Question about Toshiba Computers & Internet
How can I get my toshiba laptop to show on an interactive white board. I tried FN and F5 together but it doesn't work.
  • 41 Answers
If it has an ATI driver. You can try ctrl, alt and F12 and choose multiple monitors.
Posted on Mar 17, 2011
Fn f5 dosent work
Does your laptop have a Bluetooth card installed? Just because it shows on the keyboard doesn't mean its fitted.
Jul 08, 2012 | Computers & Internet
Tip
How to turn on Wireless Switch on your Laptop or Notebook PC
How to turn on the wireless switch on the laptop or notebook
If you have issues in finding the wireless switch on the laptop to turn the wireless on you can refer the below list
1. Dell D600 & D610-Key Board-Fn+F2
2. HP NC4000 & NC4010-Button-Above Keyboard
3. HP NC4220-Button Left Side of Laptop Near USB Port
4. HP NC6000 & NC6220-Button above Keyboard
5. HP NX9010-Button in front side of laptop
6. HP Omni book 6200 Button on Left side of laptop
7. IBM T43 & X32 Keyboard combination Fn + F5 then Click "Turn On"
8. Toshiba M1 & M2 Switch Left side of laptop towards
front
9. Toshiba R100 Switch on the Right side of laptop
10. Toshiba TE2000 Switch on the left side of laptop by Volume ctrl
11. Toshiba Tecra 2100 Switch Left side of laptop by Volume ctrl
12. Sony Vaio - switch on front left
13. Dell - FN,F2 or FN,F8 or FN,F12
14. Acer - FN,F5
15. IBM / LENOVO
IBM General - Some models have the wireless slide button on the side of the laptop.
IBM DV series - use the antenna-like button found on the upper section of your keyboard.
IBM R40 - Use the FN+F5 key-combo.
IBM ThinkPad (General) - Most have software switch or button on Left hand side.
Lenovo T-61 - Slide button on the front of the laptop
16. MEDION
General - Fn+F1 or Fn+F2
17. MSI
General - Antenna-like button close to the power switch
U100 - Fn+F11
18. PACKARD BELL
Easy note B3600 use the Fn+F1
Easy Note E2/MV46/008 - Fn+F1
Easy note W7730, Antenna-like wireless button on the side of the laptop.
MZ36-U024 - Fn+F2
19. PHILIPS
General - Fn+F2 key combo
X54 - Antenna-like button close to the power switch.
20. SAMSUNG
General - Blue button found in the middle section of the keyboard
on Dec 03, 2009 | Computers & Internet
How do i turn on the wireless device
First, make sure that the wireless switch on the computer is ON, usually found on the sides of the computer. Press Fn+F5 together then release both buttons.
>Fn+F5 enables/disables your computer's wireless capabilities.
Oct 17, 2010 | Toshiba Computers & Internet
When I power on my computer my monitor screen goes a solid whitish gray. worked fine yesterday, and then today nothing.
Laptop LCD screen turned completely white
What can you do if the laptop LCD screen turned completely white? From my experience I can tell that this problem may be related to the following:
1. Loose connection between the video cable and the LCD screen.
2. Defective LCD screen.
3. Defective motherboard (I assume the graphics card is integrated into the motherboard).
When you turn on the laptop, it starts but the image on the screen is completely white right from the beginning.
Most likely you still can use the laptop with an external monitor. Just connect the monitor to the VGA port on the back or side of your laptop and then switch the video output from internal to external mode.
On Toshiba laptops you can toggle between internal and external screens using Fn+F5 keys. Hold down Fn and press on F5 until you get video on the external monitor.
On IBM laptops use Fn+F7.
On HP laptops use Fn+F4.
It’s possible that you have to use a different key combination on your laptop but you get the idea.
On some laptops, in order to be able to use the external monitor, you have to connect it to the laptop and then restart the laptop so the external monitor is detected by the laptop.
I noticed that in some cases the laptop screen may turn white because of poor connection between the video cable and the LCD screen. If you want to check this connection, you’ll have to take apart the display panel because the connector is located on the back side of the LCD screen.
I always check the video cable connection first. Reconnecting the video cable may fix your problem.
If reconnecting the video cable doesn’t help, most likely you have a problem either with the LCD screen or with the motherboard.
The best way to find out which one is causing the problem is testing the laptop with another working LCD screen. Without this test you’ll have to guess because as I mentioned before this could either bad motherboard or bad LCD screen.
You’ll have to disconnect the video cable from the LCD screen and the inverter board. After that you connect another working screen and test video.
The original screen is white but my test screen works normal and I can see the image. After this test I can tell that the problem must be related to the screen.
After I assembled everything back together and connected the original LCD, it’s still white.
CONCLUSION.
In my case this problem is related to the LCD screen and it has to be replaced.
Feb 01, 2010 | Computers & Internet
The display turn white >>>what can i do?
CONCLUSION.
Jan 18, 2010 | Samsung NC10-14GW Notebook
When I turn on the computer the screen is white but the computer is booting up.
CONCLUSION.
Jan 14, 2010 | Dell Studio 17 Laptop
My laptop won't recognize a projector
You need to push the function key FN and hold it down then press F5
Aug 20, 2009 | Toshiba Satellite Pro S300M-S2403 Laptop
Hello, i have acer aspire one notebooki and have all the time white screen, so i cant work
Hi..
Your problem are related with my laptop problem, but i totally fix it with my own. From my experience I can tell that this problem may be related to the following:
1-laptop-white-screen.jpg Here’s an example of a laptop with white screen. When you turn on the laptop, it starts but the image on the screen is completely white right from the beginning. In my case it was a Toshiba Satellite M45 laptop but this problem may occur with any other brand.
3-video-cable.jpg I noticed that in some cases the laptop screen may turn white because of poor connection between the video cable and the LCD screen. If you want to check this connection, you’ll have to take apart the display panel because the connector is located on the back side of the LCD screen.
4-reconnect-video-cable.jpg I always check the video cable connection first. Reconnecting the video cable may fix your problem.
5-disconnect-lcd-screen.jpg The best way to find out witch one is causing the problem is testing the laptop with another working LCD screen. Without this test you’ll have to guess because as I mentioned before this could either bad motherboard or bad LCD screen.
You’ll have to disconnect the video cable from the LCD screen (connector 2) and the inverter board (connectors 3 and 1). After that you connect another working screen and test video.
6-test-with-another-lcd-screen.jpg For this purpose you using one of my test LCD screens. My test screen is cracked and because of that you see a wide white band in the center but it still works fine for this test.
The original screen is white but my test screen works normal (except the crack of course) and I can see the image. After this test I can tell that the problem must be related to the screen.
7-white-lcd.jpg After I'm assembled everything back together and connected the original LCD, it’s still white.
That's my laptop brand and model, and i am searching an image regarding about my problem. This problem are common to another brand.
Hope it may helpful for you!
Good luck
ICmanServer
Aug 02, 2009 | Acer Aspire One PC Notebook
My laptop went to white screen every time when I on it. How to solve....my laptop -- aspire 4710z -- almost 2 years but it happened JUST it 4 mths.....
Hi..
Good luck
ICmanServer
Jul 31, 2009 | Acer Aspire 4720 Notebook
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
