Question about Siemens Dishwashers
My Seimens dishwasher runs, but it sounds like it cannot grab a vaccuum to drain the grey water at the beginning of the cycle. I ran it for about 10 minutes. The bottom spray arm sprays water a little bit. Not enough to spin. It's like it is at the start cycle and does not go any farther. Help Please
    Problem Solver:
  • 11 Answers
You impeller might have something lodged in it - Not sure if you are a DIY type, but you can remove the cover (might need a hex screwdriver) and see what's in there - I suggest turning off the circuit first before going in there with a screwdriver.
My impeller had a toothpick lodged in it, once that was clear and reassembled, it worked like a charm.
Posted on Mar 14, 2011
The water is no draining completely out of the dishwasher, its's a Whirlpool 980 Deries
If you are handy what you will have to do is unclog it. DO NOT USE DRAIN CLEANER. Pull out the filters, clean out the **** and you are good to go. Once you are done with that run it a couple of times and you should be good.
Oct 10, 2012 | Whirlpool Dishwashers
ASKO 1385 not filling after overfill protection was turned on
If when turned on the dishwasher sounds like it is running the drain pump, and does this in any cycle setting, it is possible that the drain pan below the unit has filled with water. Check this post for more details.
Jun 27, 2009 | Asko 1385 Dishwasher
Water won't go out of the dishwasher
Begin at your sink drain that the dishwasher drain hose connects to. Disconnect the hose and check both directions for anything plugging the connection.
Make sure the drain hose has not become "kinked"
(After you have emptied the water from the dishwasher) remove the lower spray arm and the filter in the sump area. Look for obstructions and remove all debris. Rinse the filter thoroughly and reassemble.
If you dishwasher has a timer on the front of the dishwasher that you can manually turn, start a quick cycle with no DW soap and empty.
Allow the water to run in for several seconds and then manually (slowly, gently) turn the timer knob until the DW should begin draining the DW. Listen closely for the sound of the pump motor running.Is water properly draining out of the dishwasher into the drain?
After you have done these things, please post back here and we can take the next steps. OK?
Apr 09, 2009 | Dishwashers
Bosch Dishwasher Not Draining
Im really not all that familiar with the bosch unit, but a few things i would ck. when you cancel a cycle (it should drain the water) is it humming??? does it sound as if it even trickling into the sink discharge?? do you have a disposer under your sink that this unit drains into, if so remove the clamp and look for possible obstructions right there.Honestly passed this ill have to defer to someone else sorry and good luck
Mar 10, 2008 | Bosch SHU9915UC Dishwasher
18 in dishwasher drains water during cycles
find out how the dishwasher is set up to drain. Pour water into dishwasher 4 or 5 gallons, see if water disappears. if so, your drain is ran wrong
Jan 05, 2008 | Kenmore 15121 Built-in Dishwasher
Asko 1585 Dishwasher
do they flash lik all on one side then the other? Start a cycle, then open the door. Do the lights flash the same way when you open the door as when it stops? if soyou may have a door that needs to be adjusted so it closes better. when the cycle ends, is there any standing water in the bottom? if so you may have a poorly routed drain hose or a partial clog in it. Last, pull the bottom panels off and look inside the bottom of the dishwasher and see if there is standing water down there . If ther is you have aleak somewhere or a bad drain pump. You r only other choice is a bad pressure switch. If youve already adjusted the water fil to the proper level ( just up to the grey plastic housing that the lower wash arm sits on) tehre really aernt any more options. Hope this helps!
Aug 29, 2007 | Asko 24 in. 1585 Built-in Dishwasher
Problem with my dishwasher not draining at all.....
Has this Dishwasher ever drained at all? In installations the need to have a drain line attached to a disposal system is top on the list, how ever some times the connection is made but a small plug in the disposal on the inside of the wall of the grinding chamber has to be knocked out to allow for proper draining of the dishwasher water.
Aug 20, 2007 | GE PDW8200NWW / PDW8200NBB Dishwasher
Dishwashers Logo
208 people viewed this question
Top Siemens Dishwashers Experts
Paul Bade
shaun taylor
Mike
Are you a Siemens Dishwasher Expert? Answer questions, earn points and help others
