Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Why does the brake pedal "jump" back and forth when I start the engine? It vibrates back and forth. Thank you for considering.
I have a 2006 pacifica that the shifter will not move out of park. when I push on the brake I can hear like a relay sound inside the console but the shifter will not move from park. Also my check engine...
Hi Mitch:
Sounds as if you have several problems. I'll try some ideas for you to consider.
SHIFTER LOCKED- Will engine start? Try starting engine, press on brake pedal, gently turn steering back and forth while trying to move shifter.
MISFIRE # 6 - Check wiring components. Spark plug tired, plug lead wire mar be shorting out.
Mar 11, 2015 | 2006 Chrysler Pacifica
Snapper mower
If the hand brake is on that will also kill the engine.
Oct 30, 2017 | Snapper Garden
Just took car into service center. they mentioned there was a heavy vibration when the car is in idle, never noticed it too much before. now I notice it constantly and when I turned the car on today it...
not CLIPS,, never heard of engine CLIPS,, you do have motor mounts @ transmission mounts that if bad,,they wiil create vibration in steering wheel if in park while in park or drive or reverse while car is still @ being shifted back @ forth from reverse or drive. here's a soltion for you! while hood is up,engine running,EMERGENCY BRAKE IS ON !! while somone is looking at motor while you shift car from drive to reverse back@ forth,, does motor JUMP and rock back and forth? IF so you have a bad motor or transmission MOUNT and I'VE never heard of CLIPS. hope this is some help..suggest you always get 2nd opinion
Sep 19, 2010 | Hyundai Motor 2004 Sonata
I have a 1997 grand prix. Most days it starts. once in a while it will not start. You can sometimes rock key back and forth quickly and it will catch. But most of the time odly enough wait over night and...
When you turn the ignition key to start your car, voltage from the battery flows through the ignition switch to the Park/Neutral safety switch and/or brake pedal or clutch pedal safety switch (you have to push the pedal down before the circuit will complete) to the starter relay or solenoid. When the relay or solenoid is energized by voltage from the ignition switch circuit, it closes a contact that routes more power from the battery directly to the starter to crank the engine. The starter motor spins, pushes the starter drive gear to engage the flywheel and cranks the engine.
Low battery (Check battery voltage, recharge if low, or jump start with another vehicle or battery charger).
Loose or corroded battery cables (Inspect, clean and tighten BOTH ends of BOTH battery cables).
Bad starter relay wiring connections or ground connection (Inspect, clean, tighten wiring connections).
Bad starter relay/solenoid (Check for voltage at relay, if relay has voltage but there is no "click" when key is turned to start, replace relay).
Bad starter (Jump battery voltage direct to starter to see if it spins, or remove starter and have it bench tested at auto parts store).
Damaged starter drive or teeth on flywheel (Remove starter and inspect drive gear and flywheel teeth, replace damaged parts if necessary).
Bad ignition switch (Check to see if voltage reaches starter relay/solenoid when turn to start. If not, check for open P/N switch and brake or clutch pedal switch. Replace ignition switch if defective).
Open P/N safety switch, or open Brake Pedal Safety Switch (automatic transmission) or open Clutch Pedal Switch (manual transmission). Bypass switch with jumper wire to see if engine cranks, or use test light or voltmeter to check for voltage passing through switch when ignition is turned to start.
Engine seized due to bearing failure or internal damage (Use socket and long handle to see if engine can be turned by hand, if not engine is locked up).
Engine hydrolocked due to coolant leak from leaky head gasket (Use socket and wrench to see if engine rotates, remove spark plugs and see if coolant comes out or engine can not be cranked with plugs out).
Jul 14, 2010 | 1997 Pontiac Grand Prix
Vibrates
my 2000 mustang 3.8 also had a bad vibration. after many trial and errors we replaced the harmonic balancer..not too hard but requires the "special" tools...and you have to buy it from the manufacturer. my car ran like a dream.
Feb 07, 2010 | 2000 Ford Mustang
On my 2005 subaru legacy outback 2.5l replaced passenger side cv axle. now while driving the vehicle i come to a stop light or stop sign foot on brake pedal engine makes cavitating noise and feel the...
If I understand you correctly, you feel a vibration it the brake pedal when you apply the brakes. Is that correct?
Have your brake rotors re surfaced; they are warped.
"engine makes cavitating noise" ....what does this mean?
Apr 21, 2009 | 2005 Subaru Outback
96 GC Orvis-Severe vibration in Idle.
Before you go changing the idle motor, clean the throttle body out with a spray cleaner and make sure you get into the idle speed motor orifice. Spray the cleaner into the throttle body with the engine off, do'nt be afraid to use it all then let it sit awhile. When you try to start the car it might not want to start, just keep your foot all the way down on the gas pedal and as it starts and clears up just release the pedal slowly. If the car smokes out of the exhaust, thats normal. Hope this works.
Jan 23, 2009 | 1996 Jeep Cherokee
Vibration on fuel pedal of 1999 suburvan
This may be caused by bad motor mounts. Lift your hood and then start the engine. Put it in reverse and hold the brake. Push on the gas peddle and watch the engine. If it trys to roll over they may be bad. Be careful.
Dec 13, 2008 | 1999 GMC Suburban
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
37 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
