Question about ViewSonic PJ501 Multimedia Projector
"clean and reset filter" alert is displayed even
  • 24 Answers
You can reset the "Filter Time" on your projector and it will clear this error out of the system.
1) Clean Filter
2) Turn the power on
3) Hit the Menu button
4) Once the menu appears choose "Options"
5) Choose "Filter Time"
7) While the time is displayed hold the "Reset" button on the remote for 3 seconds
8) The "Reset" menu will pop-up and choose reset.
That should take care of it.
Posted on Mar 15, 2011
I have a problem with my Canon LV-7265 Projector. When I turn it on, a message appear "please clean the filter" with a blue windows! Please help me how to fix this problem. I try to clean 2...
You need to go into the settings menu and find the lamp reset and filter reset area, sometimes when you get to the reset part you hold down enter then an additional box may show reset/OK, select OK which should reset the filter hours. Most projectors have the filter reset but sometimes resetting can be difficult to work out. I had an old NEC where you had to hold down the on button of the remote for ten seconds to reset.
Hopefully this helps. There may be support from the manufacturers website plus downloadable user instructions.
Good luck
Aug 04, 2011 | Canon LV-7265 Projector
After turning on the projector, I get a message that says clean the filter and reset the timer. How do I do that? I have cleaned the filter.
Procedure for resetting filter time.
Pressing the RESET button for about 3 seconds displays the FILTER TIME menu. Select the RESET using button to reset the timer. : RESET <- CANCEL Selecting the RESET resets the count of the lamp timer to 0. memo Perform this function only when you have cleaned or replaced the air filter. The filter timer counts the used time of the air filter after cleaning or replacement, to display the messages about the air filter. Incorrect performing causes incorrect operation of the messages. memo About caring for the air filter, please refer to the section "Air Filter".
Users manual located here. http://www.aboutprojectors.com/pdf/hitachi-cp-x1250-manual.pdf
Good info deserves a good thumbs up! Thank you!
Mar 01, 2011 | Hitachi CP-X1250 Multimedia Projector
Viewsonic projector pj501 - Has purple bloch with
2 issues- the light filter on one of the lcd panels is burnt due to excessive dust and heat. and one of the lcd panels is shot. time to replace the entire optical engine, unless you can get the prism assembly. otherwise, replace the projector. if you do, remember to keep it clean.
Nov 17, 2009 | ViewSonic PJ501 Multimedia Projector
Lamp and temp lights are flashing while in operation
clean out the projector with canned air. the dust is keeping in the heat and the lamp can't cool down. check the fans, too. check the lamp timer. if it's close to 2000 hours, replace the lamp and reset the timer.
May 11, 2009 | Office Equipment & Supplies
Picture or screen displays multicolours : The screen looks bluish with mixed patches of light yellow,purple and grey colours; as though the lens or bulb were wet. Still getting alerts to clean air filter...
Dont use a damp cloth. Use an air hose or can air if possible.
The color differences may be your color wheel and not your
air filter. You may have to reset the projector to clear the alerts, just hold both volume buttons for 5 seconds. I've found its usually 30 seconds
Hope it helps, good luck
Apr 07, 2009 | Office Equipment & Supplies
How do I clean the filter?
www.berkley.k12.mi.us/file_repository/id2651vt580%20manual.pdf
Look at maintanance - Cleaning or replacing the filters (page 49)
Make sure you also clear the "filter hours usage" indicator. It is in the same manual on page 48.
Mar 16, 2009 | NEC MultiSync VT580 Multimedia Projector
Dvd player to projector
Yes please.
You can connect it either thru the RCA Composite output(yellow) of your DVD or thru the S-Video or even thru the component out(YPbPR) connections. In the component out you would require three RCA cables and would give you the best possible picture.
Find a link below , which gives a review of the Viewsonic PJ 501.
http://reviews.cnet.com/home-theater-projectors/viewsonic-pj501/4505-7858_7-20722971.html
Hope this clarfies.
Please do rate this solution and thanks for using FixYa!
Mar 04, 2009 | ViewSonic PJ501 Multimedia Projector
Resetting Air Filter Timer once cleaned.
Menu, options, filter time. When the filter time is displayed, press the reset button for at least 3 seconds. The reset menu will appear and you can select RESET.
Feb 01, 2008 | Hitachi CP-X385 Multimedia Projector
Clean Filter Signal continues to appear even after the filter is cleaned.
you have to reset the filter in the controls or it will continue. i cleaned it everyday for a week until i got fed up and went into the last setting (by the lamp hour reset) and reset it. good luck
Dec 06, 2007 | NEC VT470 Multimedia Projector
Can not clear filter hours
On the filter menu, hold the reset button down for five seconds.
Sep 10, 2007 | Hitachi CP-X328WT Multimedia Projector
ViewSonic PJ501 Multimedia Projector Logo
1,038 people viewed this question
Top ViewSonic Office Equipment & Supplies Experts
jasbo
jasbo
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
