Link for all appliance model numbers. Please post your entire model number. After you have clicked on the link below.... Just to the right of the "search" tab click on "help me find my model number" Just click on the model of your choice In either video or image presentation Then please repost the information. Click on the link http://www.repairclinic.com/Appliance-Parts Thanks.... Keith
What are the issues with the unit and why are you questioning the damper door?
Thanks....
Keith
Here is a link for the parts diagram for your controls. Highly unlikely the damper was bad three times.
Look at part number 22 on the prints link I have posted.It is called a thirmistor or temperature sensor.
It tells the control the temp in the fridge section which in turns opens and closes the damper door. Before changing anything else out change this part p/n 12002355 just splice the two wires together after cutting them off the old one. Will not matter how the wires are connected to one another.Part runs around $7.00
Click on the link http://www.searspartsdirect.com/partsdir...
Please post results
Keith
Denese Service Manual for your AFD2535DES is HERE and the test I need
you to do may seem a little hard to do but feel we can identify the problem as either
a=> 67003903 Air Damper or
a 12002355 Thermistor You will need Adobe Acrobat Reader to view these documents. The Adobe Acrobat Reader is available as a free download. I also want you to remove the rear panel inside the back of your freezer and insure that no ice or frost buildup is causing the 67003903 Air Damper to be stuck in the open position. Testing/Check resistance across terminals on the two terminals on the 67003903 air damper. If no resistance across terminals replace damper control. Once you are able to download the Service Manual I will be here explain and to answer any question you have. Thanks, Sea Breeze
12002355 Thermistor
Carl has the compressor been running continuous? Also between the freezer and fresh food compartment you will have a damper control hiding behind the controls. Some have a lever arm that helps adjust the damper to reduce or increase airflow from freezer and it is possible that the damper has become stuck wide open or the lever arm that when you slide the arm to adjust damper has come loose from the damper. Click Here for large photo=> Amana ATB2132ARQ Controls If your thermostat will not turn off then we may have a problem with=> 63001358 Thermostat Control as it could be bad and out of calibration. This is an interesting problem and would like to know what you find and resolve the problem. If this solution is helpful please rate, if not ask until I can help you fix this. Freezing fresh food is not good so I will be here to assist you, Thanks, Sea Breeze
MY MODEL IS AMANA ABB2524DEB , MY SERIAL # IS 10912012EV. PUR. 1/2005
LAST OCT.2010 I BOUGHT A 67003903 DAMPER TO REPLACE A VERY NOISY UNIT THAT WAS ACTING ERRATIC, THE FRIDGE COMPARTMENT TEMPERATURE WAS TOO HIGH .
AFTER 2 WEEKS MY APPL. PARTS DEALER HERE IN NEW JERSEY REPLACED THAT NEW UNIT WITH ANOTHER AFTER THE SAME PROBLEM.
THE FIRST ONE I BOUGHT WAS MADE IN 2006.THIS LAST ONE 2008.
NOW 5 MONTHS LATER I AM HAVING A REPEAT OF THIS PROBLEM WITH THIS PART MADE IN CHINA.
THE ORIGINAL ONE WAS MADE IN 2004 AND BECAME INCREASINGLY NOISY (WHICH AMAMA SAYS IS NORMAL)UNTIL IT STARTED FAILING IN 2010 .
