Question about Compaq Armada M700 Notebook
Installing a Seagate Dive into an Armada M700
Experts,
I own a Compaq Armada M700 PIII notebook and want to install a bigger hard drive. Currently this computer has a Toshiba MK6014map drive in it. It todays world 6gb is not enough drive space. I have purchased a new Seagate Momentus 5400.2 to upgrade. I have talked with Compaq and got nowhere, so now I came here hoping to find an answer.
I currently have Win XP Home installed on the 6gb drive and would like to install Win XP Home on the 60gb drive. I am running into problems though. Windows can not install XP on this drive. The seagate drive is fine. I have tested it throught seatools and have formatted it through both Disk Management in Windows and also Seagate Disk Wizard on different occasions. When I try installing Win Xp I get the following message:
*****Your computer's startup program cannot gain access to the disk containing the partition or free space you chose. Setup cannot install windows xp on this hard disk.
This lack of access does not necessarily indicate an error condition. For example, disks attached to a SCSI adapter that wasn't installed by your computer manufacturer or to a secondary hard disk controller, are typically not visible to the startup program unless special software is used. Contact your computer or hard disk controller manufacturer for more information.
On x86-based computers, this message may indicate a problem with the cmos drive type settings. See your disk controller documentation for more information.*****
I have attached the drive to the computer via usb hard drive enclosure and works great as a mass storage device. When I try it in the hard drive bay, I get controller error. Compaq and Seagate claim you do not need a driver for this. My Bios is current based on the last release. A compaq tech said this drive is compatable with this type of computer and claims he had a successful install on another computer. My computer has a PIII 850mhz Intel board in it. I did some digging around the intel site and have not found anything relative to my situation yet. I do beleive it is comming down to a driver problem or an upgrade to the controller. As you can see this is frustrating. Please help.
B Patterson
348patterson@excite.com
    Genius:
  • 2,028 Answers
Here at my shop I have run into this exact same problem on several P3 Compaq's and a few Toshiba's. I found that some of these machines, not all, but some, will not accept the 5400RPM drive, but will take the 4200RPM drive just fine. It's just weird because some that do are the exact same model, and I'm not real sure why it won't accept them. I've looked into it and the best that I can surmise is that 5400 is too fast for the reading system in the bios, or it's a power issue. Go with a 4200RPM drive and you shouldn't have any problem. You won't be able to tell any difference in the machine's performance between the two RPM speeds.
Posted on Aug 01, 2008
Bios Issue/Hard Drive Upgrade
i have installed a 60gb hdd into an m700 without even having to stuff with the bios...
Xp sp2 allows you to install larger drives then the bios reccomends.
Feb 18, 2009 | Compaq Armada M700 Notebook
Installing wifi in Compaq Armada m700??
yes, aslong you have USB port or PCMCIA card slot
if your compaq armada m700 is the p III series it's alot better
Jan 25, 2009 | Compaq Armada M700 Notebook
Armada M700 & Linux XP 2006
Yes I used the latest version of Ubuntu Linux.
Get it here
Ubuntu 8.10
You will need to install NDIS in linux after the install to use the windows drivers for your wireless card if you have one. Sometimes older wireless cards will work but most of the time you need the NDIS to use the windows disk that comes with your wireless device(if you are using one) Your hard wired ethernet port should be detected automatically as well as all your other drivers(since the machine is old)
Good luck..if you need any more help I will be around. No other compatibility issues exist, and it will run a lot faster than XP. I would suggest 512MB of Ram but 256 will handle it fine.
Oct 14, 2008 | Compaq Armada M700 Notebook
Fujitsu Drive installation on Armada M700 Laptop
I would stay away from fujitsu hard drives. They are complete trash. I would stick with either Seagate Western Digital or IBM. I have the hitachi that came with the machine and although it is slow it still works after over 10 years. I would like to know more about your situation if you need help installing it tell me what it is doing.
Sep 17, 2008 | Compaq Armada M700 Notebook
Controller Driver Issue on Armada M700
I am running a Armada M700 with a Hitachi HTS541060G9AT00 60GB Hard Drive - Ultra ATA-100, 5400 RPM, 8MB. The driver that is loaded in mine is on both primary and secondary is atapi.sys. This driver is also installed on the Intel 82371AB/EB PCI Bus Master IDE Controller, along with intelide.sys. The main difference is I am running Window XP Pro SP2. But I believe that they should use the same driver.
Hope this helps.
dferguson64
Sep 09, 2008 | Compaq Armada M700 Notebook
Compaq Armada M700
Try this: Remove the power adapter and battery from the laptop.
Press and hold the power button for up to one minute to discharge the laptop. Try starting it.
Jun 02, 2008 | Compaq Armada M700 PIII 700Mhz/ 128MB/ 12-...
Looking memory
Compaq Armada M700 - PIII 650 MHz
Ram Installed Size: 64 MB ( 64 MB soldered) / 576 MB (max)
Technology: SDRAM
Form Factor: SO DIMM 144-PIN
May 18, 2008 | Compaq Armada M700 Notebook
Bios password
Is there a removable bios battery? If not, try removing the regular battery for a day or so to try and clear out bios.
Apr 25, 2008 | Compaq Armada M700 PIII 700Mhz/ 128MB/ 12-...
Compaq armada m 700 was not show battery no go with battery
In ur laptop,U click on Control Panel - Power options.Click on Power meter.There u select the battery show option.
I go for this web address.www.hpfashinontronics.com
U can Laptop skin order through online also.
Oct 31, 2007 | Compaq Armada M700 PIII 700Mhz/ 128MB/ 12-...
CPU Upgrade Help Compaq M700
You might want to check this out I think it answers the questions you are asking? http://h18000.www1.hp.com/products/quickspecs/10382_na/10382_na.HTML
Sep 30, 2007 | Compaq Armada M700 Notebook
Compaq Armada M700 Notebook Logo
162 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
