Question about Blanco Home
I'm in the North York - Toronto area, I have a blanco double compartment sink, black, it's approximately 15 years old and it has several chips in the enamel or porecelain. Is there someone who can repair this?
  • 528 Answers
If this is a SILGRANIT sink you will need to contact Blanco to find this out they do not reveal the material used in this sink and they may be able to help. This is the web site for Canada.
http://www.blancocanada.com/
Posted on Mar 14, 2011
Postal code for 15 tobermory drive, toronto
There are multiple units at this address. The code for unit 100 is:
100-15 TOBERMORY DR
NORTH YORK ON M3N 2R5
May 19, 2014 | Computers & Internet
My Swanstone sink is sixteen years old and still in very good condition except for a small chip. The sink is a cream color with black and white specks. Is there any way to repair the sink?
You should be able to have a competent repair or restoration specialist from a reputable granite or marble fabrication shop come to your home and fix the problem. If it is a very small chip (less than an eighth of an inch around, my first try would be super glue. Keep in mind the fill will be fairly clear in color, which may match the dark specks, if not use an indelible marker after you smooth the glue to color it black. Use the gel type super glue if it is on a vertical portion of the sink, otherwise use a thinner variety. Clean the chip with sop and water, let it dry then use rubbing alcohol to remove any grease or oil residue. Use a masking type tape to isolate the chip so you have less work once the glue dries. Fill the chip and once the glue is dry, use a single edge razor (Use extreme caution, razors are by nature sharp) to gently scrape, not cut the glue flush to the sink surface. The manufacturers of these sinks claims they are difficult to scratch, but pay attention to your pressure or you might create scratches on the sink itself. Hold the blade perpendicular to the surface of the sink and take your time scraping the dried glue down changing to a fresh blade often. If the chip is in a radius area of the sink, you will have to be a bit more creative and probably use steel wool to remove the excess dried glue. I would start with #000 and see how that works, maybe using #00 to start the process and finish with #000 or #0000 steel wool to match the finish of your sink. If your chip is larger than an eighth of an inch around, I would recommend hiring a repair and restoration specialist from a competent granite fabrication shop to make a color matched epoxy to fill the blemish.
If you have any questions, feel free to contact me, Brandon Wiese - Brandon@StoneRepairman.com - http://www.StoneRepairman.com
Mar 25, 2011 | Swanstone KSDB-3322 Double Bowl Kitchen...
I need a worm gear for modle 009069,i'm in Bathurst.
Here's five address's I've got in your area.
  • Oneida Equipment Limited 20 Lepage Court North York, Ontario M3J 1Z9 Tel: (416) 630-4260 Fax: (416) 630-7203
  • Stephenson's Rental Services Inc. 520 Richmond Street West Toronto, Ontario M5V 1Y4 Tel: (416) 703-0553 Fax: (416) 703-0556 Website: www.stephensons.ca
  • Kooy Bros. 1919 Wlson Ave. Toronto, Ontario M9M 1A9 Tel: (416) 242-3513 Website: www.kooybros.com
  • Chain Saw Clinic Ltd. 2598 Weston Rd. North York, Ontario M9N 2A9 Tel: (416) 244-5678 Fax: (416) 244-5677 Website: www.chainsawclinic.com
  • Chauncey Builders' Supply Inc. 69 Chauncey Ave. Etobicoke, Ontario M8Z 2Z2 Tel: (416) 239-1187 Fax: (416) 234-1508 Website: www.chauncey.net/
If they can't help, go direct at: http://www.stihlusa.com/contact.php Hope this helped. Please rate this response if it did. Thank you
Mar 18, 2011 | Ryobi 45IN ANGLE GRINDER
Where can i buy a replacement caraffe in toronto?
hello,
you can get your caraffe replacement in this following place in toronto there web site is www. appliancecanada. were all part are available also in good quality like Electric Cooktops · Gas Cooktops. Microwaves
and also there Sales centres are located in. Toronto and London, Canada. ... Scarborough, North York, Barrie, Vaughn, London, Woodbridge, Pickering, Whitby, Ottawa, Kingston, North York, Hamilton, ...
www.appliancecanada.com/
thank you and good luck.
Jun 11, 2010 | Oster HDX23 12-Cup Coffee Maker
I have a vulcan wall heater with serial number 44674 made in 1981, needing to replace the fan as it's not blowing out hot air...Where can I find this part?
hello,
all Appliance part can be fine in various shop around you, our website www. appliancecanada. com is full of Electric heater Electric Cooktops · Gas Cooktops. Microwaves ... Sales centres are located in. Toronto and London, Canada. ... Scarborough, North York, Barrie, Vaughn, London, Woodbridge, Pickering, Whitby, Ottawa, Kingston, North York, Hamilton,e.t.c.
thank you and thanks for using fixya.
Jun 09, 2010 | Heating & Cooling
Where is area code 416?
areacode 416 is in the following locations:
East York, ON
Etobicoke, ON
North York, ON
Scarborough, ON
Toronto, ON
York, ON
Feb 19, 2009 | Innovage 69420210126 Phone
Home Logo
287 people viewed this question
Top Blanco Home Experts
J.D. Browning
J.D. Browning
Tom Chichester
William Smith
William Smith
Are you a Blanco Home Expert? Answer questions, earn points and help others
