Question about Indesit W 123 Front Load Washer
My washing takes the water but stops as soon as it is supposed to drain the water out. The on-off light stops blinking. The timer rotates without any effect. However, the sipnner works if the timer is set for the spinner, but without draining the water. I have already cleaned the filter and pump. It seems nothing is stuck there. I would highly appreciate your advice. Regards, Amar Netherlands
    Brigadier General:
  • 6,277 Answers
Have you been able to check if the drain pump is actually working when it should? If not, whilst the filter is removed, it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger with the power OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
John C
Posted on Mar 14, 2011
My dw80j3020 dishwasher wont drain.It goes through the wash cycle then stops. Two lights are blinking. Heavy and auto. When I open the door the bottom of the dishwasher is full of water.
Machine is supposed to drain the water out. If the pump is not working or not getting energized that will cause your situation.
Sep 01, 2017 | Dishwashers
Washing machine spins but won't drain!!
what make is the machine,kenmore,ge
Jun 19, 2009 | Washing Machines
Washing machine stops on spin cycle
You need a new drain pump.
May 04, 2009 | Washing Machines
Washer agitates, drains OK, but spin doesn't start
Timer is defective. Your unit has a netural drain. When finished agitating, the shuts down and then starts up reversing to drain and spin. On the initial reverse start, the water drains without the transmission spinning. After a timed period 3-4 minutes, the timer is supposed to pause, stopping the motor for a few seconds. When the motor stops again, the transmission shift to the spin cycle and when the timer resumes power tothe motor it should spin. You are doing the same thing when you lift the lid...stopping the timer and then the tranny shifts and when you set the lid down, the washer spins. Replace the timer.......
Feb 09, 2009 | Kenmore 23822 Top Load Washer
Soon as i set cycle and swich on door light flashes open
hi,
The cycle doesn't advance
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Thanks for your question.
Jan 03, 2009 | Ariston Technologies AW129NA 16 Lbs Front...
Flashing lights on Rince, Start & 0 speed.
washer think there water over fill to clear this u need ruin a diagnostic test. think of timer knob light a clock straight up being at 12 oclock an one click at 1oclock to enter the test first rotate knob to any postion except postion 6 staight down press start and fs button at same time wait 3 seconds an rotate knob to to postion 6 wait 3 second then release both button , all light should blink . you should now be in test , rotate knob to various postion to test wash cycle an rinse an spin postion 9 an 10 are the waster valve onces the test finish tun the knob to another postion to turn test off an unplug washer an plug bach in this should clear it . if still have a porblem call a applince service ok
Dec 13, 2017 | Whirlpool AWM6120 Front Load Washer
No rotate, no cyclation, no spin, just fill water and drain
Sounds like the washer lid switch may be defective, access the switch and jumper it to see if that is the problem,
Apr 30, 2017 | Washing Machines
Washing machine won't drain or finish cycle
It sounds like you have a drain pump stopped up or failed. Do you hear any noise when it is supposed to be draining? A humm or buzz?
Oct 31, 2007 | Fisher and Paykel GWL11 Top Load Washer
Indesit W 123 Front Load Washer Logo
80 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
