Question about Foxconn A6VMX Socket AM2+ AMD Motherboard (683562102995)
All devices is working but It has no video signal to monitor and it shuts down only by unpluging the power cord
  • Foxconn Master
  • 3,606 Answers
Check your bios for onboard vga settings.
Here is your product home page for driver download and manual:
http://www.foxconnsupport.com/download.aspx?models=en-us0000346&category=C000000001&series=en-us0000008&keywords=&sort=Drivers
Hope this was helpfull.
Posted on Mar 14, 2011
Why does my computer say no imput signal
If you have used a desktop computer or have a dual-monitor setup, you have likely seen the "No-input Signal" error message on your computer monitor. The error message may point to a number of culprits. Accordingly, the solutions run from simple to complex. Prior to attempting advanced troubleshooting methods, check the connection first. Power off the computer and the monitor. Remove the cable that connects the monitor with the computer, then reseat it. Try a different port, if possible, then reboot the computer.
Connect the monitor to another computer if possible to eliminate the monitor as the faulty hardware. Shut down the computer. WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove all cables and devices plugged into the computer. Make a note of the port into which your monitor is plugged. Remove the left side panel when facing the front of the case. Unscrew screws or manipulate latches to remove the side panel. This process varies according to the type of case you have. Please consult your manual if you are unsure of how to remove the side panel. Attach the antistatic wrist bracelet's clip to a metal object, then ******** the bracelet. Locate your video card. (This will be the card that contains the port with which your monitor interfaces.) Remove the slot cover screw that secures the card into the slot. Remove any power cables that connect the video card to the power supply. Pull the card out of the slot. Examine the gold pins to check for any damage. Reseat the card if it physically appears to be undamaged. You should hear a click once the card is secure in the slot. Screw in the slot cover screw. Attach the power cable from the power supply unit, if applicable. Leave the case open for now. Reconnect only the monitor, power cable and any devices required to boot the computer, then restart the computer. Shut down the computer again if you receive the "No-input Signal" error message again. Remove any cables and devices you plugged in to restart the machine. Remove the video card with a spare or replacement by following the instructions above. Connect necessary cables and devices to reboot the computer, then restart it. Shut down the computer and remove cables and devices if the display still won't work. Unplug the power supply's cables from all devices on the motherboard. Make a note of each plug-in so that you can correctly connect all devices with the new power supply. Remove the screws that mount the power supply. Fit the new power supply into the mounting area, and screw in all screws. Attach all required power cables to devices connected to the motherboard. Attach the cables and devices required to start the computer. Reboot. Hope this helps.
Dec 07, 2012 | Computers & Internet
No signal or network problem
Shut down the computer. Remove all cables and devices plugged into the computer. Make a note of the port into which your monitor is plugged
hope it can help you ma-friend
Aug 11, 2011 | Dual Computers & Internet
When I connecetd to a PC I can see "Test OK" on screen. But can't see anything. Please help
disconnect the plug, assuming it's a dvi plug if it;s a vga standard plug the idea is the same unplug it with the computer running and see if plugging it back in dose anything. no? ok shut off the monitor and the computer completely, unplug the monitor for 15 seconds, plug the monitor in first, now power up the computer and see if the wake signal is sent to the monitor, if it is then the monitor will power up as normal and All's ok, if not then theirs a possibility that the video signal is not coming from the video card, some cards are external agp cards, like higher end cards, they require a significant amount of power to run properly, and will fail if not powered up, test this by unplugging things not necessary to boot the pc. and see if it starts up, chances are you have a inboard video card and a external video card, if so plug the cord into the internal card first and enter the bios settings, from here check that the inboard video settings are disabled, this way you can plug back into the external if it is indeed external.
Dec 14, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
I have a sonicview monitor vx2235wm. I unplugged it from the computer and moved the computer. Now that it is plugged back in it says ''no signal digital'' I moved another monitor to it and it says the same...
I hate to sound like a dip stick but, you did connect the power cord to power did you connect the monitor to the computer? Was the light on on the monitor? was it blue? Was it orange or red? Did you press the power button on the monitor? Try those things, most generally people forget to either install the cords properly or power up the monitor. Once the monitor is powered you don't normally have to do it again. Hope this works for you. If not send me an email and we can try something else.
Nov 06, 2009 | ViewSonic VX2235WM Monitor
Dell e137fp monitor flashing green...
Below you will find my recommendations for troubleshooting this issue:
1. Reseat the power cord and verify a good power source.
To reseat the power cord, follow the steps below:
1.1 Power down the system.
1.2 Unplug the power cord.
1.3 Wait approximately one minute.
1.4 Reseat the power cord.
1.5 Verify that the power cord is plugged directly into a known good power outlet.
2. Verify that the monitor is receiving power from a known good outlet and bypass any power strips.
To test the power outlet, perform the following steps:
2.1 Unplug the monitor power cable from the power outlet.
2.2 Plug in a different device, and verify that the device is operational.
2.3 If there is no power try another outlet. Remove any power strips and try plugging directly into the main power outlet.
3. Verify the monitor is powered on and the power button is engaged.
Ensure that the monitor is powered on and that the power button is fully engaged. To do so, check the power LED on the front of the monitor; it should be lit.
NOTE: There are two types of power switches:
A mechanical switch characterized by a long travel. You have to push it further and you will hear an audible click.
An electrical switch that has a short travel and almost no click.
A lit monitor LED can be any of the following:
* Green
* Blinking green
* Yellow
* Blinking yellow
* A combination, such as alternating green and yellow
Any of these states indicate the monitor is receiving power and that you should proceed.
4. Swap power cables.
To try a known good power cable on the monitor, follow the instructions below:
4.1 Turn off a working monitor.
4.2 Unplug the cable from the back of the working monitor, and unplug the cable from the wall.
4.3 Unplug the cable from the monitor in question.
4.4 Plug in the cable that came from the working monitor.
5. Run the monitor self test.
To run the monitor self test, perform the following steps:
5.1 Power off both the computer and the monitor.
5.2 Unplug the video cable from the computer or video card.
5.3 Reseat the power cord to the monitor, ensuring it is plugged into a known-good outlet.
5.4 Power on the monitor.
NOTE: The monitor self test will move around on some monitor models. If the monitor self test moves, allow it to move to the affected areas of the monitor to check for the problem described.
If the Self test failed, it's possible that the monitor is faulty. Contact dell to check if it's still under warranty so they can replace it.
Jun 15, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
Monitor not seeming to work when computer is powered up.
Hi there!
Try reseatting the video card and clean the video card if needed and the memory module.
Mar 07, 2009 | Computers & Internet
Montiors shut off
if the monitor goes into standbye when you plug it into the computer , it generally means there is NO signal coming from your video adaptor.
Plug the old monitor in , if it works, ide suspect the new monitor(s) are not working correctly.
if it doesnt work , you need to restart the computer in safe mode by repettitively tapping the f8 button as the computer starts, before it says "starting windows".
If you have a signal on your monitor in safe mode, then most likely you have a bad or corrupted video driver and it will need to be updated.
if you have no video in safe mode , you will need to remove the cover and physiclly check that all add-in card power cables and memory chips are squarly seatied in there slots. MAKE SURE YOU UNPLUG THE COMPUTER AND DISCHARGE ANY STAIC BUILDUP IN YOURSELF BY GROUNDING (TOUCHING) SOMETHING METAL BEFORE YOU TOUCH ANYTHING INSIDE THE COMPUTER.
AFTER YOU CHECK THESE THINGS AND TRECONNECT THE POWER AND TRY TO START......POST AGAIN HERE
Feb 18, 2009 | Systemax Venture PC Desktop
The screen in blacked out but computer is on and monitor powered
Shut down the PC, unplug the power cord and press the power button to discharge the mainboard, wait several minutes and reconnect the power cord and power system up. Even if this works there still may be a video card and/or other hardware problem.
Jan 21, 2009 | Samsung SyncMaster 912N 19" Flat Panel LCD...
Monitor powers down upin startup
you need a new video card. it is powering down becuase it is not reciving any signal from you computer. if you are useing onboard video (vga) get a pci video card if you are useing a pci card try puting it in a dfrent slot.
Dec 20, 2007 | Gateway 310S (2900621) PC Desktop
Sceptre X7g Monitor Flashing Red & Blue Lights. Blank Screen
i fixed this problem by unplugging the monitor, unplugging the video cables. Then hold down the power button while plugging it back in. Release power button and then press power button for on. It worked then. I got the icon for no signal, i plugged back in my monitors. Sceptre X9W
Sep 11, 2007 | Sceptre X7GNAGAV 17" LCD Monitor
Foxconn A6VMX Socket AM2+ AMD Motherboard (683562102995) Logo
105 people viewed this question
Top Foxconn Computers & Internet Experts
Rommel Balcita
David
David
Gareth Cockram
Gareth Cockram
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
