 | Toshiba MK2103MAV 2.1 GB Hard Drive
Toshiba 32AF45 Black Rectangle Issue
go into your menu and find closed caption, someone has accidently set the closed caption mode to text, when the on screen display of channel or volume goes away the box appears. turn off the closed caption feature or switch it to something other than "text" mode, and your box will go away.
Apr 10, 2009 | Toshiba 32AF45 32" TV
Recorder is not showing tv listings
I spoke with Toshiba tech support today (800-631-3811). They have an advanced services team that focuses on TV Guide On Screen. Learned the following:
- The TV Guide On Screen signal is updated 4x / day and is broadcast by your service provider
- The broadcast channel varies depending on what the service provider chooses (though typically a major network or PBS station)
- TV Guide On Screen has been doing some reprogramming and updates recently and this has resulted in many sporadic outages
If you ARE not receiving your listings, it's one of two things - either your DVR or the signal from the cable company.
- If you are having issues, call Toshiba and let them know, they will walk through some basic troubleshooting to narrow down if the problem is the DVR or the TV Guide On Screen signal.
- If the issue is the TV Guide On Screen signal, they will be able to report the issue to TV Guide On Screen and let them know their is an issue.
After that - it's in someone else's hands!
Feb 05, 2008 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
Toshiba TP50f50
unplug the set for a half hour and start over. As long as you did not save the settings, all should be ok.
Sep 14, 2007 | Toshiba 50H13 50" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
