Question about Samsung Refrigerators
My fridge freezer is not collying at all. - Samsung Refrigerators
  • Samsung Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 19, 2011
How does a side by side domestic fridge work
Freezer one side, refrigerator the other side. Compressor is in the bottom at the rear. Often ice and water dispensers in the door.
Jan 23, 2016 | Refrigerators
I have a Whirlpool wbm46mw Fridge, the freezer is working ok but fridge not getting cold, any suggestions,Thanks
Empty fridge and if possible put steam down vent behind the cover in the freezer section. or hot water. it will com out in the fridge so be carefull. this unblocks the aif feed from the freezer to the fridge section. also make sure the fan is working.
Oct 04, 2013 | Engel Freezer 22 Qt. Fridge/Freezer
Fridge works freezer does not Zannussi
the fridge will soon stop to! all cooling goe to the freezer first! look to see if there is frost in back of the freezer if not it might be low on charge
Apr 11, 2010 | Freezers
Freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
freezer not working on ariston... Solve freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every... (More) freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
Sep 13, 2009 | Freezers
Fridge (KBRA22KLSS00) has lower freezer compartment. Fridge is running, & freezer is cold,however upper portion of fridge is not cold. Is there a fan or a control to bring the cold into the fridge...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Aug 31, 2009 | Refrigerators
Freezer works, fridge part does not
Aug 21, 2009 | Refrigerators
Creda R335NW Fridge/Freezer. The fridge section is not cooling down anymore, The freezer is working ok. Any ideas please?
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Jul 03, 2009 | Refrigerators
Freezer not freezing, and leaking
If this unit has an ice maker and you noticed water leaking into the refigerator, I had a similar problem. The water turn off valve for the ice maker had a small piece of sand or grit lodged in it and stopped the valve from closing properly. So it could not turn of completely and the valve became increasingly more sloppy as the piece of sand was wedged in further. The solution was to replace the samll valve. An easy job for someone a bit handy.
If the water has frozen in the bottom of the freezer compartment the colliing port for the cold air may also be affected. Don't chip the ice out of the bottom, defrost it with pans of hot water.
Hope this helps
May 03, 2009 | Frigidaire Freezers
Fridge of Fridge/Freezer keeps freezing contents.
all the food going to ice temperture at 2
Oct 24, 2007 | Refrigerators
Indesit Fridge Freezer
YOUR DEFROST TIMER OR A BURN OUT DEFROST ELEMENT
Oct 17, 2007 | Engel Freezer 22 Qt. Fridge/Freezer
Refrigerators Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
