Question about Mitsubishi Televison & Video
I just recently bought a mitsubishi tv cs-32507 and all i can get it to do is show a blue screen.
  • 164 Answers
The blue screen means there is no video signal, make sure you have your cable turner/dvd/bluray/home theatre/etc. plugged in and turned on connectors. For refference check your user manual.
Posted on Mar 14, 2011
Mitsubishi pip intermittant
yes can be fixed. However you must go to the repair shop TV, or get some service manual for your model. You can find it and buy it from Howard Sam. you can look in the internet search the web page.
God bless you
Sep 27, 2012 | Mitsubishi CS-32507 32" TV
Can get my dish network to come in on channel 60 which atenna should i use a -b?
Hello, this is fairly simple to solve. There are a few approaches that you can take for this issue. If this has already been resolved, great!, but if not, here are the steps. You can follow this link to change the setting for the second tv. If your tv goes up to channel 73, that is what you will want to put the setting to. http://www.dishnetwork.com/SupportSection/black-blue-tv2. Another option is to use the antenna b on the back of the tv. Or you can try to put the tv onto channel 116, 21, or 22. If you have any other issues, you can e-mail me at becki.barned@dishnetwork.com. Hope this helps!!!!
Becki Barned
DISH Network Customer Service
Nov 29, 2010 | Mitsubishi CS-32507 32" TV
Oversized picture problem
Several possibilities, if you use a set top box to get your signal like a cable box or satellite receiver they will have settings that effect picture size. It could be a high voltage problem inside the TV causing an effect called blooming, if that is it you can usually change brightness and or contrast and see the picture get smaller and larger. I don't recall that set having any customer settings that could give that symptom.
Sep 11, 2009 | Mitsubishi CS-40503 TV
My tv is shows a blue screen. My tv does not respond to the function button's and there is a lock in the upper left hand corner of screen of JENSEN 27" tv
To remove the lock on the Jensen simpy press and hold the Display Button on the remote for at least 3 seconds whilst pointing it at the TV.
The lock will be removed and the TV will resume normal operation.
Please do leave a vote for the solution. Thanks for using FixYa
Jul 03, 2009 | Mitsubishi CS-26201 TV
Narrow blue horizontal line across screen on intial power up
You have trouble with the vertical deflection circuitry. Probably something in the driver circuit or power supply to the driver. Maybe even a cold solder joint since it comes up after a little warmup.
Jan 17, 2009 | Mitsubishi CS-40503 TV
1995 Mitsubishi 40" Television - Worth Repairing?
there are bad solder connections on the vertical deflection IC resolder them and you will be fine
Mar 13, 2008 | Mitsubishi CS-40503 TV
Blue Screen/Waviness
sounds like convergance ic's mits is also know for bad caps
1000uf @ 16v check for bulges on top of the cap
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 05, 2008 | Mitsubishi WS-55809 55" Rear Projection...
S-Video on the blue screen
menu has input selection to turn on/off or name video inputs.....T.
Oct 24, 2007 | Mitsubishi WS-48311 48" Rear Projection...
Mitsubishi CS-27405 no picture but sound
your problem is the PIP board,tough to repair,can be taken out and replaced with two 10 mfd caps 50v bipolar from pin5 to 11 and from pin 7 to 9
Sep 27, 2006 | Mitsubishi CS-27405 TV
Televison & Video Logo
103 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
