Question about Zanussi ZWF1420W Front Load Washer
Zanussi washing maching keeps tripping trip switch
    Brigadier General:
  • 6,277 Answers
Sorry but with such a major fault it is virtually impossible for anybody on this forum to remotely guess what is wrong with your washer.
It could be internal wiring/plugs sockets, control panel switches, control PCB.
I fear that you only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
Sorry again and good luck,
John C
Posted on Mar 14, 2011
How to reset my zanussi
Switch off the machine for a while. Check for moisture in the panel, check for any capacitor leak in the mains circuit. If you have a multimeter check the voltage to the controller section.
Also check the door switch, the inlet flow valve filter and the connectors.
If all these seems fine there are errors in the controller board section.
Mar 16, 2013 | Zanussi Washing Machines
My zanussi washer dryer keeps tripping the electrics
check ground wire for tightness on plug in and on breaker box.
Mar 31, 2012 | Zanussi ZWD12270 Front Load Washer / Dryer
My Zanussi zwd 1270s washer dryer keeps tripping the MCB and i have no idea why, any help?
Washers take alot of power to run. In the instlation manuel they say to have a dedicated electric line .
i had a problem with mine i had a sump pump and the dryer and washer on the same line and would trip my breakers.
You can run it off another line or extention cord as long as its rated for the needed amps.
Sep 24, 2011 | Zanussi Washing Machines
Zanussi zbf260x built-in oven keeps tripping out
Probably due to a fault on the oven heating element. Check continuity and earth with a multimeter if you can but it's odds on you will need a new heating element.
Dec 26, 2009 | Zanussi ZBF260 Electric Single Oven
Zanussi w1242w takes circuit breaker out when it goes into tumble dry
Here is a tip that I wrote that will help you ti find out why the circuitbreaker is tripping.
Circuit Breaker Keeps Tripping
heatman101
Nov 22, 2009 | Zanussi W1242W Front Load Washer
Zanussi 360 just tripped and now keeps tripping
You will probably find that it is the oven element that needs replacing, located at rear of oven compartment behind rear panel.
Please rate my solution.
Thanks.
Nov 11, 2009 | Zanussi ZBF360 Electric Single Oven
Zanussi IZ16 trips switch when plugged in/turned on?
as you do not mention make /age of machine and was this a sudden fault ? for now best to carry out the simple progress of elimination as to what is causing trip out to operate? start at the plug? check the wires in plug then wiring to machine motor for any damage to wires insulation? have you tried another appliance in the socket ? to see if ok? if trip operates then investigate socket ? any more info ? would help to advise on further options ?
Nov 01, 2008 | Zanussi Washing Machines
Zanussi turbodry w 1042 w
probably short to earth on the dryer elements. to check. take top off, disconnect dryer elements then run on dry program. if the trip stays in, then you have identified the fault
May 16, 2007 | Zanussi FJS1225W Front Load Washer
Zanussi ZWF1420W Front Load Washer Logo
63 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
